Hello
wanted to know with the help of all what better way to visualize or
which forms to view this content in Flash.
I've never used XML, Flash only, so I'm kinda lost.
Flash File
http://www.mediafire...82o6f72hdxa2xkc
reference
MusicXML
Code: XML
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<!DOCTYPE score-partwise PUBLIC
"-//Recordare//DTD MusicXML 2.0 Partwise//EN"
"http://www.musicxml.org/dtds/partwise.dtd">
<score-partwise version="2.0">
<part-list>
<score-part id="P1">
<part-name>Music</part-name>
</score-part>
</part-list>
<part id="P1">
<measure number="1">
<attributes>
<divisions>1</divisions>
<key>
<fifths>0</fifths>
</key>
<time>
<beats>4</beats>
<beat-type>4</beat-type>
</time>
<clef>
<sign>G</sign>
<line>2</line>
</clef>
</attributes>
<note>
<pitch>
<step>C</step>
<octave>4</octave>
</pitch>
<duration>4</duration>
<type>whole</type>
</note>
</measure>
</part>
</score-partwise>
Tanks.
What are you trying to do?
Hi Murphy,
something like this site,
for now the only part of the score display xml
but I'll use mysql and php
http://musicrain.com/demo-sheetmusic.php
Tanks
I think you misunderstand what I am asking. In your first posting you say "what better way to visualize or which forms to view this content in Flash"... what does that mean? For the xml code that you showed, what are you trying to do with it? How do you hope to manipulate it? What code have you tried that is not working for you?
Just so you know, few people will download files, especially from sites like mediafire where you have to wonder if a virus is about to infect your machine as they do what they can to divert you from actually getting the file you are trying to get.
You are more likely to get help when you include everything in your posting, like code and error messages and screenshots.
Hi right
I'll post the codes and flash images
actions layer
line 1
______________________________________________________
// take out if running in Flash MX:
#include "xmlnitro.as"
function Article(id, link, headline, source) {
this.id = id;
this.link = link;
this.headline = headline;
this.source = source;
function makeArray(success) {
var i, j, mainTag, id, link, headline, source;
if (success) {
for (i=0; i<=moXML.childNodes.length; i++) {
if (this.childNodes.nodeValue == null && this.childNodes.nodeName == "moreovernews") {
mainTag = this.childNodes;
for (i=0; i<=mainTag.childNodes.length; i++) {
if (mainTag.childNodes.nodeName == "article") {
id = mainTag.childNodes.attributes["id"];
for (j=0; j<mainTag.childNodes.childNodes.length; j++) {
if (mainTag.childNodes.childNodes
link = mainTag.childNodes.childNodes
} else if (mainTag.childNodes.childNodes
headline = mainTag.childNodes.childNodes
source = mainTag.childNodes.childNodes
thisArticle = new Article(id, link, headline, source);
articles.push(thisArticle);
delete thisArticle;
_root.gotoAndStop("showArticles");
// articles is an array of Article objects
var articles = [];
// read xml and display when loaded
moXML = new XML();
moXML.ignoreWhite = true;
moXML.onLoad = makeArray;
moXML.load("intdev_page.xml");
stop();
Frame 10
news = "";
for (i=0; i<articles.length; i++) {
news += "<a href='" + articles.link + "'>" + articles.headline + "</a><br>";
news += " <font color='#cccccc'>(" + articles.source + ")</font><br>";
stop();
______________________________________________________________
"xmlnitro.as"
// XMLnitro v 2.1
// Branden J. Hall
// Fig Leaf Software
// October 1, 2001
// Thanks to Colin Moock for good whitespace info
// This file simply replaces the built-in parseXML
// method. In doing so it increases the speed of
// XML parsing 70-120% (dependent on file size).
// In addition, the ignoreWhite property now works
// in all versions of the Flash 5 plugin and no
// just the R41/42 versions. In order to do such
// this parser removes all text from mixed content
// nodes (i.e. nodes that contain both child nodes
// and child text nodes). This code is Flash 5
// specific so it makes sure that the user has only
// a Flash 5 plugin.
Object.version = getVersion().split(",");
Object.majorVersion = int(substring(Object.version[0],Object.version[0].length, 1));
Object.minorVersion = int(Object.version[2]);
if (Object.majorVersion == 5){
XML.prototype.checkEmpty = function(text){
var max = text.length;
var empty = true;
for (var i=0;i<max;++i){
if (ord(substring(text, i+i, 1))>32){
empty = false;
break;
return empty;
XML.prototype.parseXML = function(str){
this.firstChild.removeNode();
var treePtr = this;
var tags = new Array();
var textNode = null;
if (Object.minorVersion == 30){
this.status = ASnative(300, 0)(str, tags);
}else{
this.status = ASnative(300, 0)(str, tags, false);
if (this.status == 0){
var curr;
var i=0;
var max = tags.length;
if (this.ignoreWhite){
while (i<max){
curr = tags;
if (curr.type == 1){
if (curr.value == "/"+treePtr.nodeName){
treePtr = treePtr.parentNode;
}else{
treePtr.appendChild(this.createElement(curr.value));
treePtr = treePtr.lastChild;
treePtr.attributes = curr.attrs;
if (curr.empty){
}else{
if (curr.type == 3){
if (!this.checkEmpty(curr.value)){
treePtr.appendChild(this.createTextNode(curr.value));
}else{
if (curr.type == 6){
}else{
if (curr.type == 4){
this.xmlDecl = curr.value;
}else{
this.docTypeDecl = curr.value;
++i;
}else{
while (i<max){
curr = tags;
}else{
if (curr.empty){
}else{
if (curr.type == 3 || curr.type == 6){
}else{
}else{
++i;
Tanks...
For all the questions I asked in the first paragraph you seem to have missed answering all of them. If you cannot explain your problem I am not going to be able to try to help resolve it.
I'm trying to adapt this code is that the original
"xml" is this
"intdev_page.xml"
<?xml version="1.0" encoding="iso-8859-1"?><!DOCTYPE moreovernews SYSTEM "http://p.moreover.com/xml_dtds/moreovernews.dtd">
<!-- by using this feed you have read and agree to our terms and conditions at
http://w.moreover.com/site/about/termsandconditions.html
If the presence of this comment has caused an error in your parser you may use the older
uncommented version by using &o=xml_1 or +xml_1 in the URL. Using the xml_1 version
still means that you have read and agree to our terms and conditions above -->
<moreovernews>
<article id="_35605614">
<url>http://c.moreover.com/click/here.pl?x35605614</url>
<headline_text>Trade and the Third World - hypocrisy in action</headline_text>
<source>Africa Online</source>
<media_type>text</media_type>
<cluster>International development news</cluster>
<tagline></tagline>
<document_url>http://www.africaonline.com/topnews-english-rss.xml</document_url>
<harvest_time>Apr 9 2002 11:42PM</harvest_time>
<access_registration></access_registration>
<access_status></access_status>
</article>
<article id="_35602943">
<url>http://c.moreover.com/click/here.pl?x35602943</url>
<headline_text>Terrorism, poverty are new foes: Macapagal</headline_text>
<source>INQ7.net</source>
<tagline></tagline>
<document_url>http://www.inquirer.net</document_url>
<harvest_time>Apr 9 2002 11:05PM</harvest_time>
</article>
<article id="_35598087">
<url>http://c.moreover.com/click/here.pl?x35598087</url>
<headline_text>E. Asia enjoying strong economic recovery, World Bank says</headline_text>
<source>Kyodo</source>
<tagline></tagline>
<document_url>http://home.kyodo.co.jp/</document_url>
<harvest_time>Apr 9 2002 9:54PM</harvest_time>
</article>
</moreovernews>
The end
I gave a brief it had many "articles" with only three left.
For the case of the score that would be, many lines, just enough
have the base to read the first few lines and then go adapting
according to the elements that appear
then by what I understand has a function called Article
Calling the rest through (id, link, etc.)
but I can not see all the elements in order,
no more giving this error but this blank or sometimes shows a "0"
changes in flash I'm doing (or have some other way to view
otherwise, because then I'll make adaptations with MID and MP3
function part(list, id, headline, source) {
this.list = list;
this.id = id;
var i, j, mainTag, list, id, headline, source;
if (success) {
if (this.childNodes.nodeValue == null && this.childNodes.nodeName == "score-partwise") {
if (mainTag.childNodes.nodeName == "part") {
list = mainTag.childNodes.attributes["list"];
id = mainTag.childNodes.childNodes
thispart = new part(list, link, headline, source);
part.push(thispart);
delete thispart;
var part = [];
moXML = new XML();
moXML.load("score_musical.xml");
stop();
The end
the file "score_musical.xml" is the 'XML' in the first post
Thanks for now but I will try to modify and will post the results.
