whiteshark78
Flash Player 11.4r402 has stopped working
Sep 2, 2012 3:35 AM
Please help.
I've recently insalled the new flash player and have had nothing but problems with it.
Every time I try to view videos or basically do anything I keep getting the message that Flash player has stopped working.
As my technical knoweldge has now run out I'm in need of help to fix the problem.
I'm running 32bit Windows Vista with Mozilla.
Any ideas?
    Calculating status...
    Sep 2, 2012 8:28 AM   in reply to whiteshark78
    Hi
    I had the same problem and was told to
    Stop Trusteer Rapport if you have it running and the problem will go away.
    You can stop and start Rapport by following:
    Start menu -> All Programs -> Trusteer Rapport -> Stop Rapport
    Re-started my computer and the problem is now solved!
    Sep 2, 2012 5:08 PM   in reply to whiteshark78
    1.  Sounds to me like you should keep Rapport.
    2.  I had this same issue with Flash 11.4.  What I did was revert back to 11.3, which worked just fine for me.  Follow the instructions here: http://forums.adobe.com/message/4506372#4506372 and then go to the archive (link on that page) and download this version: (Released 8/14/2012) Flash Player 11.3.300.271 (98.15 MB) [This solved this exact problem for me.]
    Sep 3, 2012 7:07 AM   in reply to whiteshark78
    Oh I dont know im not an expert on computers.
    I did report it to Rapport when i uninstalled it so they might come back with a solution.
    If so ill let u kno.
    Sep 3, 2012 7:15 AM   in reply to mistique247
    I have jst seen replys from another discussion on adobe.com & 1 answer was Rapport knows about it & is sorting the problem.
    http://forums.adobe.com/message/4668269#4668269
    ElbonianKS it says in your answer on the other discussion that you have never used Rapport so mayb thats why yours is working without it?
    Sep 3, 2012 12:46 PM   in reply to mistique247
    Trusteer Rapport can now be re-installed from the link below as given from the other discussion board.x
    https://trusteer.exavault.com/share/view/exo-gvdm939m-6r11kbij
