deviousangel07
How do you add the files name to images within a PDF
Aug 30, 2012 8:19 PM
Tags: #coded_pdf #image_labeling #label_images
I have been searching the web trying to find an answer to this question, I am not sure what the proper term is called, but I refer to it as a 'coded pdf'. Hopefully someone knows what I am talking about and can help me find an answer!
The end product is a coded PDF that has the file name of all the images lableled on top the image. For example, a product brochure that has 500 images, all of them would be 'coded' with their file name, to find easy in source files. - Is this an export option in InDesign, or an option somewhere in Acrobat?
Thank you in advance for any help.
-Melissa
    Aug 31, 2012 6:25 PM   in reply to deviousangel07
    Use a phote editing program to add the "label" to the images.
    Then use Acrobat to create a PDF (combine files) of the images.
    Be well...
    Sep 1, 2012 2:53 AM   in reply to CtDave
    No, Melissa's asking for a filename that's searchable - text made of pixels is no use.
    Acrobat cannot apply the original image filenames after the PDF has been created as it can't read the information from anywhere. You have two options, both in InDesign:
    • use smart captions to add the name of the file in a visible format beside each image.
    • use accessibility tagging and place the image filename in the ALT TEXT field, then export the PDF with tags enabled (the filename will not be visible on the page but will show if you hover your mouse over the image).
    Sep 4, 2012 10:53 PM   in reply to deviousangel07
    The LabelGraphic script is redundant now InDesign captions can pick up metadata automatically. See here.
    Sep 5, 2012 7:45 PM   in reply to deviousangel07
    The Captions feature was added in InDesign CS5.
