Drive 4 -> CQ5 DAM Connection Issues
Aug 24, 2012 7:15 AM
Tags: #4 #cs6 #drive #cq5.5
  1. Connected Drive 4 to the DAM volume
  2. Copy test via the finder, folders copied, files failed.
  3. Copy test via Bridge, same results
  4. Mounted DAM volume via direct network connection, folders and files copied successfully, eliminating the Permissions as an issue
  5. We pulled error logs that you see below.
Any ideas why files are failing to get checked in to the DAM?
23.08.2012 13:35:03.195 *ERROR* [10.203.20.171 [1345746903125] POST /content/dam/3e_dam_test_ml.createasset.html HTTP/1.1] com.day.cq.dam.webdav.servlet.CreateAssetServlet Error
while creating new asset java.lang.NullPointerException
        at com.day.cq.dam.webdav.servlet.CreateAssetServlet.doPost(CreateAssetSe rvlet.java:80)
        at org.apache.sling.api.servlets.SlingAllMethodsServlet.mayService(Sling AllMethodsServlet.java:148)
        at org.apache.sling.api.servlets.SlingSafeMethodsServlet.service(SlingSa feMethodsServlet.java:344)
        at org.apache.sling.api.servlets.SlingSafeMethodsServlet.service(SlingSa feMethodsServlet.java:375)
        at org.apache.sling.engine.impl.request.RequestData.service(RequestData. java:500)
        at org.apache.sling.engine.impl.filter.SlingComponentFilterChttps://mail.google.com/mail/u/0/#inboxhain.render(SlingComponentFilte rChain.java:45)
        at org.apache.sling.engine.impl.filter.AbstractSlingFilterChain.doFilter (AbstractSlingFilterChain.java:64)
        at com.day.cq.wcm.core.impl.WCMDebugFilter.doFilter(WCMDebugFilter.java: 147)
        at org.apache.sling.engine.impl.filter.AbstractSlingFilterChain.doFilter (AbstractSlingFilterChain.java:60)
        at com.day.cq.wcm.core.impl.WCMComponentFilter.filterRootInclude(WCMComp onentFilter.java:308)
        at com.day.cq.wcm.core.impl.WCMComponentFilter.doFilter(WCMComponentFilt er.java:141)
        at org.apache.sling.engine.impl.SlingRequestProcessorImpl.processCompone nt(SlingRequestProcessorImpl.java:257)
        at org.apache.sling.engine.impl.filter.RequestSlingFilterChain.render(Re questSlingFilterChain.java:49)
        at com.day.cq.wcm.core.impl.warp.TimeWarpFilter.doFilter(TimeWarpFilter. java:106)
        at com.day.cq.wcm.mobile.core.impl.redirect.RedirectFilter.doFilter(Redi rectFilter.java:296)
        at com.lifetimefitness.cms.services.common.servlet.CSRFServletFilter.doF ilter(CSRFServletFilter.java:81)
        at com.lifetimefitness.cms.services.ltfweb.servlet.filter.MobileFilter.d oFilter(MobileFilter.java:202)
at com.lifetimefitness.cms.services.ltfweb.security.filter.SecurityFilte r.doFilter(SecurityFilter.java:149)
        at com.lifetimefitness.cms.services.ltfweb.servlet.filter.RunModeFilter. doFilter(RunModeFilter.java:58)
        at org.apache.sling.engine.impl.debug.RequestProgressTrackerLogFilter.do Filter(RequestProgressTrackerLogFilter.java:59)
        at com.day.cq.theme.impl.ThemeResolverFilter.doFilter(ThemeResolverFilte r.java:76)
        at com.day.cq.wcm.foundation.forms.impl.FormsHandlingServlet.doFilter(Fo rmsHandlingServlet.java:220)
        at org.apache.sling.i18n.impl.I18NFilter.doFilter(I18NFilter.java:117)
        at com.day.cq.wcm.core.impl.WCMRequestFilter.doFilter(WCMRequestFilter.j ava:89)
        at org.apache.sling.rewriter.impl.RewriterFilter.doFilter(RewriterFilter .java:83)
        at org.apache.sling.bgservlets.impl.BackgroundServletStarterFilter.doFil ter(BackgroundServletStarterFilter.java:135)
        at org.apache.sling.engine.impl.SlingRequestProcessorImpl.processRequest (SlingRequestProcessorImpl.java:153)
        at org.apache.sling.engine.impl.SlingMainServlet.service(SlingMainServle t.java:206)
        at org.apache.felix.http.base.internal.handler.ServletHandler.doHandle(S ervletHandler.java:96)
        at org.apache.felix.http.base.internal.handler.ServletHandler.handle(Ser vletHandler.java:79)
        at org.apache.felix.http.base.internal.dispatch.ServletPipeline.handle(S ervletPipeline.java:42)
        at org.apache.felix.http.base.internal.dispatch.InvocationFilterChain.do Filter(InvocationFilterChain.java:49)
        at org.apache.felix.http.base.internal.dispatch.HttpFilterChain.doFilter (HttpFilterChain.java:33)
        at org.apache.felix.http.base.internal.handler.FilterHandler.doHandle(Fi lterHandler.java:88)
        at org.apache.felix.http.base.internal.handler.FilterHandler.handle(Filt erHandler.java:76)
        at org.apache.felix.http.base.internal.dispatch.InvocationFilterChain.do Filter(InvocationFilterChain.java:47)
        at com.adobe.granite.license.impl.LicenseCheckFilter.doFilter(LicenseChe ckFilter.java:179)
        at org.apache.sling.security.impl.ReferrerFilter.doFilter(ReferrerFilter .java:238)
        at org.apache.sling.engine.impl.log.RequestLoggerFilter.doFilter(Request LoggerFilter.java:75)
        at org.apache.felix.http.base.internal.dispatch.FilterPipeline.dispatch( FilterPipeline.java:48)
        at org.apache.felix.http.base.internal.dispatch.Dispatcher.dispatch(Disp atcher.java:39)
        at org.apache.felix.http.base.internal.DispatcherServlet.service(Dispatc herServlet.java:67)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
        at com.day.j2ee.servletengine.ServletRuntimeEnvironment.service(ServletR untimeEnvironment.java:250)
        at com.day.j2ee.servletengine.RequestDispatcherImpl.doFilter(RequestDisp atcherImpl.java:315)
        at com.day.j2ee.servletengine.RequestDispatcherImpl.service(RequestDispa tcherImpl.java:334)
        at com.day.j2ee.servletengine.RequestDispatcherImpl.service(RequestDispa tcherImpl.java:377)
        at com.day.j2ee.servletengine.ServletHandlerImpl.process(ServletHandlerI mpl.java:351)
        at com.day.j2ee.servletengine.HttpListener$Worker.run(HttpListener.java: 625)
        at java.lang.Thread.run(Thread.java:662)
23.08.2012 13:35:31.571 *INFO* [Workflow Starter Thread] com.day.cq.workflow.impl.CQWorkflowSession  Workflow instance started with model: /etc/workflow/models/dam/update_asset/j
cr:content/model and  ID: /etc/workflow/instances/2012-08-23/model_7300732138132400 for payload: /content/dam/3e_dam_test_ml/LCCO2028_Magnets_4.indd/jcr:content/rendi tions/origi
nal
    Aug 24, 2012 10:19 AM   in reply to bingotheory
    Are you using CQ 5.5? What OS version? Do you receive any other error messaging? What happens when you create a new file on the desktop in Photoshop CS6, for example, then check that file in (via File > Check In) to the mounted DAM?
    Aug 26, 2012 8:31 PM   in reply to bingotheory
    To operate InDesign documents with Adobe Drive 4, you have to apply CQ 5.5 update1 from this link. http://dev.day.com/docs/en/cq/current/release_notes_update-1.html, which addresses the bug CQ5-17400. this bug can leads to infinite running of the "DAM update asset" workflow for Indd files.
    Aug 27, 2012 12:08 AM   in reply to bingotheory
    Sep 10, 2012 10:20 AM   in reply to bingotheory
    Did the CQ 5.5 Update 1 package resolve your issue? We’d like to be sure you get everything up and running and have it work seamlessly and flawlessly as you mention. Also, wrt the Check In option not being available from the File menu in InDesign; when you open a file from the DAM you will see “Up-To-Date” in the status bar. When you make a change, the file will be checked out and the “Up-To-Date” status will change to “Checked out by me”. The Check In option will then become available.
