CS6 crashes when working on a rotated image
Sep 6, 2012 5:11 AM
Tags: #lion #mac #crash #cs6 #imac #rotate_tool
Quite frequently when I rotate an image with the rotate tool and then work on it, after a while photoshop crashes on me. This never used to happen on CS5.
My setup is iMac12.1, lion 10.7.4
Any suggestions?
    Sep 6, 2012 5:37 AM   in reply to tsader_2012
    Have you tried different Photoshop > Preferences > Performance > Graphics Processor Settings > Advanced Settings?
    Otherwise can you update the Graphics Display Card driver?
    Sep 6, 2012 5:45 AM   in reply to tsader_2012
    And is Photoshop updated to 13.0.1?
    Sep 7, 2012 12:14 PM   in reply to tsader_2012
    It has never happened to me, for sure, but then I severely mistrust the Lions and am running under Snow Leopard 10.6.8.
  • Noel Carboni
    Dec 23, 2006
    Sep 7, 2012 12:20 PM   in reply to tsader_2012
    tsader_2012 wrote:
    I have played with the graphics settings in the preferences but so far no luck. Yes, photoshop is updated to 13.0.1
    Just to be sure, when you made the changes for testing, did you quit and restart Photoshop before trying them?  That's important.
    -Noel
    Nov 25, 2012 12:51 PM   in reply to tsader_2012
    I haven't heard of anyone else with this problem.
    Dec 19, 2012 6:31 PM   in reply to tsader_2012
    What do you have for RAM and graphics card?
    How are you rotating the image?  Is it a whole image flip or a selection rotated?  Or does it make a difference?
  • Noel Carboni
    Dec 23, 2006
    Dec 20, 2012 6:33 AM   in reply to tsader_2012
    Just tested rotating an image and doing various lasso selections here.  No problem found on PC / Windows 7 x64.
    -Noel
    Feb 3, 2013 6:52 AM   in reply to tsader_2012
    I am getting the exact same problem on MacBook Pro 17" on Snow Leopard 10.6.8
    Feb 3, 2013 10:35 AM   in reply to soom1976
    Have you installed all the updates for Photoshop?
    And what does your crash report say?
    Feb 4, 2013 1:40 AM   in reply to Chris Cox
    You are right - I didn't have updates installed. However I only managed to install update 13.0.1, not the the 13.0.4 - it says that it's not applicable. I will try to work now and see how it goes, and will let you know.
    Feb 4, 2013 10:28 AM   in reply to soom1976
    For Macintosh you should be on 13.0.4.
    Feb 5, 2013 4:49 AM   in reply to Chris Cox
    It doesn't work - I cannot install the 13.0.4 update - I've tried to downlaod it manually from adobe website and I tried through Adobe application manager - the first said - update not applicable, the second - that all is up to date...
    But nevertheless, I am working with 13.0.1, and so far no crash
    Feb 8, 2014 2:47 PM   in reply to soom1976
    I am on version 14.2 and mountain lion 10.8.5 on imac and it crashes too from time to time.
    I also experienced this on other systems too, mac pro, macbook pro...
    To me it seems to be bug. Most people I know don't use the rotate tool so I can't really verify what other's experience is
    This is quite a headache to me since I really need to use this tool
  • Trevor Dennis
    May 24, 2010
    Feb 8, 2014 8:43 PM   in reply to bsadr
    I have a vague memory that the Rotate tool uses the GPU.
    Yes, there is a reference to it here:
    http://jaykinghorn.com/2008/11/20/photoshop-cs4-rotate-tool/
    Bonus Tip: In order for the Rotate tool to work correctly, you will need to have a supported graphics card. (No, that first generation iMac isn’t supported.) For more on GPU Acceleration and a link to a list of supported graphics cards, check out my earlier post on the subject.
    So appart from obvious things like using the most up to date driver, it might me worth running through different settings in Preferences > Performance > Advanced.
    Oh, and tell your buddies they are missing out big time if they don't use Rotate
