hi < how are you all? i hope you all fine...
iam now trying to make more spells for the hero and this spell is fireball
and i want to move right when the hero is on the right also left when the hero on the left
i tried with this code when you press w it should move 10 or 20 px then it should stop
but idont this step "then it should stop" because of this error also the fireball does,t move
as i want
TypeError: Error #1010: A term is undefined and has no properties.
at HERO/onEnterFrame()
here is the code
HERO class
package {
import flash.display.MovieClip;
import flash.events.KeyboardEvent;
import flash.ui.Keyboard;
import flash.events.Event;
import flash.sensors.Accelerometer;
import flash.media.Sound;
import flash.media.SoundChannel;
public class HERO extends MovieClip {
var NIGHTJUNGLE:nightjungle = new nightjungle
var ELECTRICALSHIELD:electricalshield=new electricalshield ;
var speed:int=3;
var fireballindex:Array = new Array
var dir:int;
var ELECTRICITY:electricity = new electricity;
var SOUNDCHANNEL:SoundChannel = new SoundChannel
var firespeed:int = 50
var i:int
public function HERO() {
addEventListener(Event.ADDED_TO_STAGE,onAddedToStage);
public function onAddedToStage(event:Event):void {
addEventListener(Event.ENTER_FRAME,onEnterFrame );
stage.addEventListener(KeyboardEvent.KEY_DOWN,onKeyDown);
stage.addEventListener(KeyboardEvent.KEY_UP,onKeyUp);
SOUNDCHANNEL = NIGHTJUNGLE.play(1,1000)
gotoAndStop(4);
public function onEnterFrame(event:Event):void {
x +=dir*speed;
if(fireballindex.stage){
fireballindex.x += 1
public function onKeyDown(event:KeyboardEvent):void {
if (event.keyCode==Keyboard.RIGHT) {
gotoAndStop(2);
dir=1;
speed = 10
if (ELECTRICALSHIELD.stage)
addChild(ELECTRICALSHIELD)
if (event.keyCode==Keyboard.LEFT) {
gotoAndStop(1);
dir=-1;
speed = 10
if (event.keyCode==Keyboard.UP) {
gotoAndStop(1);
y=10;
if (event.keyCode==Keyboard.Q) {
speed=30;
addChild(ELECTRICALSHIELD);
SOUNDCHANNEL = ELECTRICITY.play()
if (event.keyCode == Keyboard.W) {
fireballindex.push(new fireball())
addChild(fireballindex)
fireballindex.width = 50
fireballindex.x += firespeed * dir
i++
trace(i)
if (event.keyCode == Keyboard.E) {
MovieClip(parent).aa.x = x +100
public function onKeyUp(event:KeyboardEvent):void {
if (ELECTRICALSHIELD.stage) {
removeChild(ELECTRICALSHIELD);
if (SOUNDCHANNEL != null)
speed=0;
SOUNDCHANNEL = ELECTRICITY.play(1,1)
if (event.keyCode==Keyboard.W) {
speed = 0
gotoAndStop(3);
} else if (event.keyCode == Keyboard.RIGHT) {
speed =0
gotoAndStop(4);
thank you
I would not use " i " to target the fireball object. If fireballs happen to be getting removed at any point, that value of i will be erroneous. The fireball you add might not be the one at fireballindex.
If all the code is happening in the same vicinity, then I would declare the instance by a var name and use the name...
var fBall:fireball = new fireball();
fBall.name = "fb"+String(i);
fBall.width = 50;
fBall.x += firespeed * dir;
fireballindex.push(fBall);
addChild(fBall);
i++;
Later on if you need to
...Copy link to clipboard
Use the trace command to find out which object in the onEneterFrame function is causing the error...
trace(x, dir, speed, i, fireballindex, fireballindex.stage);
x +=dir*speed;
i did that , nothing happend
i copied your trace command under the onEnterFrame function
thank you for your replay
If nothing happened, then you need to see why your onEnterFrame function is not being called. Trace thru the processing route of your code to see where things stop working as you know they should.
i know the problem from where , i always check the code after every small detail
it is from here
if i remove these lines the code is gonna work
thank you again for your replay and sorry because i late in the replay
If you checked and know what's wrong with that code, then you should be able to fix it. If you don't know what's wrong with that code, you need to use the trace command to see which variable/object is causing the error.
i will try that , but my way to use this spell is wrong because of that i asked you , because iam sure that you have better way to move the fire ball object to the left when the hero is left and to the right when the hero is right and remove the fireball object
from the stage after 30 px from moving
here
i++
trace(i)
i just tried with the direction idea to do the move but as you see it doesn,t move like i want also i get error , so can you give me better way to do this move please
fBall.width = 50;
addChild(fBall);
i++;
Later on if you need to target that fireball you can use the array or you can use its name.
If you wanted to still use the non-var approach (I see no reason to) then instead of targeting
fireballindex
I would target the last item added to the array which is definitiely going to be
fireballindex[fireballindex.length-1])
thank you , i will try to do that
