Eric_Knopp
Title Editor - Logo Transparency Problem
Sep 12, 2012 2:29 PM
Tags: #transparency #pp #logo #title #psd #title_editor #title_graphic
Hi folks. Been lurking for a  while, but my first real headache has arrived. I did a search but didn't find anything helpful.
I have a project in Premiere Pro CS6 (6.0.0), and I created a title graphic (background image for the names of people being interviewed) in PS CS6 Extended (13.0 x 64). The client would like a portion of the title graphic to be more transparent.
That's easy. I went into PS, reduced the transparency of those particular layers to 76% and resaved it as a PSD file.
Here's where it gets weird: when I import the new file as a logo in the Title window (Title > Logo > Insert Logo), the layers on which I reduced the opacity refuse to display. The company logo (transparency untouched) is there, but the rest does not display.
When I import the merged PSD file/image onto the timeline in PP, though, the whole graphic shows up perfectly, with the desired areas being more transparent.
Any ideas why the transparency change is resulting in a total loss of the layers when imported into the Title editor?
I have tried everything I can think of, including exporting as PNG-24, and a crappy looking GIF to preserve the transparency, but those have the same problem. I can of course, export to JPEG, but then I lose the transparency.
Any ideas?
Many thanks.
-Eric
    Sep 12, 2012 4:40 PM   in reply to Eric_Knopp
    Save a copy without layers. After you import the file into title maker, make sure that there are no shadows or strokes applied to it.
    Sep 12, 2012 4:58 PM   in reply to Eric_Knopp
    Create a new PSD matching your sequence properties.  PS now has some video presets just for the task.  Be sure to make the background transparent.  Create yourself a 'title template' right there in PS and bring that into PP.  Use it as a background under your titles.
    Nov 16, 2012 2:55 PM   in reply to Eric_Knopp
    It looks like there is something, like a Garbage Mask, that is cutting off the right-hand portion of the PSD.
    Though it was done in an earlier version, here is a similar Lower-Third with a charity's logo, and a gradient, that was placed over Video with a Title (for the Text) above it. The Transparency came through, just as designed:
    That Lower-Third was created in PS, using the 720 x 480 Preset, on a Transparent background, then just Imported into PrPro as Footage, where it was used in conjunction with a Text Title.
    Other than something, like Garbage Matte, or the Crop Effect, I cannot imagine what is killing your Gradient.
    Nov 17, 2012 10:40 PM   in reply to Bill Hunt
    I can do what Bill did using a gradient. Unfortunately, I am not much of a Photoshop guy, and I can't figure out how to use a gradient on a texture - and I think that is what was done on Eric's lower third.
