GG-Devious
Illustrator CS6 has stopped working on Exit....
Sep 16, 2012 9:01 PM
Tags: #illustrator #problem #error #bug #cs6
Everytime I go to close Illustrator down, no matter the method. I get a message that Illustrator has stopped working and has to be forcefully closed.  This happens any time I close Illustrator.  I even uninstalled the entire CS6 package, cleared the registry settings, and erased all the files, and did a complete reinstall of Illustrator CS6 only, and I still get the same error. No plug-ins running or anything...   Help...
Running Windows 7 64-bit Ultimate, AMD Athlon FX 8 Core, 3.96ghz.  16GB DDR3 1600 ram, 6 1TB drives, 3 virtual drive ( each drive is mirrored).  Everything else runs rock solid without any issues at all. Just Illustrator acts oddly on shutdown.
    Sep 17, 2012 6:32 AM   in reply to GG-Devious
    YOu may have a permissions problem with your illustrator prefs file which is updated at .ai shutdown. Check you premissions.
    Dec 18, 2012 10:40 AM   in reply to GG-Devious
    I've been having the same issue, and I keep hoping since I'm using the Cloud they'll fix it.
    Note:
    1. Everything has been unisnstalled and reinstalled 3 times.
    2. All permissions have always looked okay.
    3. Illustrator has been the only program to have this issue.
    Mar 4, 2013 3:31 PM   in reply to GG-Devious
    Same issue here.
    Running Window 7 64-bit. Also uninstalled and reinstalled with no avail.
    Also just Illustrator with this problem.
    Can't seem to find solution...
    Apr 7, 2013 4:52 AM   in reply to GG-Devious
    I also have the same issue with Adobe Illustrator CS6. I am running Windows 7 64 bit with 16 Gig of RAM.
    I am also tried uninstalling and reinstalling the program without any change in the error message.
    Illustrator is the only application in the Creative Cloud that is malfunctioning like this.
    @ADOBE -   PLEASE FIX
    May 9, 2013 9:39 AM   in reply to GG-Devious
    Agree on this only Illustrator and always on shutdown, none of the other CS programmes do this and I use most of them!
    Have gone round and round with the permissions etc. and find no problem.
    ADOBE if this was a permissions issue then would likely fail in other CS programmes... It is an Illustrator issue, please put an update on the Cloud!
    May 9, 2013 11:13 AM   in reply to SteveU_12
    I also get "Illustrator Has Stopped Working" everytime I not only close but when I open a file or try to add any 3D effects. I am running Windows 8. None of the other Creative Cloud products are acting this way. I have uninstalled and reinstalled.
    Nov 29, 2013 6:44 AM   in reply to GG-Devious
    Has this been resolved yet?
    I have the exact same problem with Illustrator CS6 - i have tried both 32 and 64 version - same thing happens
    - does this do it with Illustrator CC anyone know, is it worth for me to download/install that
    i have Illustrator CS5.1 and it does not have this problem
    I am on PC / Windows 7 64bit  //
    Jan 9, 2014 8:06 AM   in reply to Firdaus_Emir
    This worked for me!
    It is related with TeamVIewer
    LINK:
    http://forums.adobe.com/message/4661721
    (scroll down to: FINALY A FIX)
