Hello,
I use Mandriva Linux 2011 x64 with Firefox 15.0 and latest 64bit flash plugin of version 11.2.202.238. Since flash plugin 11.2.202.233 I have problem with some web sites e.g. "www.shmu.sk" or "www.bsm.sk -> Forum medicum", that if I go to that web page it is displayed correctly but if I press CTRL+T, means to open new empty tab in FF I see one of the flash images from first tab. The same with Opera. Also if I navigate to some web page on this 2nd tab I still see flash from first one on the background. Last version of flash plugin without this bug for me was flash-plugin-11.1.102.63-release.x86_64.rpm. Does anybody observed this problem? Any solution?
Thanks.
sounds like some wmode issue. you could try the following...
as root, create a file mms.cfg in the /etc/adobe directory (you may have to create the adobe directory if it does not exist)
edit the file in vi or similar and add the following line
WindowlessDisable=true
save the changes and restart your browser and try again. does that resolve the issue?
OverrideGPUValidation=1 didn't help. I use latest nvidia graphics card driver 304.43. I found web site http://lists.x.org/archives/xorg-announce/2012-September/002066.html where is written that there is some problem between Adobe and Nvidia regarding flash leak to other widndows and in fact I realized that flash is not leaked only to new tab of FF but also to other white windows. With flash plugin 11.1.102.63 there is no problem also with latest nvidia driver 304.43. So is it possible somehow to change setting in some cfg file which causes flash plugin 11.2.202.238 to behave like 11.1.102.63 regarding this image leaks?
Found solution: http://www.my-guides.net/en/guides/linux/334-how-to-fix-the-leaking-ov erlay-problem-of-flash-and-nvidia
I added to /etc/profile: export VDPAU_NVIDIA_NO_OVERLAY=1
Then I observed flash plugin crashes sometimes, so I unticked "Enable hardware acceleration" in settings when watching youtube video.
North America
Asia Pacific
