I am having trouble with footage shot with the Canon C300.
In Premiere, Prelude, & Media Encoder Ingest/Import fails with 'generic error' or 'unable to read xmp'
I can play the footage in Resolve 9, & in VLC.
I have tried transcoding it using Pavtube MXF Converter.
When transcoded to MPEG2 the ingest/import still fails.
When transcoded to WMV it can then be ingested/imported.
Has anyone else experienced this?
Anyone have a solution?
Thank you community :-)
I'm using Cannon .mxf on CS5.03, CS5.5.1, and CS6.02 without issue.
I'm able to import the files through P-Pro media browser in CS 5.5 and CS6.020 and edit natively.
I'm able to inmport the native mxf files and edit in CS 5.03
Adobe bridge and Adobe media encoder can see and employ the files as well.
The camera is an XF100, but I believe that it uses the same XF codec that the C300 uses.
I am running 6.0.2
In Premiere I get the errors "File format not supported" and impressively
vague "The importer reported a generic error".
Thanks for your responses, appreciate it.
It is not a file or codec problem as they play in other software.
I'd love to hear from someone who is shooting C300 & using Prem CS6 so I
know it is specific to my installation.
Mark
I want to murder Google by making it impossible to make a killing off
AdSense. Total Googleplex slaughter!
Well import folder will bring up the File format not supported warning, because there are folder structure and meta info files in there that shouldn't be imported. However, you should be able to import a .mxf, otherwise I'd say your Premiere install is bad.
Of course this is again predicated on the assumption that the XF100 and C300 use the same codec, which I think they do.
Are you using the media browser? Or just the standard import method?
If you're not using the media browser try using it to import your footage and set the media browser to view as "cannon xf".
Here is a link on using the media browser (not the standard import method)
Although if you've already tried this then just disregard my post.
My current work around is to create proxies in PavTube & work off them.
Then I'm going to conform using the original MXF files in Resolve 9 lite.
I haven't done the full trip yet, & my only slight concern is I have frame
rate effects on a few hero shots.
I'll let you know how it goes.
PS even though PavTube is only $30 if u want to avoid the expense just use
it in trial & ignore the watermark, they are only proxies ![]()
Mark
Have you tried a re-install of CS6? Having to transcode files that should play natively is a heck of a problem. I would wipe the system drive and start agian. Contacting Adobe support is also on tap.
This should work; from CS6 white papers:
"Adobe Systems and Canon have collaborated to bring highly e&cient, #le- and tape-based work!ows
to Adobe Premiere Pro CS6 so"ware, giving users the ability to natively edit HD and SD footage shot
with Canon video cameras, including the Canon EOS C300 Digital Cinema camera, Canon XF305/300,
and Canon XF105/100, which record video on solid-state media using the powerful Canon XF
MPEG-2 codec with Full HD 1920x1080 resolution, 50Mbps bit rate, and 4:2:2 color sampling."
I can confirm I've been editing C300 mxf footage successfully. I import files using Media Browser.
CS6.02 (been using Premiere since CS6).
This is on a MacPro 4.1, 2.8Ghz Quad, OS10.6.8, 10Gb RAM, NVidia GTX285, Blackmagic Decklink Studio.
All drivers updated.
Since the upgrade to CS6.02 a few days ago I've experienced some lag when stopping play in the timeline, but this is not confined to Canon C300 files.
theyellowrubberduck wrote:
The footage plays in all non-adobe software such as VLC, GOM, PavTube,
Resolve etc.
Don't think there is a codec problem.
I will install Adobe Media Player & see if it can play though...
Mark
Because it works in a media player does not mean that you don't have a codec conflict. The adobe media player will not solve your issue. It is a discontinued product from adobe that they shelved two years ago. It was a flash player.
Codec packs are notorious for bricking editing systems, while they may or may not affect players. Players and editors can also employ separate decoders for the same codec.
If you know of any 3rd party or shady codec packs added to the system, it might be as simple as uninstalling it. It might be as pervasive as to make you need to wipe your system drive and start from scratch.
This problem has not yet been resolved. Some C-300 files I've been working with were cleared out of a project, and when trying to reimport the .mxf's I get the same, "generic error." Clean install of CS6.0.2, and files should be the same XDCam MPEGs that Premiere natively supports. The files cannot import through the Import function or by Importing through the Media Browser.
Are you using a trial version ?
On Oct 16, 2012 9:08 PM, "Transparency_Bear" <forums_noreply@adobe.com
Deactivate, then reactivate & register your copy.You have to have a
legitimate full licence registered version for mxf compatibility.
On Oct 17, 2012 12:43 PM, "Transparency_Bear" <forums_noreply@adobe.com
Still no solution?
I have the same problem. The strange thing is that I was able to edit the C300 MXF files the first couple of months that I was using the program! But suddenly it stopped working.
The only thing I did was instelling the DNxHD plugin, but It seems strong that it has anything to do with it.
Because it worked before, I have a full sequence with stuff which I have to replace with other footage now (proress's). Not so difficult, but lots of work... ![]()
Cry for help for the Adobe Update team!! Why did it stop working?!
North America
Asia Pacific
