DP998877
Acrobat PDF Printer Hangs in Windows 8
Aug 31, 2012 3:11 AM
Printer Hang.pngI am running Windows 8 Enterprise RTM  64-bit on an Intel i7-3770 3rd gen CPU, Z77 chipset. I've found that most PDF printers I have been using on Windows 7 now hang on 8, including the Acrobat X printer (latest version). I have found one free alternative that works fine, but would like to get back to using the Acrobat printer. Will Adobe be releasing an update that addresses the hang?
Above is a screenshot afterr more than ten minutes:
    Aug 31, 2012 10:09 AM   in reply to DP998877
    Adobe doesn't offer support for beta-software. When Windows 8 is released it may be supported by Acrobat X or it may have to wait for Acrobat XI. My bet is that it will be fixed. Adobe generally doesn't pre-announce its support for software that has not yet been released.
    Sep 3, 2012 5:06 AM   in reply to DP998877
    I have had no problem with various PDF printers in Win8 32-bit. Thus it may be the 64-bit aspect. In that case, be sure to update Acrobat as something like 10.1 is needed for 64-bit systems. Be aware that you need to deactivate Acrobat before you do any new dealing with the OS.
    Sep 9, 2012 2:59 AM   in reply to Bill@VT
    Adobe may be working on a fix for AAX in the background, but typically does not put a lot of effort into the prerelease versions because of the number of changes tha usually occur before the final release that do effect Adobe software (usually a lot). They are probably just keeping track of potential problems to test and attack when Win8 is released next month.
    In most of my testing of Win8, things are pretty much compatibile with Win7, except at this point a lot of drivers are missing. I expect a lot of folks will have problems with Win8 on legacy hardware because of driver issues (my case with my tablet -- not slate). I also replaced the metro interface with a classic Windows Start system -- what a relief. That interface may be nice for folks who like touch screens, but it is the pits for the rest of the folks and at this point MS is providing no alternative.
    I am assuming you are having problems with the print to the Adobe PDF printer (you kind of implied). To test the source of the problem, print to file with that printer. Then open the file in Distiller to see if the conversion works. If so, you will at least know if AcroTray is the source of the problem. Have you tried PDF Maker? Of course, I suspect that the 64-bit system is the ultimate cause of the problem. Win7 64-bit has been a nightmare for many folks with software that will not work.
    Jan 13, 2013 9:57 PM   in reply to DP998877
    Hello All
    I have been struggling with this same problem of Printing to Acrobat PDF driver freezing up not only the print spooler, but also the software I was printing from, on Windows 7 64Bit, using both acrobat 9.4 and Acrobat X with the same freeze, stall lockup result.
    I think this is the same problem you are having.
    I found many questions about this online but no useful answers, and alot of fingerpointing trying to blame different programs and combinations of software.
    The 1 solution, which created a PDF and did not freeze, was to switch of the choice of a saving location in the PDf driver and setting a fixed PDF save location instead of the ASK for location option.
    This worked but was a real pain having to move and rename the file each time.
    This got me thinking that there was actually nothing wrong with the PDF driver.
    The problem seemed to be the user input to save the file to a certain location.
    I then experimented and found that if I was fast enough with a file name, that the save to location option did not freeze up when creating the PDF.
    By repeatedly trying to print and looking at the print dialog box I noticed that after a count of 5 seconds the Acrobat PDF print driver progress box greyed slightly (Asif loosing focus) and after that happened there was no hope of a successful PDF.
    The 5second timer got me thinking about a windows timeout, rather than a PDF option.
    PDF Print Freeze Problem Solution:
    Windows 7 64 bit (And I assume Windows 8 too) has a default program timeout of 5 seconds after which Windows considers a program to be NOT RESPONDING.
    The time during which the PDF printer is waiting for a response from you for a save location, is seen as inactive by Windows and Windows decides that the Print driver has stalled.
    Something then changes anough to effect the driver, and once the PDF print driver is allowed to carry on and save the PDF it can't anymore and stalls.
    Solution is to edit the HungAppTimout in the Windows Registry, and set it to something like 20000 to 30000 = 20 to 30 seconds.
    http://technet.microsoft.com/en-us/library/cc978614.aspx (Info regarding the Registry Key)
    HKEY_CURRENT_USER\Control Panel\Desktop\HungAppTimeout
    This then give you 20-30 seconds to select a save location for your PDF.
    In my case (Windows 7 64bit) the Registry entry was missing.
    I had to create it from scratch and reboot.
    If ENTRY IS MISSING:
    Goto the folder in the registry
    Right Click  - NEW - STRING VALUE
    Name it exactly as above including CAPS: HungAppTimeout
    Set the value to 20000 (For 20 seconds or more if you need it)
    Reboot Windows.
    After that Printing to PDf with Acrobat works 100%.
    Note this option also helped on my Windows XP PC.
    I hope this prevents others from struggling as much as I did to fogure this out.
    Regards
