Connecting to Dynamic Link server failed
Aug 30, 2012 7:08 AM
I am using an HP Desktop computer:
- 24 GBs RAM
- Quad Core i7
- NVIDIA GTX-580 GPU
- Windows 7 Professional
I have Master Collection CS6 and I'm not sure if Dynamic Link ever worked properly for me. But I am experiencing 2 issues:
1). When I use Media Encoder, I want to use "File" > "Add After Effects Composition..." or "Premiere Pro Sequence..." and can't progress further. When I try to bring in the Premiere Pro sequence, I get a loading bar, but it never loads the sequence. When I try to bring in the After Effects composition, I get the message "Connecting to the Dynamic Link server failed."
2). When I open a squence in Premiere Pro that has a clip that is Dynamically Linked to After Effects, the clip will show in the timeline as media not found or available. I have to try and relink it to make it work. This would be a huge hassell if I have many clips that are dynamically linked.
I have tried virus scans, reinstalling the software and checking to make sure the firewall is not blocking the Adobe protocols. Nothing seems to work. I unfortunately have never been able to use Dynamic Link until I got a computer that was speedy enough that would allow me to run Premiere and After Effects at the smae time! :-) Is anyone else having this issue and is there a solution?
Here are some screen shots:
    Aug 31, 2012 5:07 AM   in reply to Enrique1972
    If you haven't yet, please try deactivating your Adobe software, rebooting, then launching and re-activating the Master Collection.  That procedure has fixed licensing issues that affected presets and codecs; it may help reset the dynamic link stuff.
    Jeff
    Aug 31, 2012 4:23 PM   in reply to Enrique1972
    On a Windows box, you can reset your preferences and plug-in cache by holding down Alt+Shift while launching Pr, and holding them until the Welcome screen appears.  "Trashing your prefs" is roughly equivalent to creating a new user account.  Maybe worth a try holding Opt+Shift on the Mac?
    Jeff
    Sep 5, 2012 4:05 PM   in reply to Enrique1972
    Many of the Internet Security Solutions out today stop the network services required for Dynamic Linking to work. Unless an editor feels the protection is required for Web Surfing habits, editors may want to avoid this. The 2 Internet Security Solutions out that so far have not caused this issue with Dynamic Linking are ESet and Trend Micro.
    Eric
    ADK
    Sep 5, 2012 5:42 PM   in reply to ECBowen
    No issues so far with Webroot, either.
    Jeff
    Apr 21, 2013 8:53 AM   in reply to Enrique1972
    I've been searching/troubleshooting for days, none of the firewall, new shortcuts in folder, antivirus, you name it I tried it even wiped my system which seemed to work at first..
    What did it for me in the end was I had Dxtory (a software recorder, for recording gameplay) running on startup, and somehow it interfered with only Premiere projects in Media Encoder, I could still import AE projects go figure.
    Check all the programs you have running or use sometimes, if they have some sort of hook into other programs/deal with video/codecs this could be your problem too!
    Thanks to everyone trying to solve this problem!
    -JonOfAllGames
    Apr 27, 2013 8:24 AM   in reply to Enrique1972
    I guess the easiest way is to find the path C:\Program Files (x86)\Common Files\adobe\dynamiclink and set the file dynamiclinkmanager.exe as "Run As Administrator"  and then set your AfterFX.exe as "Run As Administrator", that would solve the problem
