Cannot update Illustrator CS6 Mac to version 16.0.1
Aug 28, 2012 6:11 AM
I have Illustrator 16.0.0 retail on my Mac running Mountain Lion, and has downloaded he Updater to version 16.0,1
I have Illustrator 16.0.0, version 682 on my system.
When running the Updater, it end up with Installation fail, this update is not applicable for you.
I have tried to uninstall and reinstall Illustrator but the update problem persist.
All other updates went fine. and Adobe Application Manager stated that all my software is up to date, no update
I have just updated Prelude To version 1.0.2 without any problem thru AAM
Help please.
    Aug 28, 2012 7:06 AM   in reply to sanchaithw
    I'm running into the same problem. I get an Upload Failed message when I attempt to update Illustrator CS6. When I click on the error log link I get the following message:
    Adobe Illustrator CS6 Update (version 16.0.1)
    Installation failed. Error Code: U44M1P7
    Does anyone know what the issue may be and how to solve it?
    Thanks.
    Aug 28, 2012 8:09 AM   in reply to GD63
    Same exact error here this morning.
    Aug 28, 2012 9:34 AM   in reply to sanchaithw
    Where I can download the Application Manager 6.2?
    Aug 28, 2012 9:36 AM   in reply to Rollerblader-1959
    Aug 28, 2012 10:07 AM   in reply to Rollerblader-1959
    I had to reinstall Illustrator... then the updater worked!
    Aug 28, 2012 3:35 PM   in reply to sanchaithw
    It most definitely does NOT work for me.  I tried the new Application Manager, and the update still fails with the following error:
    Aug 28, 2012 5:36 PM   in reply to sanchaithw
    It's a Mac.  The error code is linked from the resulting error message - just clicking the word "error" provides the code.
    Aug 29, 2012 6:36 AM   in reply to yapple_dapple
    Yapple_Dapple which version of the Adobe Application Manager do you have installed?  You can locate the Adobe Application Manager in Applications/Utilities/Adobe Application Manager/core.
    Aug 29, 2012 7:15 AM   in reply to Jeff A Wright
    6.2.112.0, installed fresh yesterday.
    Aug 29, 2012 7:16 AM   in reply to yapple_dapple
    BTW, this also fails with the same error on my Macbook Pro.  Both machines are running 10.8.1, which has been a little flakey on the Mac Pro 3,1, but pretty solid on the laptop.
    Aug 29, 2012 7:57 AM   in reply to yapple_dapple
    Can you please review your installation log located in Library/Logs/Adobe/Installers to see what maybe the cause.  You can utilize the directions listed in Troubleshoot with install logs | CS5, CS5.5, CS6 - http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5 -cs5.html for information regarding how to review the installation log.
    The quick summary though is doing a search on the words ERROR and FATAL.  You can then do a search on the code at Adobe.com.  You can also find many of the error codes listed at Installation, launch log errors | CS5, CS5.5, CS6, CCM - http://helpx.adobe.com/x-productkb/global/installation-launch-log-erro rs-creative.html.
    Aug 29, 2012 12:12 PM   in reply to Jeff A Wright
    Here's the final entry in the Illustrator installer log:
    START - Installer Session
    RIBS version: 6.2.10.0
    OSX version: 10.8.1
    ::START TIMER:: [Total Timer]
    CHECK: Single instance running
    CHECK : Credentials
    Load Deployment File
    deploymentFile option not given
    CHECK : Another Native OS installer already running
    Create Required Folders
    Assuming install mode
    Looking up install source path
    Sync Media DB ...
    ::START TIMER:: [Sync Media DB]
    Pre check media db sync
    End of Pre check media db sync. Exit code: 0
    :: END TIMER :: [Sync Media DB] took 20 milliseconds (0.02 seconds)
    Ready to initialize session to start with ...
    ::START TIMER:: [CreatePayloadSession]
    -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
    Updated source path: /Users/ericdarling/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16 -mul/16.1
    Updating media info for: {449931D3-C2C4-4817-919E-9774ECE85BFF}
    Ignoring original data since install source is local
      Type: 0, Volume Order: 1, Media Name:
      Path: /Users/ericdarling/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16 -mul/16.1/payloads/AdobeIllustrator16-mul-180812133154/AdobeIllustrato r16-mul-180812133154.dmg
    --------------------  END  - Updating Media Sources -  END  --------------------
    Supported RIBS version range: [0.0.66.0,6.2.10.0]
    ----------------- CreatePayloadSession: machine is x86 ---------------
    [       0] Tue Aug 28 18:34:47 2012  INFO
    ______ Verify Dependency Subscribers ______
    BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
      {449931D3-C2C4-4817-919E-9774ECE85BFF} Adobe Illustrator CS6 Core_16.0.1_AdobeIllustrator16-mul 16.0.1.0: 0 (0,0)
    END Operation order for all session payloads: mediaGroup (requires,satisfies)
    Patch {449931D3-C2C4-4817-919E-9774ECE85BFF} Adobe Illustrator CS6 Core_16.0.1_AdobeIllustrator16-mul 16.0.1.0 can be applied to product {AAF0D225-F129-40F2-916E-12E28DBD19ED} Adobe Illustrator CS6 Core 16.0.0.0
    Overwrite property "extensionsOnly" to: 1
    Overwrite property "mode" to: silent
    Overwrite property "patchesOnly" to: 1
    Overwrite property "workflow" to: updater
    Found payload actions:
    Deciding what installer mode to use...
    BEGIN Setting requested payload actions
    Value returned on lookup of payload: {449931D3-C2C4-4817-919E-9774ECE85BFF} Adobe Illustrator CS6 Core_16.0.1_AdobeIllustrator16-mul 16.0.1.0 is: false
    Action string for {449931D3-C2C4-4817-919E-9774ECE85BFF} Adobe Illustrator CS6 Core_16.0.1_AdobeIllustrator16-mul 16.0.1.0  is install
    END Setting requested payload actions
    Collected advanced path check information for INSTALLDIR
    INSTALLDIR is a well-formed path
    INSTALLDIR is not the root path
    INSTALLDIR is on a local volume
    INSTALLDIR is on a writable volume
    INSTALLDIR is not on a case sensitive volume
    INSTALLDIR passed path basic path validation: /Applications
    BEGIN InstallOperationsQueue Unordered operations
      {449931D3-C2C4-4817-919E-9774ECE85BFF} Adobe Illustrator CS6 Core_16.0.1_AdobeIllustrator16-mul 16.0.1.0:  with operation install
    END InstallOperationsQueue Unordered operations
    BEGIN InstallOperationsQueue Ordered operations
    END InstallOperationsQueue Ordered operations
    Payloads passed preflight validation.
    Call PreSession Custom Hook
    Calling the custom action code for pre-install for payload {449931D3-C2C4-4817-919E-9774ECE85BFF} Adobe Illustrator CS6 Core_16.0.1_AdobeIllustrator16-mul 16.0.1.0
    ::START TIMER:: [Payload Operation :{449931D3-C2C4-4817-919E-9774ECE85BFF}]
    [       1] Tue Aug 28 18:34:47 2012  INFO
    Installer Operation: PayloadInstaller
    Request to install payload
    Payload {449931D3-C2C4-4817-919E-9774ECE85BFF} Adobe Illustrator CS6 Core_16.0.1_AdobeIllustrator16-mul 16.0.1.0: Calling ARKEngine from path /Applications/Utilities/Adobe Application Manager/DECore/DE6/resources
    [       1] Tue Aug 28 18:34:49 2012  INFO
    CustomizedPatch property not found in database
    Beginning installation for payload at /private/tmp/.tempdirfrEfqL18/Install.db
    Attempting to patch file: "/Applications/Adobe Illustrator CS6/Plug-ins.localized/Illustrator Formats.localized/SVG File Format.aip/Contents/Resources/it.lproj/InfoPlist.strings"(Seq 3)
    [       1] Tue Aug 28 18:34:49 2012 ERROR
    DF019: Unable to locate file to patch at "/Applications/Adobe Illustrator CS6/Plug-ins.localized/Illustrator Formats.localized/SVG File Format.aip/Contents/Resources/it.lproj/InfoPlist.strings"(Seq 3)
    DW063: Command ARKPatchCommand failed.(Seq 3)
    Completing installation for payload at /private/tmp/.tempdirfrEfqL18/Install.db
    [       0] Tue Aug 28 18:34:49 2012  INFO
    *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
    :: END TIMER :: [Payload Operation :{449931D3-C2C4-4817-919E-9774ECE85BFF}] took 1516 milliseconds (1.516 seconds)
    User specified overrideFile:
    The csu inventory was not updated for payload {449931D3-C2C4-4817-919E-9774ECE85BFF} Adobe Illustrator CS6 Core_16.0.1_AdobeIllustrator16-mul 16.0.1.0, value of local var is -1
    Calling the ROLLBACK custom action code for pre-install for payload {449931D3-C2C4-4817-919E-9774ECE85BFF} Adobe Illustrator CS6 Core_16.0.1_AdobeIllustrator16-mul 16.0.1.0
    No operation.  We're done:
    [       0] Tue Aug 28 18:34:51 2012  INFO
    Total components installed: 0
    Total components repaired: 0
    Total components removed: 0
    [       0] Tue Aug 28 18:34:51 2012 ERROR
    DW050: The following payload errors were found during install:
    DW050:  - Adobe Illustrator CS6 Core_16.0.1_AdobeIllustrator16-mul: Install failed
    Call PostSession Custom Hook
    :: END TIMER :: [Total Timer] took 11646 milliseconds (11.646 seconds) DTR = 4.12159 KBPS (0.00402499 MBPS)
    -------------------------------------- Summary --------------------------------------
    - 0 fatal error(s), 3 error(s), 0 warning(s)
    ----------- Payload: {449931D3-C2C4-4817-919E-9774ECE85BFF} Adobe Illustrator CS6 Core_16.0.1_AdobeIllustrator16-mul 16.0.1.0 -----------
    ERROR: DF019: Unable to locate file to patch at "/Applications/Adobe Illustrator CS6/Plug-ins.localized/Illustrator Formats.localized/SVG File Format.aip/Contents/Resources/it.lproj/InfoPlist.strings"(Seq 3)
    ERROR: DW063: Command ARKPatchCommand failed.(Seq 3)
    ERROR: DW050: The following payload errors were found during install:
    ERROR: DW050:  - Adobe Illustrator CS6 Core_16.0.1_AdobeIllustrator16-mul: Install failed
    Please search the above error/warning string(s) to find when the error occurred.
    These errors resulted in installer Exit Code mentioned below.
    [       0] Tue Aug 28 18:34:52 2012  INFO
    Exit Code: 7 - Unable to complete Silent workflow.
    Please see specific errors and warnings for troubleshooting. For example, ERROR: DF019, DW063 ...
    END - Installer Session
    Aug 29, 2012 12:40 PM   in reply to yapple_dapple
    The failure appears to be at DF019: Unable to locate file to patch at "/Applications/Adobe Illustrator CS6/Plug-ins.localized/Illustrator Formats.localized/SVG File Format.aip/Contents/Resources/it.lproj/InfoPlist.strings"
    If you view the package and navigate to that directory does the InfoPlist.strings file exist?  If so can you also verify the permissions on the file so that system and admin groups have read & write access.
    Aug 29, 2012 12:47 PM   in reply to Jeff A Wright
    I've only got an en.lproj folder in the Contents/Resrouces folder.  That folder does have the InfoPlist.strings file.  Should I expect to also have an it.lproj folder there?  Are those language files?
    Aug 29, 2012 12:55 PM   in reply to yapple_dapple
    Yes I have verified on both my Creative Cloud and perpetual version installations.  This is what is causing your failure.
    I thought you already posted that you had removed and reinstalled Illustrator?  Regardless you will need to do so again because it appears your current installation is incomplete.
    Sep 4, 2012 1:05 AM   in reply to Jeff A Wright
    I got the same problem as user yapple_dapple and read all of the above comments but this is unacceptable. I mean I paid a lot of money for this product and suddenly it doesn't work anymore!
    Will this problem be fixed within a new soon to be coming update? I don't have time to reinstall Illustrator and hoping for the best.
    Sep 4, 2012 11:40 AM   in reply to Jeff A Wright
    Hi Jeff, no it was someone else who had reported they tried re-installing from scratch.  I did that, and the update worked.  I am glad Adobe allows me to download the installer perpetually - that's good customer service!  Thanks, Jeff.
    Sep 4, 2012 11:48 AM   in reply to yapple_dapple
    Excellent thank you for the update Yapple_dapple!
    Calculating status...
    Sep 7, 2012 7:11 AM   in reply to Jeff A Wright
    Gentlemen, I've just downloaded a stand-alone 16.0.1 update (AAM v. 6.2.112.0 didn't see it for some reason) and that's what I get tying to install it:
    Any thoughts? Please?
    Sep 7, 2012 10:40 AM   in reply to andrew.kramar
    Andrew.Kramar please try the steps listed in message #15 to review your installation log for the update.  Also unless you installation log matches exactly what Yapple_Dapple posted in message #16 I might recommend creating a new thread regarding your difficulties.  This thread is already quite difficult to read due to the previously posted install log.
    Sep 10, 2012 12:42 AM   in reply to Jeff A Wright
    Okay. I had a small workaround on this: I have another creative suite installed on my MacBook Pro, where Illustrator updated successfully. I've just copied that one (the whole folder) on my iMac, where trouble persisted and it worked! Shows version 16.0.1.
    Sep 21, 2012 2:15 AM   in reply to sanchaithw
    Thanks sanchaithw
    I have solved the problem by downloading the latest version of Adobe Application Manager and install it (version 6.2.122.0).
    It worked for me!
    Oct 8, 2012 10:30 PM   in reply to sanchaithw
    After following the troubleshooting instructions and reading through the summary of the error logs, I ended up manually copying the missing language.lproj folders with their InfoPlist.strings files from the same directory structure in my back-up of CS5 to the /Applications/Adobe Illustrator CS6/Adobe Illustrator.app/Required/Plug-ins/Rasterize.aip/Contents/Resources/ location indicated by the error log. I also compared the text in the existing newer lproj files and changed the copied versions to match the newer info. It was tedious, but the updater worked after that.
    Jan 24, 2013 8:55 PM   in reply to naomiquinones
    on Mac OS X Mountain Lion 10.8.2..........close all the backup programs like SugarSync, dropbox, box...etc...and install latest installer from adobe and run the setup. Problem solved.
