How create indesign using Java Script
Sep 5, 2012 10:36 PM
I am new in indesign and want to create indesign application using JavaScript.
When i use AppleScript to create Indesign Application i use this statement
tell application "Adobe InDesign CS5.5"
set myDocument to make document with properties
end tell
Indesign Application create sucessfully.
How create Indesign Application using JavaScript ?
or what is equivelent statement of ( tell application "Adobe InDesign CS5.5" ) in Java Script.
There are some java scripting example given on forum or in sdk.These all example start with app.
when I debug these java script using ExtendScript ToolKit 3.6 It give error on app (undefined app).I think this app ia application object.
How create  indesign application object  app in javascript ?
While this script run sucessfully when i put these script in C:\Program Files\Adobe\Adobe InDesign CS5.5\Scripts
and to run these script use Scripts panel (choose Window > Utilities > Scripts), then double-click the script name in the Scripts panel in indesign application.But In this case first i start indesign application and then choose Window > Utilities > Scripts then double-click the script name in the Scripts panel.
I want to create Indesign Application (instance) using JavaScript.When I run or (debug) my JavaScript in any javaScript tool like ExtendScript ToolKit 3.6 then Indesign application should start, like in Apple Script.
    Sep 5, 2012 11:28 PM   in reply to Bill joy
    add first line
    #target indesign
    Sep 6, 2012 10:33 PM   in reply to Bill joy
    short story.. NO!
    however, if you run the script from ESTK, you don't need to copy the script in the "Scripts" folder. Don't know exactly if that's what you want.
    Sep 6, 2012 11:10 PM   in reply to Bill joy
    i understand, and the answer is still No, you cannot.
    VB si a windows global scripting language, runed by the os, like applescript. javascript, or more precised jsx is runned by the Adobe application. So, the app needs to be running.
    you can, i think to make a vb script to initialize the aplicattion and then call (still from VB) a javascript. i think. but since i never used vb, i'm not sure.
