Safely adding a "mailto:" link to your website
Aug 28, 2012 7:44 AM
My website has a "Email Me" button that I'm not yet sure of the behavior of. Either it will point straight to a "mailto:", or it will go to a form (that the HTML will specify a target address for).
In either case, what would be the safest way to add a target email address so that robots don't automatically pick it up and add it to their "spammable" lists?
    Aug 28, 2012 7:48 AM   in reply to jyeager11
    There is no safe way to use a mailto: link.  Either you use it and take your chances, or you don't use it and be assured that spambots are not able to find your email address.
    When I say "don't use it" I mean use another method to send your emails, like server scripting which is totally safe from spambots.
    Aug 28, 2012 8:11 AM   in reply to jyeager11
    Quck and easy?  I dunno.
    What kind of server are you hosted on (Windows or *nix)?
    Aug 28, 2012 8:13 AM   in reply to MurraySummers
    Or - go to http://www.bebosoft.com/products/formstogo/overview/ and see if that looks promising.
    Aug 28, 2012 8:33 AM   in reply to jyeager11
    Looks to me like you are on a Linux server, so you could use PHP to process your contact form and send your email.  See if the forms to go thing looks interesting....
    Aug 28, 2012 8:45 AM   in reply to jyeager11
    "Commercial product"?  PHP is usually free, and if the email address is contained within PHP code, it's invisible to the internet.
    ^_^
    Aug 28, 2012 8:56 AM   in reply to jyeager11
    You could use an email obfuscating javascript. Though, those folks who disable javascript won't see your email link.
    I've used this one in the past...
    http://www.dynamicdrive.com/emailriddler/
    Aug 28, 2012 9:01 AM   in reply to Jon Fritz II
    Obfuscating JavaScript doesn't work, anymore, from the chatter I've been hearing.  Even the ColdFusion obfuscating CFCs have been surpassed.
    ^_^
    Aug 28, 2012 9:20 AM   in reply to jyeager11
    You can do something like this on your page -
    <?php echo $success?"<p>Your email has been sent!</p>":''; ?>
    <?php echo $fail?"<p>There has been an error. Your email has not been sent!</p>":''; ?>
    <form action="<?php echo $_SERVER['PHP_SELF']; ?>" method="POST" name="form1">
    <label for="comments">Comments: </label>
    <textarea name="comments" id="comments"></textarea>
    <input type="submit" name="submit" value="submit">
    </form>
    Then at the top of the page put this (above the doctype) -
    <?php
    $success = false;
    $fail = false;
    if (array_key_exists('submit', $_POST) {
    $to = 'you@example.com';
    $subject = 'The email subject line';
    $message = $_POST['comments'];
    $headers ="FROM: admin@example.com\r\n";
    $success = mail ($to, $subject, $message, $headers);
    $fail = !$success;
    Message was edited by: Murray *ACP*
    Aug 28, 2012 9:21 AM   in reply to MurraySummers
    Be aware that this email method is bare bones and is subject to potential email injection, but it works to replace mailto: links.
    Aug 28, 2012 9:38 AM   in reply to jyeager11
    First contact your web host and ask them if they have a form-to-email script you can use.  Hosts often provide scripts on their servers which you can activate through your Admin Panel or by referencing the script in your form's action attribute.
         <form action="path-to-form-on-server/form-to-email-script.php">
    Ideally, you want a form-to-email processing script that:
    a) validates form input fields,
    b) blocks hackers,
    c) stops submissions from spam bots,
    d) hides your email address from harvesters.
    Formm@iler.php from DB Masters script does all of this  and it's free if you credit the author; $20 per domain if you don't.
    Related Links:
        FormToEmail.com (free & pro versions available)
        http://formtoemail.com/formtoemail_pro_version.php
        Tectite
        http://www.tectite.com/formmailpage.php
    Nancy O.
    Aug 28, 2012 10:26 AM   in reply to Nancy O.
    There are also (old fashioned) cgi scripts that are usually offered by hosting services.
    Aug 28, 2012 1:36 PM   in reply to WolfShade
    Perl isn't as robust as PHP.  If that's all you can use, sure.  But if given a choice, PHP is much better.
    Nancy O.
    Mar 1, 2013 9:38 AM   in reply to jyeager11
    No offense intended, but the question was about a safe substitute for mailto:, ie, a script that will create a new email in the default email app, drop in an address and subject via a simple text link or button. Is there a JS that will do this while masking the address?
    Mar 1, 2013 9:56 AM   in reply to customizer2
    So called e-mail address obfuscation methods are not 100% reliable.  If JS is disabled, they don't work.  Also, mailto: links require the end user to have e-mail software installed on their device.  Owing to the increased popularity and accessibility of free web mail services like G-mail, Hotmail, Yahoo mail, etc...  most people don't need e-mail software anymore.  Without software, clicking a mailto: link does absolutely nothing.
    For best results, use a contact form with a server-side e-mail processing script.
    Nancy O.
