Premiere Pro CS6 importing .mp4 = "The file has no audio or video streams."
Sep 5, 2012 5:49 PM
Tags: #pro #premiere #import #cs6
When I import an MP4 clip into Adobe Premiere Pro CS6, I get the following message:
"File Import Failure
151_0010_01.mp4
Error Message
I have the latest Quicktime, and I have reinstalled Premiere Pro CS6 a few times already.  If anyone knows a fix for this, I would greatly appreciate it.  My system and clip info are found below.  Thank you, Robert.
OPERATING SYSTEM
Win 7 Ultimate 64bit
CLIP INFO
Complete name                         \BPAV\CLPR\151_0009_01\151_0009_01.MP4
Format                                   : MPEG-4
Commercial name                    : XDCAM EX 35
Format profile                         : Base Media / Version 2
Codec ID                                : mp42
File size                                : 1.76 GiB
Duration                                 : 7mn 5s
Overall bit rate mode                 : Variable
Overall bit rate                         : 35.6 Mbps
Encoded date                             : UTC 2009-07-19 04:22:10
Tagged date                              : UTC 2009-07-19 04:22:10
Video
Format                                   : MPEG Video
Format version                           : Version 2
Format profile                           : Main@High
Format settings, BVOP                    : Yes
Format settings, Matrix                  : Custom
Format settings, GOP                     : M=3, N=15
Codec ID                                 : 61
Duration                                 : 7mn 5s
Bit rate mode                            : Variable
Bit rate                                 : 34.0 Mbps
Maximum bit rate                         : 35.0 Mbps
Width                                    : 1 280 pixels
Height                                   : 720 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 29.970 fps
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Compression mode                         : Lossy
Bits/(Pixel*Frame)                       : 1.231
Stream size                              : 1.68 GiB (96%)
Language                                 : English
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
Audio
Format                                   : PCM
Format settings, Endianness              : Big
Format settings, Sign                    : Signed
Codec ID                                 : twos
Duration                                 : 7mn 5s
Bit rate mode                            : Constant
Bit rate                                 : 1 536 Kbps
Channel(s)                               : 2 channels
Sampling rate                            : 48.0 KHz
Bit depth                                : 16 bits
Stream size                              : 77.9 MiB (4%)
Language                                 : English
