Must restart FB frequently, very slow, stops responding
Sep 11, 2012 6:30 AM
I have to restart FB 4.7 frequently because it slows to a crawl just while editing in the MXML editor (i.e. I type a character, I wait for it to display, I type...I wait, etc).  And, when saving, the compiles are 10 times slower than they were after restarting.
I'm on a new MacBook Pro running Mountain Lion, on 16 GB memory.  I did not have this issue when running FB 4.6 on the same machine.
I have a good size mobile project (approx 8 libraries), but, I'm just making changes on the main project code.  Ugh.
Replies 1 2 Previous Next
    Sep 12, 2012 1:46 AM   in reply to David_Welch
    Can you please give some more details and try these things -
    Are you using an old workspace? If so, can you try on a new workspace.
    Can you tell whether this slowness happens when the project is getting built, i.e., when you see "building workspace" in the FB status bar (bottom right corner)? Or is this slowness observed everytime?
    Try creating a new Flex Project to see whether the issue is observed there.
    Can you try disabling the following and see whether your issue is resolved -
    Window -> Preferences -> Flash Builder -> Editors -> Report problems as you type
    Sameer
    Sep 12, 2012 9:55 AM   in reply to David_Welch
    Can you confirm whether you are working on a new workspace in FB 4.7 or reusing an existing workspace created using older versions of FB?
    Sep 13, 2012 11:24 PM   in reply to David_Welch
    If you are using FB 64 bit version then set xms to 512m and and xmx to 1024m (or more) in FB.ini file and tryout.
    Are you using pure action script or flex as well?. Is there any assets like large images or mp3 files embedded in you app.
    Could you please share the FB log file located under yourFBWorkspace/.metadata/.LOGfile.
    Sep 14, 2012 6:54 AM   in reply to David_Welch
    If you are using standalone version of FB then go to your installation directory
    1.right click on Adobe Flash  Builder 4.7.app and click on show contents
    2.Open Contents folder
    3.Open MacOS folder
    there you find FB.ini folder edit it and set Xms to 512 and Xmx to 1024(or more) then tryout.
    Sep 14, 2012 7:31 PM   in reply to David_Welch
    Go into Applications/Adobe Flash Builder 4.7. Then hold down the control key, and click once on the Adobe Flash Builder 4.7 icon. You should see a menu pop up with a bunch of options, one should be "Show Package Contents". It should open up a new Finder window which had a folder "Contents", open that, then open the "MacOS" folder.
    In mine, I have two files, one is "Adobe Flash Builder 4.7.ini" and "Adobe Flash Builder 4.ini" I would change the Xms and Mxm in both just to be safe
    Oh, and you can use that control key + click option in many programs, or if you have a mouse, there is an option in System Preferences -> Mouse and change the right side to "Secondary Button", and you can now left and right click on the mouse like a PC.
    Sep 17, 2012 3:13 AM   in reply to David_Welch
    You can’t find the ini file by search  in installation directory.
    I just verified "show package contents" on MAC 10.8.1.So it should exist on 10.8.2 as well.
    Please make sure that you are context clicking on "Adobe Flash Builder 4.7.app" file in side Adobe Flash Builder 4.7 installation directory.
    Sep 17, 2012 7:04 AM   in reply to David_Welch
    Can you try creating a new workspace and importing all your projects in it?
    If you encounter issues again, please mail the workspace log to sameer AT adobe DOT com
    Sep 19, 2012 11:05 PM   in reply to David_Welch
    Hi David,
    We studied the logs and most of the references in the logs are pointing to classes that not even present in FB 4.7. That's why I asked you to create a new workspace.
    These classes were, however, present in FB 4.6 and we suspect that somehow 4.6 and 4.7 installations are getting mixed up.
    To diagnose this issue further, can you verify the following -
    1. Whether you have installed FB 4.7 as standalone or plugin over an existing Eclipse installation?
    2. Whether the directories for installating FB 4.6 and 4.7 are different?
    3. Many exceptions in the logs point towards Design View but Design View is removed in FB 4.7. So, in case you see it, can you try disabling it through Windows -> Disable "Design Mode". If you see the Design View option, then there is an installation problem because Design View is removed in FB 4.7
    Thank you again for being patient and providing us the details.
    Sep 23, 2012 10:22 PM   in reply to David_Welch
    Hi David,
    "BootLoader constants: OS=macosx, ARCH=x86, WS=cocoa, NL=en_US"
    Your log shows it is x86 architecture. It should have been x86_64 architecture.
    Log content
    !MESSAGE Commands should really have a category: plug-in='com.qnx.flashbuilder.multiplatform.qnx.ui', id='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.OpenInfoCenter ', categoryId='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.catego ry.help'
    Gives us an indication that your workspace should have been corrupted. Since above plugins should not be available in FB 4.7
    You can go to <FB Install dir>/Adobe Flash Builder 4.7.app/Contents/MacOS from the command line to get the contents of Flash builder.ini
    Regards,
    Kishan
    Sep 23, 2012 11:21 PM   in reply to Kishan M V
    Could you please share your log file again.
    Please delete the existing log contents in  yourWorkspaceLocation/Adobe Flash Builder 4.7/.metadata/.log
    Try to reproduce the stability issues and copy the log contents from yourWorkspaceLocation/Adobe Flash Builder 4.7/.metadata/.log file.
    Send the log file to mail ID sjavvadiATadobeDOTcom
    Satya J
    Sep 25, 2012 10:50 PM   in reply to David_Welch
    David,
    Could you please relpy to the mails I have sent to your mail ID.
    Sep 26, 2012 9:11 PM   in reply to David_Welch
    David,
    I resend the mails to you, are you able to receive the mails from our side?
    Is it possible to share your project to reproduce the issue.
    Else, Can we setup a connect session to troubleshoot the issue.
    Please let us know your location/time zone and convenient time.
    Dec 10, 2012 5:02 AM   in reply to David_Welch
    I have this same issue. Everything works fine by about half hour and then just hovering the mouse cursor top of the toolbar buttons will make cpu usage jump to 40% and UI-does not update for awhile. Memory usage is this point something like 1,5GB which is double amount compared to 4.6.
    I had these setting already in the ini files
    -Xms512m
    -Xmx1024m
    I didn't have any this kind of issues with 4.6.
    Dec 10, 2012 10:15 PM   in reply to Ossi R
    Hi Ossi,
    Do help us to investigate your problem further by answering followign questions to beign with.
    1.  What is the OS type and RAM capacity of your machine ?  Is it same kind of machine as mentieond by David on this thread ?
    2.  Are you usign older workspace(prior to 4.7) with FB4.7 or have you created a new one ?
    3.  What is the type of project that you are workgin with ? Is it Flex or Pure actionScript one ?
    4.  Also, what is the overall size of your peojcts including assets etc. ?  If you project is bigger to get accomodated by 1024 heap size, you may want to increase it further, to find an optimal performance for your project.
    5. Post any logs from your Eclipse workspace, that may help us look into what may be going wrong at your end.
    Jayesh
    Dec 11, 2012 12:03 AM   in reply to Jayesh Viradiya
    System Information
    Operating System: Windows 8 Pro with Media Center 64-bit (6.2, Build 9200) (9200.win8_gdr.121023-1503)
    Language: Finnish (Regional Setting: Finnish)
    BIOS: BIOS Date: 12/14/10 15:27:28 Ver: 08.00.15
    Processor: Intel(R) Core(TM) i5 CPU         760  @ 2.80GHz (4 CPUs), ~2.8GHz
    Memory: 8192MB RAM
    Available OS Memory: 8190MB RAM
    Page File: 3347MB used, 6746MB available
    DirectX Version: DirectX 11
    DX Setup Parameters: Not found
    System DPI Setting: 96 DPI (100 percent)
    I created a completely new worksapce and then imported FB4.6 project into it.
    Currently I have 7 projects within my workspace. I got both types Flex and Pure actionscript ones.
    287MB
    !SESSION 2012-12-10 15:06:32.119 -----------------------------------------------
    eclipse.buildId=M20110909-1335
    java.version=1.6.0_31
    java.vendor=Sun Microsystems Inc.
    BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
    Command-line arguments:  -os win32 -ws win32 -arch x86_64
    !ENTRY org.eclipse.jface 2 0 2012-12-10 15:07:10.509
    !MESSAGE Keybinding conflicts occurred.  They may interfere with normal accelerator operation.
    !SUBENTRY 1 org.eclipse.jface 2 0 2012-12-10 15:07:10.509
    !MESSAGE A conflict occurred for CTRL+SHIFT+F:
    Binding(CTRL+SHIFT+F,
              ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.organize .autoformat,Apply Formatting,
                        Category(com.adobe.flexbuilder.as.editor.source.editing.category,Acti onScript Source Editing,null,true),
                        LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.mxml. editor.code.ui.actions.MXMLFormatterAction@5383c2d9)),
                        ,,true),null),
              org.eclipse.ui.defaultAcceleratorConfiguration,
              com.adobe.flexide.editorcore.flexEditorScope,,,system)
              ParameterizedCommand(Command(FlexPrettyPrintFormat.commands.addons.fl exbuilder,Format MXML/ActionScript,
                        Format Adobe MXML or ActionScript code.  Format the selected lines or the entire document if there is no selection.,
                        Category(FlexPrettyPrintCommand.commands.category,Flex,null,true),
                        flexprettyprint.handlers.FlexPrettyFormatHandler@6f6d5f64,
                        ,,true),null),
    !ENTRY org.eclipse.jface 2 0 2012-12-10 15:07:10.664
    !SUBENTRY 1 org.eclipse.jface 2 0 2012-12-10 15:07:10.664
    !MESSAGE A conflict occurred for CTRL+G:
    Binding(CTRL+G,
              ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all .declarations.in.workspace,Find All Declarations In Workspace,
                        Category(com.adobe.flexbuilder.editorcore.navigation.category,Navigat ion,null,true),
                        LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.ed itor.ui.actions.FindAllDeclarationsAction@4132f0f5)),
                        ,,true),null),
    Binding(CTRL+G,
                        ,,true),null),
              com.adobe.flexbuilder.as.editor.context.packageexplorer,,,system)
    Binding(CTRL+G,
              ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.java.search .declarations.in.workspace,Declaration in Workspace,
                        Search for declarations of the selected element in the workspace,
                        Category(org.eclipse.search.ui.category.search,Search,Search command category,true),
                        ,,true),null),
              org.eclipse.ui.contexts.window,,,system)
    !MESSAGE A conflict occurred for CTRL+SHIFT+G:
    Binding(CTRL+SHIFT+G,
              ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all .references.in.workspace,Find All References In Workspace,
                        LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.ed itor.ui.actions.FindAllReferencesAction@77698643)),
                        ,,true),null),
                        ,,true),null),
              ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.java.search .references.in.workspace,References in Workspace,
                        Search for references to the selected element in the workspace,
                        ,,true),null),
    !ENTRY org.eclipse.jface 2 0 2012-12-10 15:35:29.044
    !SUBENTRY 1 org.eclipse.jface 2 0 2012-12-10 15:35:29.044
    !MESSAGE A conflict occurred for F5:
    Binding(F5,
              ParameterizedCommand(Command(com.adobe.flexbuilder.dcrad.commands.Key AssociationCommand,KeyAssociationCommand,
                        Category(com.adobe.flexbuilder.dcrad.commands.KeyAssociationCategory, KeyAssociationCategory,null,true),
                        com.adobe.flexbuilder.dcrad.handlers.KeyBoardCommandHandler,
                        [Lorg.eclipse.ui.internal.commands.Parameter;@547a79cf,,true),[Lorg.e clipse.core.commands.Parameterization;@150c44c3),
              com.adobe.flexbuilder.dcrad.keybindings.contexts.refresh,,,system)
    Binding(F5,
              ParameterizedCommand(Command(org.eclipse.debug.ui.commands.StepInto,S tep Into,
                        Step into,
                        Category(org.eclipse.debug.ui.category.run,Run/Debug,Run/Debug command category,true),
                        ActionDelegateHandlerProxy(null,org.eclipse.debug.internal.ui.command s.actions.StepIntoCommandActionDelegate),
                        ,,true),null),
              org.eclipse.debug.ui.debugging,,,system)
    Binding(F5,
              ParameterizedCommand(Command(org.eclipse.ui.file.refresh,Refresh,
                        Refresh the selected items,
                        Category(org.eclipse.ui.category.file,File,null,true),
                        ,,true),null),
    !SESSION 2012-12-11 09:51:39.798 -----------------------------------------------
    !ENTRY org.eclipse.jface 2 0 2012-12-11 09:52:01.475
    !SUBENTRY 1 org.eclipse.jface 2 0 2012-12-11 09:52:01.475
                        LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.mxml. editor.code.ui.actions.MXMLFormatterAction@19c0c6eb)),
                        ,,true),null),
                        flexprettyprint.handlers.FlexPrettyFormatHandler,
                        ,,true),null),
    !ENTRY org.eclipse.jface 2 0 2012-12-11 09:58:40.102
    !SUBENTRY 1 org.eclipse.jface 2 0 2012-12-11 09:58:40.103
    Binding(CTRL+G,
                        LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.ed itor.ui.actions.FindAllDeclarationsAction@454a77c8)),
                        ,,true),null),
    Binding(CTRL+G,
                        ,,true),null),
    Binding(CTRL+G,
                        ,,true),null),
                        LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.ed itor.ui.actions.FindAllReferencesAction@1bfe0f02)),
                        ,,true),null),
                        ,,true),null),
                        ,,true),null),
    Dec 12, 2012 5:29 PM   in reply to David_Welch
    I am having this very same issue on Windows 7 Flash Builder 4.7 -- Every 10-15 minutes I have to restart the program because it slows down to a crawl.  Typing is nearly impossible.  I tried every fix mentioned above to no avail.  Some suggestions would be greatly appreciated.  Thanks all!
    Dec 13, 2012 1:45 AM   in reply to imakeinternet.com
    Today I tried this with my older MacBook and it does exactly same thing.
    Half our and then FB starts to slow down. Typing is impossible
    I remember that 4.6 did this same slow down when the Design View was enabled.
    Dec 13, 2012 4:11 AM   in reply to Ossi R
    Hi Ossi,
    Can you send the heap dump just when the editor tends to get slow as you mentioned?
    Also which jdk are you on?
    For getting the heap dump, get the PID of FlashBuilder from Task Manager.
    Go to command prompt and change directory to your jdk location > bin folder, (your bin folder would be having jmap.exe)
    Type the below command :
    jmap -dump:format=b,file="C:\heap.txt" <pid>
    Send the generated heap.txt file to gkalyaniATadobeDOTcom
    Regards,
    Guriya
    Dec 18, 2012 2:48 AM   in reply to Guriya Kalyani
    Sorry for the delay, but the file is so HUGE that I'm unable to send it through email (2,25GB).
    Dec 18, 2012 9:58 PM   in reply to Ossi R
    Hi Ossi,
    Can you try zipping it first and then uploading it to say dropbox ?
    Jan 4, 2013 4:03 PM   in reply to imakeinternet.com
    I am having the exact same issues here.  Having to reboot FB4.7 several times.  FB ini is already set to recommended settings.  Please advise.  Performance is awful with FB 4.7
    Jan 6, 2013 10:26 AM   in reply to Cyclex
    Has any progress been made on this issue? I have the exact same problem, on both my laptop and desktop.
    • Both my computers run Mac OS X 10.8.2 .
    • Both my computers have 8 GB RAM.
    • I have created a new workspace with FB 4.7 .
    • I have only 3 opened (and linked) projects in the workspace. Two of the projects are Flex Library projects and the third is the Flex Application (SDK 4.8) (not pure ActionScript). All three projects put together is less than 3 MB in size.
    • I am running JDK 7 update 9.
    I did not have these problems in FB 4.6 . The overall performance of the IDE itself is very very slow. It is extremely annoying to keep having to restart the IDE every half hour or so.
    The performance problems are separate from the other bugs in the IDE: In MXML files, anything defined in the <fx:Declarations> is not recognized by the code outside the declarations. Compiling is fine, but "command-clicking" on any reference to the declared variable does not go to the declaration of the variable. The same is seen for the <fx:Script source="..." /> included files.
    I am seriously considering reverting back to 4.6 or to switch to JetBrains IDEA.
    Jan 6, 2013 9:46 PM   in reply to t_anjan
    Could you please let us know the heap utilized in Flash Builder while you face this problem.
    You can enable this settings from Windows->Preferences->General->Show Heap Status.
    Could you please try increasing the default max heap size (xmx) from 1024 to 2048.
    You can find these settings under Flash Builder Installation folder /FlashBuilder.ini file.
    If you have plugged-in FB to external eclipse then you need to update heap settings in eclipse.ini file.
    Jan 6, 2013 10:31 PM   in reply to Satya Krishna Javvadi
    This clearly helped on my Windows computer with 8 gigabytes of memory, but with Mac (4GB) it didn't really have any effect.
    Jan 6, 2013 10:38 PM   in reply to Satya Krishna Javvadi
    I have done this in both "Flash Builder.ini" and "Flash Builder 4.7.ini" in the "Contenets/MacOS" folder inside the FB app.
    I am yet to use the app heavily since. I will report back.
    The Heap Status currently fluctuates between  "150M of 529M" and "175M of 529M", as soon as I open the app. Even now, the performance of the IDE within the MXML files and its associated *.as files is quite laggy.
    Jan 8, 2013 4:00 PM   in reply to Satya Krishna Javvadi
    I've increased head size to 2048 and still experiencing poor performance with FB 4.7.  Actually the application is crippled within a few minutes.  Watching the heap status, it starts out around 100M of 300M then after a few minutes of developing the status changes to about 920M out of 1000M.  Having to restart FB 4.7 every few minutes is unacceptable.
    Please advise, thank you.
1 2 Previous Next
Actions
