zz bottom
Rendered sequence video is flipped vertically, dimmed and b&w
Aug 29, 2012 10:03 AM
Tags: #premiere #playback #cs6 #flipped #dimmed
Hi community!  I searched, but all instances I found of similar behavior were either on much older versions or else had unique circumstances...
I keep seeing odd behavior of my footage in the timeline.  All of my clips begin in AE CS6, which I then export as the default AVI Uncompressed container/codec (no alpha).  I am trying to assemble a rough edit video in Premiere CS6, but when I "Render entire work area" to see my preview playback smooth, the video changes to upside-down and black & white.
In addition, all .mov h.264 clips that I import (which were exported from AE CS6 on PC) are always this way; even before I render them.  To be clear, all of these clips completely normal when played independently in VLC.
I am using Premiere CS6 along with AE CS6.  Both are up to date.  My system is a PC running Windows 7, Intel i7 2600k, ATI 6970 GPU, 16GB Ram...
Thanks for any insight!
    Aug 29, 2012 10:44 AM   in reply to zz bottom
    Just to get this out of the way early, what date/version of the Catalyst driver, are you running?
    Nov 21, 2012 2:33 PM   in reply to zz bottom
    Hi, did you ever solve the problem? im having the same issue and have no idea how to fix it. your reply would be highly appreaciate.
    Kent
    Jan 2, 2013 10:10 AM   in reply to zz bottom
    This also occures with .MP4, I've found. Irritating to no end, anyone with a solution would be very much appreciated.
    Jan 30, 2013 5:29 AM   in reply to zz bottom
    I'm having the same issue. Help!
    ATI Mobility Radeon 5700 Series
    Windows 7 64bit / Service Pack 1
    Intel Core i7 / 1.73 GHz
    4.00 GB RAM
    Feb 1, 2013 12:51 PM   in reply to zz bottom
    I do not know if it will apply to this instance, but there is a similar thread: http://forums.adobe.com/message/5011820?tstart=270#5011820
    Where the OP got resolution.
