Ehrgeiz912
How to add to layer from background?
Aug 26, 2012 4:43 PM
Tags: #mask #help #layer #cs6 #simple
I'm sure this is an incredibly simple task and I can't believe I can't just find the answer, but how do you add to a layer from another layer, for instance, the background?
There are TONS of explanations for how to take away from a layer or create a new layer (layer mask) but nothing on how to add to a layer once it's already made. I made this layer with the magic wand tool and now I simply need to add little bits in to the layer that the magic wand missed.
    Aug 26, 2012 4:53 PM   in reply to Ehrgeiz912
    There are several ways.
    The first I'll suggest is select and copy these bits of the background that you previously missed into a third layer. Optionally merge that down into the previous layer you created.
    Another way is to use the Clone Stamp Tool to copy from one layer to another.
    There are others but you should investigate these two, anyway.
    Aug 26, 2012 8:27 PM   in reply to Ehrgeiz912
    Instead of your workflow, think about this one instead.
    You have an Image, with the Background Layer. You want to add material (pixels) from another Image to that. Select that additional material, and Copy it to the Clipboard. Then, paste it into the original Image, with extra pixels around that image. Add a Layer Mask around it, hiding the pixels, that you do not wish to see. Done.
    Aug 26, 2012 8:59 PM   in reply to Ehrgeiz912
    It is so much easier to keep all the layers seperate when possible. It makes it much easier to edit later on. There is nothing stopping you from creating a new top layer that consist of all the other layers combined into one if you need to apply filters, etc. just use ctrl-alt-shift-e. Yeah its a whole lot of keys to hold at once, but it can be worth it.
    Also as mentioned before you can merge all the layers into one , but should be done after your file is saved, then treat the file as a copy once the layers are merged. Then if you need to save, use save as instead and give it a new name. That way you can go back to your layers to edit if needed. As you can see ctrl-alt-shift-e is a better choice, since you only need the one file.
