docRef.Export bugs?
Aug 27, 2012 9:22 PM
I seem to have found two bugs in docRef.Export for jpg in CS4.
I found in posting this that the period marks (full stops) in the filename strings were almost invisible. Since these are crucual to the point I have enclosed then in {} like this "{.}"
1. Poor quality jpg exports irrespective of the  QualitySetting value.
2. The documentation tells you to supply the file path with no extension - it will be supplied. However Export clearly has a function to strip off the extension should you have left it on. This then is antagonistic to legal windows (7 in my case) file names, since these allow multiple periods in the file name, only the text after the last period being considered the extension. The Export function function strips off everything after any period there is in the filename and then adds jpg.
So a file  XYZ{.}ABC{.}ai - which we want to generate XYZ{.}ABC{.}jpg should be supplied as XYZ{.}ABC acording to the documentation - but if this is done the return is XYZ{.}jpg. If XYZ{.}ABC{.}ai is supplied then it gets even stranger, and I am not sure of all the ramifications, but filenames like XYZ{.}AbC abc{.}ai generated output names like XYZ{.}ABC -abc{.}jpg - note the added "-"!
I suggest the function should either assume the filename fed it is correct and just add the ".jpg" or the documentation should be changed to require the extension to remain, and the function should strip off the text after the last period and append "jpg".
Any comments / workarounds?
    Aug 28, 2012 1:40 AM   in reply to Peter JD Matthews
    How about export with regular name, and rename filename after export.
    Aug 28, 2012 6:48 AM   in reply to Peter JD Matthews
    When you say quality are you refering to the applied compression or the fact that it's always 72dip as for the export I have always supplied full file path as parameter… You may need to post some code?
    Aug 28, 2012 8:07 AM   in reply to Peter JD Matthews
    exporting with a fixed simple 'fake' name and
    then renaming
    Yes, that's what I mean, I haven't test this issue through.
    Aug 28, 2012 8:47 AM   in reply to Peter JD Matthews
    The AI way is to output at 72dpi and allow you to scale H&V… I don't recall anyone posting who prefers it this way about…? but there you go… I don't understand what you are saying about export naming though?
    Aug 28, 2012 10:52 PM   in reply to Peter JD Matthews
    What I am saying is… In javaScript… exportFile (exportFile: File, exportFormat: ExportType[, options: any]) 3 parameters…
    var jpegOpts = new ExportOptionsJPEG();
    jpegOpts.antiAliasing = true;
    jpegOpts.qualitySetting = 100;
    jpegOpts.optimization = true;
    jpegOpts.horizontalScale = 100;
    jpegOpts.verticalScale = 100;
    jpegOpts.artBoardClipping = true;
    var jpegPath = File( dF.fsName+'/'+baseName+'_'+abName+'.jpeg' );
    docRef.exportFile( jpegPath, ExportType.JPEG, jpegOpts );
    Aug 31, 2012 9:25 AM   in reply to Peter JD Matthews
    You should probably make the first artboards rectangle the same as the documents visible bounds ( if theres only one ) or do the math off each artboards rectangle to caluclate sizes… Never seen this issue of file naming before so my guess it is VB related?
