adob357
How do I keep illustrator from doing unwanted snapping?
Sep 11, 2012 9:51 AM
Tags: #illustrator #problem #cs6 #snap
I have been experiencing the problem of elements not aligning properly.
I will try to do a fine tune alignment manually, however, I have discovered that the program does not allow me to accurately align any elements. They all seem to snap off alignment by 0.5 point/pixel.
I tried to turn off snapping at all levels, however, it still continues to misbehave. Perhaps I missed a switch somewhere.
I do not remember other versions of the program acting this way, so, it seems unusual.
Is there a way to around this, or is there some hidden control to fix this problem?
Thank you for your input.
    Sep 11, 2012 9:53 AM   in reply to adob357
    Is Align to Pixel Grid turned on? Look in the Transform panel and click it off.
    Sep 11, 2012 9:58 AM   in reply to adob357
    In the transform panel flyout menu uncheck the option for Align New Objects to Pixel Grid. Additionally, select any objects you already have on your artboard and in the Transform menu uncheck Align to Pixel Grid.
    When you started your project you might have chosen the Web preset, in which case the option becomes automatically selected.
    Hope this helps!
    Michael
    Feb 9, 2013 5:38 PM   in reply to adob357
    Is there any way to change this default after the document was created? We have a few documents that must have had "align to pixel grid" set when created but was an oversight... I suppose a workaround is to create a new document and copy all the contents from one to another, but that workaround can get arduous if there are many layers and layer effects.
    Feb 9, 2013 7:54 PM   in reply to viveredesign
    If you're having trouble when you copy layers from one file into another, ie the layers all collapse into layer 1 of the new file, just turn on "paste remembers layers" from the layers flyout menu. Then when you paste all of the layers will come over intact.
    Hope that helps,
    Michael
    http://www.learnadobesoftware.com
    Nov 12, 2013 11:17 AM   in reply to viveredesign
    To enable or disable this option in an already-created document, you toggle the setting in the Transform palette's flyout menu, "Align New Objects to Pixel Grid"
    Dec 19, 2013 8:51 AM   in reply to mjarrott
    Is there any way to change the web preset so you don't automacitally have "align to pixel grid" selected on any new document?
    Dec 19, 2013 9:24 AM   in reply to Jfavero
    edit the new document profile
    http://blogs.adobe.com/adobeillustrator/2009/05/startup_profiles_a_gre at_tool.html
