José L. Martínez Díaz
Black Horizontal line on resized or stabylyzed material
Sep 3, 2012 10:34 AM
I'm conforming a R3D project in 2:40 to 1 and found that with in shoots, appears and horizontal black bar on the lower part of the screen. Seems like some kind of bug, because all of these shots are reframed with the motion controls (resize) or has the warp stabilizer. If I change anything in the motion control, the bar disappears, but appears again in the render or the preview.
Has anybody experienced something like that or found a solution?
Jose
    Sep 3, 2012 11:24 AM   in reply to José L. Martínez Díaz
    What are the exact dimensions of the original R3D files?
    What are the dimensions of the sequence you're working in?
    What changes have you made to the Motion effect?  Scale?  Position?  Both?
    Dec 4, 2012 10:29 PM   in reply to Jim Simon
    Having the same problem. Using Warp Stabilizer in Adobe Premiere CS6. Footage is from Panasonic GH2 (unhacked), AVCHD 1920x1080p24, converted to cineform avi files. 24p. Any setting I do within Warp Stabilizer with Smooth Motion gives the same results.
    Mar 6, 2013 12:13 PM   in reply to José L. Martínez Díaz
    I believe I ran into this issue today. After talking with a support agent, we found out that the resolution in the Sequence settings was @ 720p and my footage was @1080p.  The picture would be fine after the stabilization process but I would get a sizeable black bar at the bottom of the screen after I rendered the video.
    Bottom line: Make sure that your sequence resolution matches the resolution of your footage or is at least larger than your footage resolution.
    To give more background.  I was using PluralEyes to sync the the audio and video.  I haven't figured it out yet but when I imported the .XML into Premiere Pro CS6, the sequence resolution would be set to 720p.  I fixed this by creating another sequence in the project with the proper resolution and basically copied and pasted the footage from the imported sequence into to new sequence.
    Mar 6, 2013 6:31 PM   in reply to roque32
    I did not think it was possible to stabilise footage if it didnt match the edit sequence.
