• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Adobe Flash Player 11.4 installation via SCCM(Batch File)
New Here ,
Sep 11, 2012 Sep 11, 2012
Hi Guys,
I need to install Adobe Flash Player 11.4 on 150+ Computers via SCCM
I am trying to run batch file in SCCM but doesn't work.
It says Program has started in reporting but nothing happens and eventually failed saying -> run time exceeded
SCCM program-> i m just calling ->
commandline --> flashinstall.bat
my code in batch file is,
@echo off
start \\sms01\source$\Adobe Flash Player 11.4.402.265\IE\flashplayer_11_ax_debug.exe /silent
start \\sms01\source$\Adobe Flash Player 11.4.402.265\Other Browser\flashplayer_11_plugin_debug.exe /silent
xcopy /y /q /s "\\sms01\source$\Adobe Flash Player 11.4.402.265\mms.cfg" "C:\windows\System32\macromed\flash\"
EXIT
Can you please help me out regarding how to run batch file in sccm
TOPICS
Ad development
Views
31.8K
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here ,
Sep 24, 2012 Sep 24, 2012
OK , I just deployed flash player here and it ran like a charmy .
1 - Download the last version of flash ( msi )
- Go to this URL and Download the msi file : http://www.adobe.com/au/products/flashplayer/distribution3.html
2 - Create a "install.cmd" file  .
   - Create a folder , place the flash player msi file there ( install_flash_player_11_plugin.msi) . Inside this folder , create a file with the name "install.cmd" . Open this file and add the follow lines  :
msiexec /qn /norestart /i "%~dp0install_flash_player_11_plugin.msi"
exit /B %EXIT_CODE%
Salve and close the file .
I assume that you know how to create a package  / program .
3 - Create a new package
   - After create the packge , create a new program for the package . In command line field , click in browse , make sure that you list "all files (*.*)" and click at install.cmd . Select the msi file (install_flash_player_11_plugin.msi) on "Windows Installer" option  . also , make sure that "Run with administrative rights" is selected on "Environment" .
Thats  should be enough , let me know how it go .
Cheers ,
Votes
Translate
Translate
Report
Report
Community Beginner ,
Mar 07, 2013 Mar 07, 2013
LATEST
Hi harsh5094,
Did you ever get this working. I am looking for the same thing.
GuillyAU gives me some ideas, but still does not do exactly what you asked.
I would like a single command or batch file that will install both the Active X and Plugin versions of Flash Player (exe or msi - whichever works best), and also copy the mms.cfg file to the destination PCs (If not already there).
I was also going to copy the mms.cfg file to both 32-bit and 64-bit directories, instead of just the 32-bit one you mentioned in the OP.
Currently I have a separate Package for the Plugin and Active X installers, and deploy the mms.cfg file through GPO.
It would be good to have it all install in the single package.
I could possible even include AIR and Shockwave in the same script.
Votes
Translate
Translate
Report
Report
