Why is Adobe Flash CS6 crashing sporadically when resizing MC's or shapes?
Sep 17, 2012 10:26 AM
Tags: #flash #mac #crash #cs6
It doesn't happen all the time but when Flash crashes, it happens when i'm resizing a symbol or a shape.
I'm using Flash CS6 v 12.0.0.481
Processor  2.7 GHz Intel Core i7
Memory  8 GB 1333 MHz DDR3
Graphics  AMD Radeon HD 6630M 256 MB
Software  OS X 10.8.1 (12B19)
-Line
    Sep 18, 2012 12:42 AM   in reply to Line
    1. Could you please explain the type of MC  you are using (whether its includes bitmap or drawing etc...).
    2. In shapes, what type of shapes you using (Primitive  drawing object or Normal drawing objects like circle or stroke etc...)
    Sep 20, 2012 10:21 PM   in reply to Line
    could you please share one file.
    Sep 26, 2012 10:57 PM   in reply to Line
    How exactly are you resizing?
    Here're the kinds of resizing I tried with your FLA and Flash Professional CS6 didn't crash on my system:
    • Individually resize each object on stage using the sub-selection tool.
    • Individually resize each object on stage using the free-transform tool.
    • Select all objects on stage and resize them as a group
    I tried saving the file, reopening it, and repeat the above mentioned resizing scenarios - Flash CS6 didn't crash.
    So, could you please let us know the exact steps you follow to resize?
    Regards,
    Suhas Yogin
    Dec 11, 2012 2:41 AM   in reply to Suhas Yogin
    Hi everybody,
    i got the same problem here. To reproduce this, scale using the shortcut 'alt + cmd + s'.
    This happens almost always, after i entered a number und pressed enter, the beach ball comes up and flash crashes.
    Best Regards
    Dec 21, 2012 6:32 AM   in reply to JYRF
    It happens because Adobe decided to release a crappy product. CS6 sucks in general. I have constant crashes when working with lines or shapes. It was a problem in the past, but seems to be much worse at least with my install. Others here at work dont have it so bad.
    Oh yeah, my keyboard shortcuts stop working every so often... Others here at work have the same issue. I am going to ask to be DGed to 5.5
    If anyone at Adobe reads this:
    For Gods sake! I know you run a business, and dont need to fix all the things that are wrong, but just out of human compassion, please?
    Jan 11, 2013 6:22 AM   in reply to Line
    This happens to me VERY often (like 8 or more times a day). Totally sucks, especially when I haven't had a chance to save. A numeric scale will crash when scaling anything (like mentioned above, using the shortcut ALT-CMD-S). Happens about 50% of the time for me.
    This seems to be a very specific bug. Hopefully Adobe sees this and fixes it.
    Jan 14, 2013 3:44 PM   in reply to Suhas Yogin
    Same issue on two different Macs, multiple different Flash docs. Currently just installed a new iMac Quadcore with 16G of RAM and a 1TB Fusion drive. Fresh install of CS6 and it still happens evey 4-5 times I use that menu item (Command Shift S). I only use Graphics, not MovieClips. Small vector objects (30x40 pixels) Single color RGB builds created in Illustrator CS6.
    I'm losing tons of productivity here Adobe. Not exactly why I pay all this money for your upgrades. Fix. It. Now.
    Mar 8, 2013 2:09 PM   in reply to mightyfudge
    I just waisted 6 hours working on a file. I was saving every 5 minutes and then on one save, it froze. The file was corupted, and all the work is lost. Seriously? I just started on a new project for the Navy, was the first to be "upgraded" to CS6 and our team required that we all use the same version, so I cant down grade. Every project gets locked into a certain version so that there are no comaptibility issues... However, the problems that I and my co-workers have had with CS6 has made me decide that I am going to tell my boss that we should suspend all upgrades of CS6 for any other projects.
    I cannot express how pissed off I am right now.
    And it doesnt matter what kind of shapes I was working with,  or how I resize. There is a problem, and it needs to be fixed.
    Mar 18, 2013 1:22 PM   in reply to Line
    I'm going to add my voice to this bug report. Adobe Flash CS6 crashes sporadically for me (numerous times per day), and it's almost always when I am editing a vector shape control point using the subselection tool. If I select a control point and nudge it with the keyboard arrow keys, I haven't encountered a problem. But if I select a control point, then click and drag it to reposition it, I often get the spinning wheel followed by a crash. Is this really a bug or a problem related to my own hardware/software configuration?
    I am working on a Mac Pro with 2 x 2.66 GHz 6-Core Intel Xeon processors, 24GB RAM running OS X 10.7.5. Here is the crash report from the most recent crash (about 10 minutes before I posted this):
    Process:         Adobe Flash CS6 [1424]
    Path:            /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/MacOS/Adobe Flash CS6
    Identifier:      com.adobe.flash
    Version:         12.0.2.529 (12.0.2)
    Code Type:       X86 (Native)
    Parent Process:  launchd [153]
    Date/Time:       2013-03-18 16:10:30.795 -0400
    OS Version:      Mac OS X 10.7.5 (11G63)
    Report Version:  9
    Crashed Thread:  0  Dispatch queue: com.apple.main-thread
    Exception Type:  EXC_BAD_ACCESS (SIGBUS)
    Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000014
    VM Regions Near 0x14:
    --> __PAGEZERO             0000000000000000-0000000000001000 [    4K] ---/--- SM=NUL  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/MacOS/Adobe Flash CS6
        __TEXT                 0000000000001000-0000000001b83000 [ 27.5M] r-x/rwx SM=COW  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/MacOS/Adobe Flash CS6
    Application Specific Information:
    objc[1424]: garbage collection is OFF
    Java information:
     Exception type: Bus Error (0xa) at pc=000000009c28de16
     Java VM: Java HotSpot(TM) Client VM (20.14-b01-445 mixed mode macosx-x86)
    Current thread (000000002b04fc00):  JavaThread "main" [_thread_in_native, id=-1407053120, stack(00000000bf800000,00000000c0000000)]
    Stack: [00000000bf800000,00000000c0000000]
    Java Threads: ( => current thread )
      00000000638b6000 JavaThread "Code Model Worker" daemon [_thread_blocked, id=-1283768320, stack(00000000b36b4000,00000000b37b4000)]
      00000000638b5800 JavaThread "Code Model Worker" daemon [_thread_blocked, id=-1284825088, stack(00000000b35b2000,00000000b36b2000)]
      000000006605d000 JavaThread "FelixPackageAdmin" daemon [_thread_blocked, id=-1285881856, stack(00000000b34b0000,00000000b35b0000)]
      000000006605c800 JavaThread "FelixStartLevel" daemon [_thread_blocked, id=-1286938624, stack(00000000b33ae000,00000000b34ae000)]
      000000002b44e400 JavaThread "FelixDispatchQueue" [_thread_blocked, id=-1287995392, stack(00000000b32ac000,00000000b33ac000)]
      000000002b405000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=-1290108928, stack(00000000b30a8000,00000000b31a8000)]
      000000002b404000 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=-1291165696, stack(00000000b2fa6000,00000000b30a6000)]
      000000002b403000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=-1292222464, stack(00000000b2ea4000,00000000b2fa4000)]
      000000002b402000 JavaThread "Surrogate Locker Thread (Concurrent GC)" daemon [_thread_blocked, id=-1293279232, stack(00000000b2da2000,00000000b2ea2000)]
      000000002b3fa000 JavaThread "Finalizer" daemon [_thread_blocked, id=-1294336000, stack(00000000b2ca0000,00000000b2da0000)]
      000000002b3f9000 JavaThread "Reference Handler" daemon [_thread_blocked, id=-1295392768, stack(00000000b2b9e000,00000000b2c9e000)]
    =>000000002b04fc00 JavaThread "main" [_thread_in_native, id=-1407053120, stack(00000000bf800000,00000000c0000000)]
    Other Threads:
      000000002b3f6400 VMThread [stack: 00000000b2a9c000,00000000b2b9c000] [id=-1296449536]
      000000002b406800 WatcherThread [stack: 00000000b31aa000,00000000b32aa000] [id=-1289052160]
    VM state:not at safepoint (normal execution)
    VM Mutex/Monitor currently owned by a thread: None
    Heap
     par new generation   total 14784K, used 6310K [00000000569d0000, 00000000579d0000, 00000000579d0000)
      eden space 13184K,  42% used [00000000569d0000, 0000000056f42ab0, 00000000576b0000)
      from space 1600K,  45% used [0000000057840000, 00000000578f7088, 00000000579d0000)
      to   space 1600K,   0% used [00000000576b0000, 00000000576b0000, 0000000057840000)
     concurrent mark-sweep generation total 49152K, used 0K [00000000579d0000, 000000005a9d0000, 000000005e9d0000)
     concurrent-mark-sweep perm gen total 12288K, used 6704K [000000005e9d0000, 000000005f5d0000, 00000000629d0000)
    Code Cache  [00000000549cf000, 0000000054a80000, 00000000569cf000)
     total_blobs=279 nmethods=150 adapters=73 free_code_cache=32844480 largest_free_block=0
    Virtual Machine Arguments:
    JVM Args: -Djava.awt.headless=true -Xmx128m
    Java Command: Launcher Type: generic
    Physical Memory: Page Size = 4k, Total = 24576M, Free = 17592186043894M
    Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
    0   com.apple.CoreFoundation           0x9c28de16 blockForLocation + 6
    1   com.apple.CoreFoundation           0x9c28ddeb CFRunArrayGetValueAtIndex + 27
    2   com.apple.CoreFoundation           0x9c28ddc6 CFAttributedStringGetAttributes + 182
    3   com.apple.CoreText                 0x98c9fdc9 TTypesetterAttrString::Initialize(__CFAttributedString const*) + 217
    4   com.apple.CoreText                 0x98c9f9d9 CTLineCreateWithAttributedString + 47
    5   com.apple.HIToolbox                0x92854029 TCoreTextEngine::LayoutSingleLine(THIThemeTextInfo*, float) + 23
    6   com.apple.HIToolbox                0x92853f96 TCoreTextEngine::Layout(THIThemeTextInfo*, float, float, TextLayoutType) + 64
    7   com.apple.HIToolbox                0x9282e761 TCoreTextEngine::VerifyLayout(THIThemeTextInfo*, float, float, LayoutIntent) + 309
    8   com.apple.HIToolbox                0x928920e2 TCoreTextEngine::GetThemeTextDimensions(float, THIThemeTextInfo*, float*, float*, float*) + 54
    9   com.apple.HIToolbox                0x92892dfc TCoreTextEngine::TruncateThemeText(short, unsigned long, __CFString const**, unsigned char*) + 140
    10  com.apple.HIToolbox                0x92890f53 DataEngine::TruncateText(__CFString const*, HIThemeTextInfo*, short, __CFString const**, unsigned char*) + 145
    11  com.apple.HIToolbox                0x9287ba82 TruncateThemeText + 232
    12  com.adobe.flash                    0x00f8fb4e CDialogViewImpl::SetWindowText(unsigned short const*) + 40722
    13  com.adobe.flash                    0x00f906ef CDialogViewImpl::SetWindowText(unsigned short const*) + 43699
    14  com.adobe.flash                    0x00f91cf8 CDialogViewImpl::SetWindowText(unsigned short const*) + 49340
    15  com.adobe.flash                    0x00f9338f CDialogViewImpl::SetWindowText(unsigned short const*) + 55123
    16  com.apple.HIToolbox                0x92942a14 TBrowser::Draw(unsigned long, unsigned long, unsigned long, Rect const&, short, bool, TDeviceRenderer::Context const&) const + 620
    17  com.apple.HIToolbox                0x929427a3 non-virtual thunk to TBrowser::Draw(unsigned long, unsigned long, unsigned long, Rect const&, short, bool, TDeviceRenderer::Context const&) const + 71
    18  com.apple.HIToolbox                0x9295f7f3 TTableCell::Draw(unsigned long, TDeviceRenderer::Context const&) const + 1307
    19  com.apple.HIToolbox                0x9295a373 TTableView::DrawCell(TTableCell const&, unsigned long, TDeviceRenderer::Context const&) const + 95
    20  com.apple.HIToolbox                0x92962862 TListView::DrawCell(TTableCell const&, unsigned long, TDeviceRenderer::Context const&) const + 74
    21  com.apple.HIToolbox                0x9295a217 TTableView::DrawCellSelf(Cell32 const&, Rect const&, TDeviceRenderer::Context const&, DBDrawFlags) const + 101
    22  com.apple.HIToolbox                0x9295a3c4 non-virtual thunk to TTableView::DrawCellSelf(Cell32 const&, Rect const&, TDeviceRenderer::Context const&, DBDrawFlags) const + 48
    23  com.apple.HIToolbox                0x9296f0dc TTableLayout::Draw(Rect const&, UPoint32 const&, TDeviceRenderer::Context const&, DBDrawFlags) const + 318
    24  com.apple.HIToolbox                0x92957764 TTableView::DrawView(unsigned short, TDeviceRenderer::Context const&) const + 164
    25  com.apple.HIToolbox                0x92965ccf TListView::DrawView(unsigned short, TDeviceRenderer::Context const&) const + 241
    26  com.apple.HIToolbox                0x92949c2a TBrowserView::Draw(CGContext*, unsigned short, OpaqueRgnHandle*) const + 390
    27  com.apple.HIToolbox                0x9294363d TBrowser::Draw(CGContext*, OpaqueRgnHandle*) const + 431
    28  com.apple.HIToolbox                0x92946051 TBrowser::EventHandlerProc(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 3941
    29  com.apple.HIToolbox                0x92990c0c _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
    30  com.apple.HIToolbox                0x9280c313 _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 1602
    31  com.apple.HIToolbox                0x9280b790 _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCallRec + 482
    32  com.apple.HIToolbox                0x9284f420 CallNextEventHandler + 79
    33  com.adobe.flash                    0x00f89e73 CDialogViewImpl::SetWindowText(unsigned short const*) + 16951
    34  com.apple.HIToolbox                0x92990c0c _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
    35  com.apple.HIToolbox                0x9280c313 _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 1602
    36  com.apple.HIToolbox                0x9280b790 _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCallRec + 482
    37  com.apple.HIToolbox                0x9280b5a8 SendEventToEventTargetWithOptions + 75
    38  com.apple.HIToolbox                0x9282c040 HIView::SendDraw(short, OpaqueGrafPtr*, __HIShape const*, CGContext*) + 478
    39  com.apple.HIToolbox                0x928bb30e HIView::RecursiveDrawNonComposited(short, OpaqueGrafPtr*, OpaqueRgnHandle*, unsigned char, unsigned char, unsigned char) + 558
    40  com.apple.HIToolbox                0x928bb5ac HIView::DrawNonComposited(short, OpaqueGrafPtr*, OpaqueRgnHandle*, unsigned long) + 340
    41  com.apple.HIToolbox                0x928bbfcf HIView::Draw(short, OpaqueGrafPtr*, unsigned long) + 149
    42  com.apple.HIToolbox                0x9284809e HIView::Show(unsigned char) + 304
    43  com.apple.HIToolbox                0x928acc99 ShowControl + 37
    44  com.adobe.flash                    0x00f89a7b CDialogViewImpl::SetWindowText(unsigned short const*) + 15935
    45  com.adobe.flash                    0x002bbfd6 CActionThrowDlg::~CActionThrowDlg() + 16920
    46  com.adobe.flash                    0x002bc0ce CActionThrowDlg::~CActionThrowDlg() + 17168
    47  com.adobe.flash                    0x00fa5b39 CMultiDocTemplate::GetRuntimeClass() const + 195
    48  com.adobe.flash                    0x00ff9639 TArray::~TArray() + 157
    49  com.adobe.flash                    0x00ff9af5 TTimerTask::DoTask() + 51
    50  com.adobe.flash                    0x01062cc9 LCollapsableTree::~LCollapsableTree() + 3915
    51  com.apple.HIToolbox                0x92821cfd TimerVector + 22
    52  com.apple.CoreFoundation           0x9c2562a6 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 22
    53  com.apple.CoreFoundation           0x9c255c37 __CFRunLoopDoTimer + 743
    54  com.apple.CoreFoundation           0x9c234cd0 __CFRunLoopRun + 1888
    55  com.apple.CoreFoundation           0x9c2341dc CFRunLoopRunSpecific + 332
    56  com.apple.CoreFoundation           0x9c234088 CFRunLoopRunInMode + 120
    57  com.apple.HIToolbox                0x92806543 RunCurrentEventLoopInMode + 318
    58  com.apple.HIToolbox                0x9280d8ab ReceiveNextEventCommon + 381
    59  com.apple.HIToolbox                0x9285bd93 AcquireNextEventInMode + 67
    60  com.apple.HIToolbox                0x929a395b _AcquireNextEvent + 58
    61  com.apple.HIToolbox                0x92990b78 RunApplicationEventLoop + 221
    62  com.adobe.flash                    0x00fcd77b CArray::SetSize(int, int) + 5271
    63  com.adobe.flash                    0x00fa619d CTimerImpl::~CTimerImpl() + 1293
    64  com.adobe.flash                    0x00fa6380 CTimerImpl::~CTimerImpl() + 1776
    65  com.adobe.flash                    0x0020f46d std::vector >::vector(std::allocator const&) + 6295
    Thread 1:: Dispatch queue: com.apple.libdispatch-manager
    0   libsystem_kernel.dylib             0x934c390a kevent + 10
    1   libdispatch.dylib                  0x9265fe04 _dispatch_mgr_invoke + 969
    2   libdispatch.dylib                  0x9265e853 _dispatch_mgr_thread + 53
    Thread 2:
    0   libsystem_kernel.dylib             0x934c0c22 mach_msg_trap + 10
    1   libsystem_kernel.dylib             0x934c01f6 mach_msg + 70
    2   com.apple.CoreFoundation           0x9c22b9da __CFRunLoopServiceMachPort + 170
    3   com.apple.CoreFoundation           0x9c234b04 __CFRunLoopRun + 1428
    4   com.apple.CoreFoundation           0x9c2341dc CFRunLoopRunSpecific + 332
    5   com.apple.CoreFoundation           0x9c244f01 CFRunLoopRun + 129
    6   com.apple.DVCPROHDMuxer            0x14f6a98f AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 317
    7   libsystem_c.dylib                  0x9278ced9 _pthread_start + 335
    8   libsystem_c.dylib                  0x927906de thread_start + 34
    Thread 3:
    0   libsystem_kernel.dylib             0x934c283e __psynch_cvwait + 10
    1   libsystem_c.dylib                  0x92790e21 _pthread_cond_wait + 827
    2   libsystem_c.dylib                  0x9274142c pthread_cond_wait$UNIX2003 + 71
    3   com.apple.CoreServices.CarbonCore     0x96d60e62 TSWaitOnCondition + 124
    4   com.apple.CoreServices.CarbonCore     0x96cd237d TSWaitOnConditionTimedRelative + 136
    5   com.apple.CoreServices.CarbonCore     0x96d3467f MPWaitOnQueue + 200
    6   com.adobe.ACE                      0x069b1a69 0x6972000 + 260713
    7   com.adobe.ACE                      0x069b0d99 0x6972000 + 257433
    8   com.apple.CoreServices.CarbonCore     0x96d355e0 PrivateMPEntryPoint + 68
    9   libsystem_c.dylib                  0x9278ced9 _pthread_start + 335
    10  libsystem_c.dylib                  0x927906de thread_start + 34
    Thread 4:
    Thread 5:
    Thread 6:
    Thread 7:
    Thread 8:
    Thread 9:
    Thread 10:
    Thread 11:
    Thread 12:
    Thread 13:
    Thread 14:
    Thread 15:
    Thread 16:
    Thread 17:
    Thread 18:
    3   com.adobe.AFlame                   0x0bb91439 Flame_Terminate + 1281926
    4   com.adobe.AFlame                   0x0bbdb950 Flame_Terminate + 1586333
    5   com.adobe.AFlame                   0x0bb8fa35 Flame_Terminate + 1275266
    6   libsystem_c.dylib                  0x9278ced9 _pthread_start + 335
    7   libsystem_c.dylib                  0x927906de thread_start + 34
    Thread 19:
    0   libsystem_kernel.dylib             0x934c2a9a __recvfrom + 10
    1   libsystem_c.dylib                  0x927414a2 recv$UNIX2003 + 54
    2   ServiceManager-Launcher.dylib      0x1ba7c733 Invoke + 47867
    3   ServiceManager-Launcher.dylib      0x1ba7b846 Invoke + 44046
    4   ServiceManager-Launcher.dylib      0x1ba7a988 Invoke + 40272
    5   ServiceManager-Launcher.dylib      0x1ba7aa0f Invoke + 40407
    6   ServiceManager-Launcher.dylib      0x1ba75baf Invoke + 20343
    7   ServiceManager-Launcher.dylib      0x1ba75ea7 Invoke + 21103
    8   ServiceManager-Launcher.dylib      0x1ba76685 Invoke + 23117
    9   ServiceManager-Launcher.dylib      0x1ba768f9 Invoke + 23745
    10  ServiceManager-Launcher.dylib      0x1ba792a0 Invoke + 34408
    11  ServiceManager-Launcher.dylib      0x1ba793fd Invoke + 34757
    12  ServiceManager-Launcher.dylib      0x1ba79c91 Invoke + 36953
    13  ServiceManager-Launcher.dylib      0x1ba79db2 Invoke + 37242
    14  ServiceManager-Launcher.dylib      0x1ba6c656 Login + 461
    15  ServiceManager-Launcher.dylib      0x1ba7009a Login + 15377
    16  ServiceManager-Launcher.dylib      0x1ba7a165 Invoke + 38189
    17  ServiceManager-Launcher.dylib      0x1ba7c2eb Invoke + 46771
    18  libsystem_c.dylib                  0x9278ced9 _pthread_start + 335
    19  libsystem_c.dylib                  0x927906de thread_start + 34
    Thread 20:: Java: Exception Handler Thread
    2   libsystem_kernel.dylib             0x934c0835 mach_msg_server + 699
    3   libjvm.dylib                       0x2484505a 0x2482f000 + 90202
    4   libjvm.dylib                       0x24844ee3 0x2482f000 + 89827
    5   libjvm.dylib                       0x2484396c 0x2482f000 + 84332
    Thread 21:: Java: Gang worker#0 (Parallel GC Threads)
    2   libjvm.dylib                       0x248440c6 0x2482f000 + 86214
    3   libjvm.dylib                       0x24844002 0x2482f000 + 86018
    4   libjvm.dylib                       0x24843ec8 0x2482f000 + 85704
    5   libjvm.dylib                       0x24843a0d 0x2482f000 + 84493
    6   libjvm.dylib                       0x24843897 0x2482f000 + 84119
    7   libjvm.dylib                       0x2485b3f1 0x2482f000 + 181233
    8   libjvm.dylib                       0x2485b2db 0x2482f000 + 180955
    9   libjvm.dylib                       0x2484396c 0x2482f000 + 84332
    10  libsystem_c.dylib                  0x9278ced9 _pthread_start + 335
    11  libsystem_c.dylib                  0x927906de thread_start + 34
    Thread 22:: Java: Gang worker#1 (Parallel GC Threads)
    Thread 23:: Java: Gang worker#2 (Parallel GC Threads)
    Thread 24:: Java: Gang worker#3 (Parallel GC Threads)
    Thread 25:: Java: Gang worker#4 (Parallel GC Threads)
    Thread 26:: Java: Gang worker#5 (Parallel GC Threads)
    Thread 27:: Java: Gang worker#6 (Parallel GC Threads)
    Thread 28:: Java: Gang worker#7 (Parallel GC Threads)
    Thread 29:: Java: Gang worker#8 (Parallel GC Threads)
    Thread 30:: Java: Gang worker#9 (Parallel GC Threads)
    Thread 31:: Java: Gang worker#10 (Parallel GC Threads)
    Thread 32:: Java: Gang worker#11 (Parallel GC Threads)
    Thread 33:: Java: Gang worker#12 (Parallel GC Threads)
    Thread 34:: Java: Gang worker#13 (Parallel GC Threads)
    Thread 35:: Java: Gang worker#14 (Parallel GC Threads)
    Thread 36:: Java: Gang worker#15 (Parallel GC Threads)
    Thread 37:: Java: Gang worker#16 (Parallel GC Threads)
    Thread 38:: Java: Gang worker#17 (Parallel GC Threads)
    Thread 39:: Java: Gang worker#0 (Parallel CMS Threads)
    7   libjvm.dylib                       0x24b3cf0e 0x2482f000 + 3202830
    Thread 40:: Java: Gang worker#1 (Parallel CMS Threads)
    Thread 41:: Java: Gang worker#2 (Parallel CMS Threads)
    Thread 42:: Java: Gang worker#3 (Parallel CMS Threads)
    Thread 43:: Java: Gang worker#4 (Parallel CMS Threads)
    Thread 44:: Java: Concurrent Mark-Sweep GC Thread
    2   libjvm.dylib                       0x24844196 0x2482f000 + 86422
    3   libjvm.dylib                       0x24861d56 0x2482f000 + 208214
    4   libjvm.dylib                       0x24843ee4 0x2482f000 + 85732
    7   libjvm.dylib                       0x2496cca5 0x2482f000 + 1301669
    8   libjvm.dylib                       0x2496cc13 0x2482f000 + 1301523
    9   libjvm.dylib                       0x24861b71 0x2482f000 + 207729
    10  libjvm.dylib                       0x2484396c 0x2482f000 + 84332
    11  libsystem_c.dylib                  0x9278ced9 _pthread_start + 335
    12  libsystem_c.dylib                  0x927906de thread_start + 34
    Thread 45:: Java: VM Thread
    7   libjvm.dylib                       0x248dc246 0x2482f000 + 709190
    8   libjvm.dylib                       0x248dbeef 0x2482f000 + 708335
    Thread 46:: Java: Reference Handler
    4   libjvm.dylib                       0x248eae28 0x2482f000 + 769576
    5   libjvm.dylib                       0x248ea32a 0x2482f000 + 766762
    6   libjvm.dylib                       0x248ea01c JVM_MonitorWait + 203
    7   libjvmlinkage.dylib                0x1c3e2dd5 JVM_MonitorWait + 69
    8   ???                                0x549d99d9 0 + 1419614681
    9   ???                                0x549d1e31 0 + 1419583025
    10  ???                                0x549d1e31 0 + 1419583025
    11  ???                                0x549cf374 0 + 1419572084
    12  libjvm.dylib                       0x248dd583 0x2482f000 + 714115
    13  libjvm.dylib                       0x248dd2f5 0x2482f000 + 713461
    14  libjvm.dylib                       0x248e9ccd 0x2482f000 + 765133
    15  libjvm.dylib                       0x248e9b5d 0x2482f000 + 764765
    16  libjvm.dylib                       0x248e9adb 0x2482f000 + 764635
    17  libjvm.dylib                       0x248e9935 0x2482f000 + 764213
    18  libjvm.dylib                       0x248e9773 0x2482f000 + 763763
    19  libjvm.dylib                       0x2484396c 0x2482f000 + 84332
    20  libsystem_c.dylib                  0x9278ced9 _pthread_start + 335
    21  libsystem_c.dylib                  0x927906de thread_start + 34
    Thread 47:: Java: Finalizer
    10  ???                                0x549d1f97 0 + 1419583383
    11  ???                                0x549d1f97 0 + 1419583383
    12  ???                                0x549cf374 0 + 1419572084
    13  libjvm.dylib                       0x248dd583 0x2482f000 + 714115
    14  libjvm.dylib                       0x248dd2f5 0x2482f000 + 713461
    15  libjvm.dylib                       0x248e9ccd 0x2482f000 + 765133
    16  libjvm.dylib                       0x248e9b5d 0x2482f000 + 764765
    17  libjvm.dylib                       0x248e9adb 0x2482f000 + 764635
    18  libjvm.dylib                       0x248e9935 0x2482f000 + 764213
    19  libjvm.dylib                       0x248e9773 0x2482f000 + 763763
    20  libjvm.dylib                       0x2484396c 0x2482f000 + 84332
    21  libsystem_c.dylib                  0x9278ced9 _pthread_start + 335
    22  libsystem_c.dylib                  0x927906de thread_start + 34
    Thread 48:: Java: Surrogate Locker Thread (Concurrent GC)
    6   libjvm.dylib                       0x248437da 0x2482f000 + 83930
    7   libjvm.dylib                       0x248facb4 0x2482f000 + 834740
    8   libjvm.dylib                       0x248fabf8 0x2482f000 + 834552
    9   libjvm.dylib                       0x248e9935 0x2482f000 + 764213
    10  libjvm.dylib                       0x248e9773 0x2482f000 + 763763
    11  libjvm.dylib                       0x2484396c 0x2482f000 + 84332
    12  libsystem_c.dylib                  0x9278ced9 _pthread_start + 335
    13  libsystem_c.dylib                  0x927906de thread_start + 34
    Thread 49:: Java: Signal Dispatcher
    0   libsystem_kernel.dylib             0x934c0c5e semaphore_wait_trap + 10
    1   libjvm.dylib                       0x248fb59a 0x2482f000 + 837018
    2   libjvm.dylib                       0x248faf78 0x2482f000 + 835448
    3   libjvm.dylib                       0x248e9935 0x2482f000 + 764213
    4   libjvm.dylib                       0x248e9773 0x2482f000 + 763763
    Thread 50:: Java: C1 CompilerThread0
    7   libjvm.dylib                       0x24902e4a 0x2482f000 + 867914
    8   libjvm.dylib                       0x248fc770 0x2482f000 + 841584
    9   libjvm.dylib                       0x248fc51a 0x2482f000 + 840986
    10  libjvm.dylib                       0x248e9935 0x2482f000 + 764213
    11  libjvm.dylib                       0x248e9773 0x2482f000 + 763763
    12  libjvm.dylib                       0x2484396c 0x2482f000 + 84332
    13  libsystem_c.dylib                  0x9278ced9 _pthread_start + 335
    14  libsystem_c.dylib                  0x927906de thread_start + 34
    Thread 51:: Java: Low Memory Detector
    7   libjvm.dylib                       0x248fd458 0x2482f000 + 844888
    Thread 52:: Java: VM Periodic Task Thread
    3   libjvm.dylib                       0x249779d6 0x2482f000 + 1346006
    4   libjvm.dylib                       0x248ffe2a 0x2482f000 + 855594
    Thread 53:: Java: FelixDispatchQueue
    11  ???                                0x549d1e31 0 + 1419583025
    12  ???                                0x549d1e31 0 + 1419583025
    13  ???                                0x549d230d 0 + 1419584269
    14  ???                                0x549cf374 0 + 1419572084
    15  libjvm.dylib                       0x248dd583 0x2482f000 + 714115
    16  libjvm.dylib                       0x248dd2f5 0x2482f000 + 713461
    17  libjvm.dylib                       0x248e9ccd 0x2482f000 + 765133
    18  libjvm.dylib                       0x248e9b5d 0x2482f000 + 764765
    19  libjvm.dylib                       0x248e9adb 0x2482f000 + 764635
    20  libjvm.dylib                       0x248e9935 0x2482f000 + 764213
    21  libjvm.dylib                       0x248e9773 0x2482f000 + 763763
    22  libjvm.dylib                       0x2484396c 0x2482f000 + 84332
    23  libsystem_c.dylib                  0x9278ced9 _pthread_start + 335
    24  libsystem_c.dylib                  0x927906de thread_start + 34
    Thread 54:: Java: FelixStartLevel
    11  ???                                0x549d230d 0 + 1419584269
    Thread 55:: Java: FelixPackageAdmin
    Thread 56:: Java: Code Model Worker
    3   libjvm.dylib                       0x24ae7041 0x2482f000 + 2850881
    4   libjvm.dylib                       0x24b27912 0x2482f000 + 3115282
    5   ???                                0x549d99d9 0 + 1419614681
    6   ???                                0x549d1e31 0 + 1419583025
    7   ???                                0x549d1e31 0 + 1419583025
    8   ???                                0x549d230d 0 + 1419584269
    9   ???                                0x549d2473 0 + 1419584627
    Thread 57:: Java: Code Model Worker
    Thread 58:
    0   libsystem_kernel.dylib             0x934c2bb2 __semwait_signal + 10
    1   libsystem_c.dylib                  0x927417b9 nanosleep$UNIX2003 + 187
    2   com.adobe.flash.flbridge           0x1de2d93b ScObjects::Thread::sleep(unsigned int) + 59
    3   com.adobe.flash.flbridge           0x1de29799 ScObjects::BridgeTalkThread::run() + 185
    4   com.adobe.flash.flbridge           0x1de2dca8 ScObjects::Thread::go(void*) + 168
    5   libsystem_c.dylib                  0x9278ced9 _pthread_start + 335
    6   libsystem_c.dylib                  0x927906de thread_start + 34
    Thread 59:: com.apple.CFSocket.private
    0   libsystem_kernel.dylib             0x934c2b42 __select + 10
    1   com.apple.CoreFoundation           0x9c282e15 __CFSocketManager + 1557
    Thread 60:
    0   libsystem_kernel.dylib             0x934c302e __workq_kernreturn + 10
    1   libsystem_c.dylib                  0x9278eccf _pthread_wqthread + 773
    2   libsystem_c.dylib                  0x927906fe start_wqthread + 30
    Thread 0 crashed with X86 Thread State (32-bit):
      eax: 0xbfffc248  ebx: 0x1f998b10  ecx: 0x00000000  edx: 0x00000000
      edi: 0xbfffc248  esi: 0x1dfef920  ebp: 0xbfffc188  esp: 0xbfffc17c
       ss: 0x00000023  efl: 0x00010286  eip: 0x9c28de16   cs: 0x0000001b
       ds: 0x00000023   es: 0x00000023   fs: 0x00000000   gs: 0x0000000f
      cr2: 0x00000014
    Logical CPU: 0
    Binary Images:
        0x1000 -  0x1b82fff +com.adobe.flash (12.0.2.529 - 12.0.2) <05566898-067F-CC57-6272-EF851BBF7BDD> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/MacOS/Adobe Flash CS6
     0x272b000 -  0x28bffff +com.adobe.PlugPlug (3.0.0.383 - 3.0.0.383) <2205B6E1-7C9E-1892-EC68-C1B326C727A8> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
     0x2967000 -  0x2a4ffe3 +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.7.101.18636 - 3.7.101.18636) <2540764B-C2F2-61D7-EFBA-6663171FD19A> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
     0x2ae0000 -  0x2b7efe3 +libicucnv.40.0.dylib (40.0.0 - compatibility 40.0.0)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/libicucnv.40.0.dylib
     0x2ba0000 -  0x2cd5fe7 +libicui18n.40.0.dylib (40.0.0 - compatibility 40.0.0) <8BE3FE71-0CE6-2B93-B5F2-B4F0DD274B91> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/ICUInternationalization.framework/Versions/4.0/libicui18n.40.0.dylib
     0x2d49000 -  0x2e3afef +libicuuc.40.0.dylib (40.0.0 - compatibility 40.0.0) <4CF7066A-6E82-FF80-93E6-6849149FBB98> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/libicuuc.40.0.dylib
     0x2e77000 -  0x3bbcff7 +libicudata.40.0.dylib (40.0.0 - compatibility 40.0.0) <015E6351-4F42-00C1-2096-BEE385B275B1> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/ICUData.framework/Versions/4.0/libicudata.40.0.dylib
     0x3bcf000 -  0x3bdaff7 +libChar16.dylib (??? - ???) <5E278E11-8234-CB11-AAC9-090FBD037DB7> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/MacOS/libChar16.dylib
     0x3be3000 -  0x3c05fff +libCoreTypes.dylib (??? - ???) <5799BD8C-B334-518F-3F6F-EAA503B43831> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/MacOS/libCoreTypes.dylib
     0x3c1d000 -  0x3e4bfff  com.apple.carbonframeworktemplate (1.0 - 1.0) <9F3FE9F2-8834-4654-C0D0-F4F356E6A906> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/Xerces.framework/Versions/A/Xerces
     0x4102000 -  0x4106ffd  com.apple.JavaVM (14.6.0 - 14.6.0) <1163556C-5C1D-3C5A-8767-682DAE7D3174> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
     0x410e000 -  0x5778fff +com.adobe.AILib (AILib version 16.0.0 - 16.0.0.646) <317A871E-E0A5-8C5E-B60F-7448ADEBEDBD> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AILib.framework/Versions/A/AILib
     0x67f1000 -  0x684cfff +com.adobe.aiport (aiport version 16.0.0 - 16.0.0.646) <59612576-B2F2-BF25-B09D-6120A3B1462C> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/aiport.framework/Versions/A/aiport
     0x688c000 -  0x68ecfff +com.adobe.filterport (filterport version 16.0.0 - 16.0.0.646)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/filterport.framework/Versions/A/filterport
     0x6937000 -  0x6937ffb +com.adobe.SPBasic (SPBasic version 16.0.0 - 16.0.0.646) <936C3F3E-8DDD-50EC-D247-C1F242633914> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/SPBasic.framework/Versions/A/SPBasic
     0x693c000 -  0x6958ff9 +AdobePDFSettings (??? - ???) /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
     0x6972000 -  0x6aeeff3 +com.adobe.ACE (AdobeACE 2.19.18.19822 - 2.19.18.19822) <2EC89B0E-6B51-4F7F-314A-FB6E18BFC36D> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
     0x6afd000 -  0x7098fef +com.adobe.AGM (AdobeAGM 4.26.20.19822 - 4.26.20.19822)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
     0x7108000 -  0x7142fef +com.adobe.ARE (AdobeARE 1.5.02.19822 - 1.5.02.19822) <2A3CBF43-F63E-B5B6-19EA-A2C392CA92F4> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
     0x7148000 -  0x7163fff +com.adobe.BIB (AdobeBIB 1.2.02.19822 - 1.2.02.19822)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
     0x7169000 -  0x718ffff +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <606DA5E0-CCB3-90B2-3971-A48349DA046A> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
     0x7195000 -  0x74bcffb +com.adobe.CoolType (AdobeCoolType 5.10.31.19822 - 5.10.31.19822)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
     0x74f4000 -  0x78effe7 +com.adobe.MPS (AdobeMPS 5.8.0.19673 - 5.8.0.19673)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
     0x794c000 -  0x7a50fef +com.adobe.PDFPort (AdobePDFPort 2.1.0.19734 - 2.1.0.19734) <71232DFD-06FB-837B-8246-BD20F862B5E3> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
     0x7a69000 -  0x8261ffb +com.adobe.PDFL (PROD_MAJOR.PROD_MINOR.PROD_STEP - 10.0.1.18562)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
     0x82ec000 -  0x8314feb +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.7.101.18636 - 3.7.101.18636)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
     0x8333000 -  0x835bff3 +com.adobe.AXE16SharedExpat (AdobeAXE16SharedExpat 3.7.101.18636 - 3.7.101.18636)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedExpat
     0x837a000 -  0x83d6fef +com.adobe.AdobeXMPCore (Adobe XMP Core 5.3 -c 11 - 66.145661) <123A0829-A85B-6E67-0E48-4F37B08E4C03> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
     0x83df000 -  0x8457fe3 +com.adobe.FileInfo.framework (Adobe XMP FileInfo 5 . 3 . 0 . 0 -i 3 - 66.145433)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
     0x8466000 -  0x8645ffb +com.adobe.owl (AdobeOwl version 4.0.93 - 4.0.93)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
     0x8672000 -  0x971eff3 +com.adobe.psl (AdobePSL 13.0.0.19655 - 13.0.0.19655) <47A9AAEC-43CD-17C9-6E58-6312315FC15D> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
     0x9897000 -  0x9ac1ffb +com.adobe.linguistic.LinguisticManager (6.0.0 - 17018)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
     0x9b33000 -  0x9b36ffb +com.adobe.AdobeCrashReporter (6.0 - 6.0.20120201) <6CE1936E-6AC7-6900-769B-876CBB68B5BC> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
     0x9b3e000 -  0x9f71ffb +com.adobe.dvaui.framework (5.0.0 - 5.0.0.0)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
     0xa3aa000 -  0xa55fff3 +com.adobe.dvacore.framework (5.0.0 - 5.0.0.0)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
     0xa6ad000 -  0xaac0fe7 +com.adobe.dvaadameve.framework (5.0.0 - 5.0.0.0)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
     0xb0d1000 -  0xb1b3ff3 +com.adobe.amtlib (amtlib 6.0.0.93 - 6.0.0.93) <2218F05B-09B7-AE0E-5EF7-98FBA5DF9C86> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
     0xb1c2000 -  0xb22fffb +com.adobe.headlights.LogSessionFramework (??? - 2.1.2.1652) <82DA9279-45D2-AD40-C86C-F5A94B9DAAFF> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
     0xb27e000 -  0xb2b2ff7 +com.adobe.pip (??? - 6.0.0.1654) <21A87289-747E-A0BD-2692-F9E844932E26> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobePIP.framework/Versions/A/AdobePIP
     0xb2be000 -  0xb3fefeb +com.winsoft.wrservices (WRServices 5.0.0 - 5.0.0) <6D085279-1185-E7F0-B0D8-FBADBA062516> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
     0xb470000 -  0xb478ff7 +com.adobe.boost_date_time.framework (5.0.0 - 5.0.0.0) <6397AF50-419F-3030-C6D6-A28D34CF3412> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
     0xb490000 -  0xb4a8ff3 +com.adobe.boost_filesystem.framework (5.0.0 - 5.0.0.0) <8DC64C9A-155F-DE79-3521-8869C4A2661D> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
     0xb4c9000 -  0xb573ffb +com.adobe.boost_regex.framework (5.0.0 - 5.0.0.0)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
     0xb5f8000 -  0xb603ff7 +com.adobe.boost_signals.framework (5.0.0 - 5.0.0.0) <5F9FB957-8AC2-A2FD-1518-9F9D978B0C58> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
     0xb617000 -  0xb619ff3 +com.adobe.boost_system.framework (5.0.0 - 5.0.0.0) <5641DBC5-37C4-7349-4BB4-FC19F46EEFFC> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
     0xb61f000 -  0xb62bff7 +com.adobe.boost_threads.framework (5.0.0 - 5.0.0.0) <6F6A3465-894D-2E05-9FDE-16A15486E583> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
     0xb647000 -  0xb7fafe3 +com.adobe.AFlamingo (AFlamingo 2.3.102.19287 - 2.3.102.19287)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/aflamingo.framework/Versions/A/aflamingo
     0xb816000 -  0xb81dffb +com.adobe.ape.shim (3.3.8.19346 - 3.3.8.19346)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
     0xb825000 -  0xb8eefeb +FlashIK Framework (??? - 1.0)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/FlashIK.framework/Versions/A/FlashIK
     0xb977000 -  0xb9abff7 +com.adobe.pff.framework (1.0 - 1.0)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/PFF.framework/Versions/A/PFF
     0xb9d4000 -  0xc377fef +com.adobe.AFlame (AFlame 2.03.54.19287 - 2.03.54.19287) <21495560-EA23-BCA2-8E91-9F0C1EF440EB> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/aflame.framework/Versions/A/aflame
     0xc3eb000 -  0xc41afff +com.adobe.contextui.framework (5.0.0 - 5.0.0.0) <109B01C7-7CB9-D3CA-2CBB-B8D4ADC7AE3E> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/contextui.framework/Versions/A/contextui
     0xc461000 -  0xc485fe7 +com.adobe.dvaunittesting.framework (5.0.0 - 5.0.0.0)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
     0xc4bd000 -  0xc4dcfff +libtbb.dylib (??? - ???) <6EA19434-60D6-505D-CB6F-5CA562A0F2A7> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/libtbb.dylib
     0xc4f3000 -  0xc4fbfef +libtbbmalloc.dylib (??? - ???) <7A79ED70-A4AC-737A-2FAA-63B6FB29D4ED> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/libtbbmalloc.dylib
     0xc50a000 -  0xc5c5fef +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.4 -f 49 - 66.145661)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
     0xc5f4000 -  0xc5f8fff  JavaLaunching (??? - ???)  /System/Library/PrivateFrameworks/JavaLaunching.framework/Versions/A/JavaLaunching
     0xc600000 -  0xc600fff  libmx.A.dylib (2026.0.0 - compatibility 1.0.0) <859B5BCC-B5D9-370F-8B6C-1E2B242D5DCD> /usr/lib/libmx.A.dylib
     0xc603000 -  0xc640fff  com.apple.vmutils (4.2.1 - 107) <43B3BFA5-8362-3EBD-B44B-32DCE9885082> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
     0xc65a000 -  0xc65dffb +com.adobe.dvaflashview.framework (5.0.0 - 5.0.0.0)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dvaflashview
     0xc66c000 -  0xc73efff +com.adobe.dvaworkspace.framework (5.0.0 - 5.0.0.0) <2B746397-82F4-3C89-28C1-1EC7EE317435> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
     0xc876000 -  0xc877ff1  com.apple.textencoding.unicode (2.4 - 2.4) <4E55D4B9-4E67-3FC9-9407-3E99D1D50F15> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
     0xedf0000 -  0xedf2ff3  com.apple.LiveType.component (2.1.4 - 2.1.4)  /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
     0xedf8000 -  0xedfaff7  Motion (729.0.0 - compatibility 1.0.0) <051B60E9-B39F-EBB2-5B96-F088D147E78C> /Library/Frameworks/Motion.framework/Versions/A/Motion
     0xef99000 -  0xef9bff7 +com.macromedia.Flash.FLfile (12.0.0.481 - 12.0.0) <639D8AF3-69A7-4D91-5826-F54C86AB1BD1> /Applications/Adobe Flash CS6/*/FLfile.bundle/Contents/MacOS/FLfile
     0xefcd000 -  0xefceff3 +com.macromedia.Flash.flastoragelib (9.0 - 9.0)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/PlugIns/FLAStorageLib.bundle/Contents/MacOS/FLAStorageLib
     0xefd3000 -  0xefd4ffc  ATSHI.dylib (??? - ???) <0B0F21B6-C254-34AE-8128-F3FBC80C68E6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
     0xefd9000 -  0xefddffb  com.apple.audio.AudioIPCPlugIn (1.2.3 - 1.2.3)  /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
     0xeff5000 -  0xeffafff  com.apple.audio.AppleHDAHALPlugIn (2.2.5 - 2.2.5a5)  /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
    0x11320000 - 0x11333ff7 +com.adobe.AdobeSFL (AdobeSFL 1.1.0.18561 - 1.1.0.18561) <5A153C87-DD7A-CE28-2E93-7DC120D4244F> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeSFL.framework/Versions/A/AdobeSFL
    0x1133a000 - 0x11348ffb  libSimplifiedChineseConverter.dylib (54.0.0 - compatibility 1.0.0) <4378B89F-0BDA-3072-9C67-DE1A371DD816> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
    0x1134c000 - 0x1135efff  libTraditionalChineseConverter.dylib (54.0.0 - compatibility 1.0.0)  /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
    0x11398000 - 0x113fcfe2  com.apple.LiveType.framework (2.1.4 - 2.1.4)  /Library/Application Support/ProApps/*/LiveType.framework/Versions/A/LiveType
    0x1141c000 - 0x11462ffb  com.apple.motion.component (1.0 - 729) <494487C6-EA30-43DD-39E4-BED23C5A5B1C> /Library/QuickTime/Motion.component/Contents/MacOS/Motion
    0x11468000 - 0x11492ff7 +com.grame.JackRouter (JackRouter - 0.9.5) <13AB2581-FFAF-AC76-FB8F-D1C8779C94AF> /Library/Audio/Plug-Ins/HAL/JackRouter.plugin/Contents/MacOS/JackRouter
    0x115c6000 - 0x115c6ff7 +cl_kernels (??? - ???)  cl_kernels
    0x14e02000 - 0x14e9fff8  com.apple.procore.framework (4.0.2 - 757)  /Library/Application Support/ProApps/*/ProCore.framework/Versions/A/ProCore
    0x14edf000 - 0x14f34fe2  com.apple.DVCPROHDAudio (1.3.2 - 1.3.2)  /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
    0x14f53000 - 0x14fb8fe0  com.apple.DVCPROHDMuxer (1.3.2 - 1.3.2)  /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
    0x19b0b000 - 0x1a4fdff3 +com.macromedia.Flash Player.authplaylib (10.2.153.2 - 10.2.153.2) <3CFE191B-E5E1-6C47-46DB-FE24C06872B7> /Applications/Adobe Flash CS6/*/AuthPlayLib.bundle/Contents/MacOS/AuthPlayLib
    0x1a79f000 - 0x1a7c8fff +Jackmp (??? - ???) <0B8EB3A5-FD59-2D99-839C-2D4A9A59AA94> /Library/Frameworks/Jackmp.framework/Versions/A/Jackmp
    0x1aacb000 - 0x1aad3ffb  com.apple.URLMount.AFPPlugin (4.0.1 - 4.0.1)  /System/Library/Filesystems/NetFSPlugins/afp.bundle/Contents/MacOS/afp
    0x1aada000 - 0x1ab23ff7  com.apple.AppleShareClientCore (2.5.1 - 2.5.1)  /System/Library/Frameworks/AppleShareClientCore.framework/Versions/A/AppleShareClientCore
    0x1ab36000 - 0x1ab3ffff  com.apple.AppleSRP (1.0 - 1) <81354E70-3B47-37CA-AF3E-2511AD125291> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
    0x1ab51000 - 0x1abc3fef +com.adobe.adobe_caps (adobe_caps 6.0.29.0 - 6.0.29.0)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
    0x1abd6000 - 0x1ac19ff3 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 6.0.0.24 - 6.0.0.24) <4B40551F-5306-C836-02AD-109826BD580C> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotifications
    0x1ae56000 - 0x1ae5bfff  com.apple.URLMount.CIFSPlugin (5.0.0 - 5.0.0) <6871D2AB-2D12-3BEB-B3A0-A3FFF47E2561> /System/Library/Filesystems/NetFSPlugins/smb.bundle/Contents/MacOS/smb
    0x1ae6a000 - 0x1ae6bffd +cl_kernels (??? - ???) <2F2A69A0-050E-4C2D-96D5-B66258AE2D83> cl_kernels
    0x1aefd000 - 0x1aefffff  libCoreFSCache.dylib (??? - ???) <9E7CBE71-566C-36E9-A49F-C5FF6956D76F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x1af55000 - 0x1af56ff5 +cl_kernels (??? - ???)  cl_kernels
    0x1af5a000 - 0x1af5affd +cl_kernels (??? - ???)  cl_kernels
    0x1af5d000 - 0x1afb1fe7 +com.adobe.ape (3.3.8.19346 - 3.3.8.19346) <0B80F7A7-EC10-A7C7-5E6E-787953553C55> /Library/Application Support/Adobe/*/adbeapecore.framework/adbeapecore
    0x1ba67000 - 0x1ba8effb +ServiceManager-Launcher.dylib (389.0.0 - compatibility 2.5.0) <4EEAF886-0B48-9FF4-BE65-41E222123A50> /Library/Application Support/Adobe/*/ServiceManager-Launcher.dylib
    0x1bba7000 - 0x1bbb0ff6  libcldcpuengine.dylib (2.0.19 - compatibility 1.0.0) <95A88DC8-E5EE-363F-9275-214D5AB7A2EF> /System/Library/Frameworks/OpenCL.framework/Libraries/libcldcpuengine.dylib
    0x1bec3000 - 0x1bec7ffb  libFontRegistryUI.dylib (??? - ???) <2E905389-BAB1-3339-9C98-185D60BAB4D0> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib
    0x1c222000 - 0x1c231fff +com.yourcompany.PointGrid (??? - 1.0) <2CB987CD-6752-D333-7F4F-A6713A901947> /Applications/Adobe Flash CS6/*/PointGrid.bundle/Contents/MacOS/PointGrid
    0x1c3e2000 - 0x1c3e9ffb  libjvmlinkage.dylib (??? - ???) <6A77EDD1-D1B2-39A9-A637-67BC1D7349F9> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjvmlinkage.dylib
    0x1c60c000 - 0x1c62eff7 +com.adobe.flash.cs6.airAndroid (12.0.0.0 - 12.0.0)  /Applications/Adobe Flash CS6/*/Air_Android.bundle/Contents/MacOS/Air_Android
    0x1c6af000 - 0x1c6d9ff7 +com.adobe.flash.cs6.air (12.0.0.0 - 12.0.0) <5D928258-091F-21EA-B69D-00EEA6B7838A> /Applications/Adobe Flash CS6/*/Air_Desktop_iOS.bundle/Contents/MacOS/Air_Desktop_iOS
    0x1c896000 - 0x1c89dfff  libverify.dylib (1.0 - 1.0) <832C9B30-D9EF-3A78-87D1-39B5B59AC38A> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libverify.dylib
    0x1c931000 - 0x1c939fff  JavaNativeFoundation (??? - ???) <255E405D-7805-3461-A678-47692E309629> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.framework/Versions/A/JavaNativeFoundation
    0x1cad5000 - 0x1caf2fff  libjava.jnilib (??? - ???)  /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjava.jnilib
    0x1cb05000 - 0x1cb11fff  libzip.jnilib (??? - ???) <2C56697E-3280-377C-BF3E-9FC09C627B02> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libzip.jnilib
    0x1cbac000 - 0x1cbb4fff  com.apple.java.JavaRuntimeSupport (14.6.0 - 14.6.0)  /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaRuntimeSupport.framework/Versions/A/JavaRuntimeSupport
    0x1d27b000 - 0x1d2d8fef +com.yourcompany.Brush (??? - 1.0) <2136D27E-974D-81F0-6078-492B233E16FC> /Applications/Adobe Flash CS6/*/Brush.bundle/Contents/MacOS/Brush
    0x1de0c000 - 0x1de53fff +com.adobe.flash.flbridge (12.0.0.481 - 12.0.0) <9301CA9F-DABA-0BB4-84D3-B9DAE690711D> /Applications/Adobe Flash CS6/*/FLBridge.bundle/Contents/MacOS/FLBridge
    0x1ded1000 - 0x1dee9fff  com.apple.SMBClient (1.7.2 - 1.7.2)  /System/Library/PrivateFrameworks/SMBClient.framework/Versions/A/SMBClient
    0x1e4e1000 - 0x1e564ffb +com.yourcompany.Collision (??? - 1.0)  /Applications/Adobe Flash CS6/*/Collision.bundle/Contents/MacOS/Collision
    0x1e900000 - 0x1ea01fff +com.yourcompany.Stroke (??? - 1.0)  /Applications/Adobe Flash CS6/*/Stroke.bundle/Contents/MacOS/Stroke
    0x21031000 - 0x210a6fff  com.apple.DCERPC (1.0 - 46) <0106A1EC-BE9F-39E9-9206-D49499DDC8C3> /System/Library/PrivateFrameworks/DCERPC.framework/Versions/A/DCERPC
    0x21607000 - 0x216afff7  unorm8_argb.dylib (2.0.19 - compatibility 1.0.0) <1C5CBAF6-9739-340F-9CD6-10D08FEF554F> /System/Library/Frameworks/OpenCL.framework/Libraries/ImageFormats/unorm8_argb.dylib
    0x21800000 - 0x218a8ff7  unorm8_bgra.dylib (2.0.19 - compatibility 1.0.0) <99A967D2-5577-396B-BD11-56EAFF962AB2> /System/Library/Frameworks/OpenCL.framework/Libraries/ImageFormats/unorm8_bgra.dylib
    0x2482f000 - 0x24b92fe2  libjvm.dylib (??? - ???)  /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/bundle/Libraries/libjvm.dylib
    0x40000000 - 0x400c4fe3 +com.adobe.JP2K (2.0.0 - 2.0.0.18562)  /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
    0x51b85000 - 0x52733ff3 +com.adobe.flash.createjs (1.1.0.0 - 1.1.0)  /Users/USER/Library/Application Support/Adobe/*/FLCreateJS.bundle/Contents/MacOS/FLCreateJS
    0x8fe7a000 - 0x8feacaa7  dyld (195.6 - ???) <3A866A34-4CDD-35A4-B26E-F145B05F3644> /usr/lib/dyld
    0x90005000 - 0x9000dfff  com.apple.DiskArbitration (2.4.1 - 2.4.1) <28D5D8B5-14E8-3DA1-9085-B9BC96835ACF> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x9000e000 - 0x900b2fff  com.apple.QD (3.40 - ???) <3881BEC6-0908-3073-BA44-346356E1CDF9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x900b3000 - 0x900c8ff7  com.apple.ImageCapture (7.1.0 - 7.1.0)  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x90145000 - 0x90a7072b  com.apple.CoreGraphics (1.600.0 - ???)  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x90a7a000 - 0x90b3dfff  com.apple.CoreServices.OSServices (478.49 - 478.49) <5AF33605-C893-3F60-89CF-1BC9C0BC35AF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x90b3e000 - 0x90b90ff7  libFontRegistry.dylib (??? - ???)  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x90b91000 - 0x90b9cff3  libCSync.A.dylib (600.0.0 - compatibility 64.0.0)  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x90b9d000 - 0x90c02ff7  libvDSP.dylib (325.4.0 - compatibility 1.0.0) <4B4B32D2-4F66-3B0D-BD61-FA8429FF8507> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x90c1a000 - 0x90c1efff  libGIF.dylib (??? - ???) <2ADFED97-2228-343D-9A53-207CBFDE7984> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x90c1f000 - 0x90eabffb  com.apple.RawCamera.bundle (4.04 - 680)  /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    0x90fd4000 - 0x90ff0ff1  libPng.dylib (??? - ???)  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x90ff1000 - 0x9101fff7  com.apple.DictionaryServices (1.2.1 - 158.3) <8D03D180-D834-39F3-A106-78E0B22A7893> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x91020000 - 0x9102dfff  com.apple.HelpData (2.1.2 - 72.2) <330C6B7F-2512-37B7-B2FF-24E1804E9426> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
    0x9109b000 - 0x910a3ff5  libcopyfile.dylib (85.1.0 - compatibility 1.0.0)  /usr/lib/system/libcopyfile.dylib
    0x910a4000 - 0x910a4fff  com.apple.audio.units.AudioUnit (1.7.3 - 1.7.3) <2E71E880-25D1-3210-8D26-21EC47ED810C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x910d1000 - 0x91b02fff  com.apple.WebCore (7534.57 - 7534.57.7) <5FF60D46-9BC0-3B5A-AFF1-2C965D561009> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
    0x91b03000 - 0x91b61ff7  com.apple.coreui (1.2.2 - 165.11) <340B0B83-1407-3AB4-BCAB-505C29303EE2> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x91b62000 - 0x91b73fff  libbsm.0.dylib (??? - ???) <54ACF696-87C6-3652-808A-17BE7275C230> /usr/lib/libbsm.0.dylib
    0x91b74000 - 0x91c5cfff  libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <1841196F-68B5-309F-8ED1-6714B1DFEC83> /usr/lib/libxml2.2.dylib
    0x91c68000 - 0x91c80fff  com.apple.frameworks.preferencepanes (15.0 - 15.0)  /System/Library/Frameworks/PreferencePanes.framework/Versions/A/PreferencePanes
    0x91c81000 - 0x91c88fff  com.apple.agl (3.2.0 - AGL-3.2.0)  /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x91c89000 - 0x92044ffb  com.apple.SceneKit (125.3 - 125.8) <89008B87-87E7-3972-A274-30311497EE32> /System/Library/PrivateFrameworks/SceneKit.framework/Versions/A/SceneKit
    0x92087000 - 0x920bafef  libtidy.A.dylib (??? - ???)  /usr/lib/libtidy.A.dylib
    0x920bb000 - 0x9210cff9  com.apple.QuickLookFramework (3.2 - 500.18)  /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x9210d000 - 0x921ddffb  com.apple.ImageIO.framework (3.1.2 - 3.1.2) <2092785C-795A-3CDF-A1B4-6C80BA3726DD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x9224d000 - 0x9224eff7  libsystem_sandbox.dylib (??? - ???) <5CFCCFB7-CF29-3E04-801D-8532AE004768> /usr/lib/system/libsystem_sandbox.dylib
    0x9224f000 - 0x92651ff6  libLAPACK.dylib (??? - ???) <00BE0221-8564-3F87-9F6B-8A910CF2F141> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x9265d000 - 0x9266bfff  libdispatch.dylib (187.10.0 - compatibility 1.0.0) <1B857064-288D-3919-B81A-38E9F4D19B54> /usr/lib/system/libdispatch.dylib
    0x926a0000 - 0x92718ff8  com.apple.CorePDF (3.1 - 3.1) <0074267B-F74A-30FC-8508-A14C821F0771> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
    0x92719000 - 0x92727ff7  libxar-nossl.dylib (??? - ???) <5BF4DA8E-C319-354A-967E-A0C725DC8BA3> /usr/lib/libxar-nossl.dylib
    0x92728000 - 0x9272fff7  libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <47DB9E1B-A7D1-3818-A747-382B2C5D9E1B> /usr/lib/system/libsystem_notify.dylib
    0x92730000 - 0x927fbfff  libsystem_c.dylib (763.13.0 - compatibility 1.0.0) <52421B00-79C8-3727-94DE-62F6820B9C31> /usr/lib/system/libsystem_c.dylib
    0x92804000 - 0x92b4aff3  com.apple.HIToolbox (1.9 - ???)  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x92b4b000 - 0x92b73ff7  libxslt.1.dylib (3.24.0 - compatibility 3.0.0)  /usr/lib/libxslt.1.dylib
    0x92b87000 - 0x92b87fff  com.apple.Accelerate (1.7 - Accelerate 1.7) <4192CE7A-BCE0-3D3C-AAF7-6F1B3C607386> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x931c9000 - 0x93498ffb  com.apple.security (7.0 - 55148.6) <8DF67BDD-C98F-3B7E-AC63-D468407FA82D> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x934aa000 - 0x934c8ff7  libsystem_kernel.dylib (1699.32.7 - compatibility 1.0.0) <79179F83-457A-3539-A76B-E960D2108109> /usr/lib/system/libsystem_kernel.dylib
    0x934c9000 - 0x934c9fff  com.apple.Carbon (153 - 153) <63603A0C-723B-3968-B302-EBEEE6A14E97> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x934ca000 - 0x934f7ff9  com.apple.securityinterface (5.0 - 55022.6) <0FA3E84B-B5FF-3A58-A408-46280982CACC> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
    0x9368e000 - 0x93696ff3  liblaunch.dylib (392.39.0 - compatibility 1.0.0) <9E6135FF-C2B1-3BC9-A160-B32D71BFA77C> /usr/lib/system/liblaunch.dylib
    0x936c0000 - 0x938dcff7  com.apple.imageKit (2.1.2 - 1.0) <71FC9A62-4E07-307C-8E6B-4DE7661DC0A3> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
    0x938f3000 - 0x93a11fec  com.apple.vImage (5.1 - 5.1) <7757F253-B281-3612-89D4-F2B04061CBE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x93a12000 - 0x93a1cff0  com.apple.DirectoryService.Framework (10.7 - 146) <59061A4B-D743-3A34-B142-7BE2472BBC2D> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x93a1d000 - 0x93a7effb  com.apple.audio.CoreAudio (4.0.3 - 4.0.3) <7A14BE52-6789-3CE3-9AE9-B733F4903EB1> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x93a7f000 - 0x93a88fff  libc++abi.dylib (14.0.0 - compatibility 1.0.0)  /usr/lib/libc++abi.dylib
    0x93a98000 - 0x93a9aff9  com.apple.securityhi (4.0 - 1)  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x93a9b000 - 0x93bacff7  libJP2.dylib (??? - ???) <2B5EB147-F845-30DF-87C4-D2D3C3D0680A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x93bad000 - 0x93bfeff9  com.apple.ScalableUserInterface (1.0 - 1) <3C39DF4D-5CAE-373A-BE08-8CD16E514337> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
    0x93bff000 - 0x93f09ff3  com.apple.Foundation (6.7.2 - 833.25) <4C52ED74-A1FD-3087-A2E1-035AB3CF9610> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x93f0c000 - 0x93f5bffb  com.apple.AppleVAFramework (5.0.16 - 5.0.16) <1188E7AB-76FE-343F-9108-30CD67E5A37B> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x93f5c000 - 0x93f5cff0  com.apple.ApplicationServices (41 - 41)  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x93f5d000 - 0x93f79ff5  com.apple.GenerationalStorage (1.0 - 126.1)  /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x93f7a000 - 0x93f7cff7  libdyld.dylib (195.6.0 - compatibility 1.0.0) <1F865C73-5803-3B08-988C-65B8D86CB7BE> /usr/lib/system/libdyld.dylib
    0x93f7d000 - 0x9408cff7  com.apple.DesktopServices (1.6.5 - 1.6.5)  /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x9408d000 - 0x940efff3  libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <266CE9B3-526A-3C41-BA58-7AE66A3B15FD> /usr/lib/libstdc++.6.dylib
    0x94243000 - 0x9471fff6  libBLAS.dylib (??? - ???) <134ABFC6-F29E-3DC5-8E57-E13CB6EF7B41> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x9473b000 - 0x9473eff7  libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <7F6C14CC-0169-3F1B-B89C-372F67F1F3B5> /usr/lib/system/libcompiler_rt.dylib
    0x9473f000 - 0x94773ff3  libTrueTypeScaler.dylib (??? - ???)  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
    0x94774000 - 0x9499fffb  com.apple.QuartzComposer (5.0 - 236.10) <416993F4-2868-35FF-90DE-34C93D83574F> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
    0x94de7000 - 0x94e11ff1  com.apple.CoreServicesInternal (113.19 - 113.19)  /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x94e12000 - 0x94e1aff3  libunwind.dylib (30.0.0 - compatibility 1.0.0)  /usr/lib/system/libunwind.dylib
    0x94e1b000 - 0x94e1bfff  com.apple.vecLib (3.7 - vecLib 3.7) <8CCF99BF-A4B7-3C01-9219-B83D2AE5F82A> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x94e36000 - 0x94e86ffa  libTIFF.dylib (??? - ???)  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x94f07000 - 0x9506afff  com.apple.QTKit (7.7.1 - 2339) <163FBDDD-0458-378F-84DD-CB0F603A259E> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x9506b000 - 0x950acff9  libcurl.4.dylib (7.0.0 - compatibility 7.0.0) <9FD420FB-7984-3A07-8914-BB19E687D38B> /usr/lib/libcurl.4.dylib
    0x950ad000 - 0x950b3fff  libGFXShared.dylib (??? - ???) <9C9834EB-B794-38C8-9B90-31D8CB234F86> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x950c0000 - 0x950d6ffe  libxpc.dylib (77.19.0 - compatibility 1.0.0) <0585AA94-F4FD-32C1-B586-22E7184B781A> /usr/lib/system/libxpc.dylib
    0x950d7000 - 0x950e7fff  libsasl2.2.dylib (3.15.0 - compatibility 3.0.0)  /usr/lib/libsasl2.2.dylib
    0x95101000 - 0x95218fe9  com.apple.WebKit (7534.57 - 7534.57.7) <85DAC34E-86A1-380F-B166-56630C9B0BD5> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
    0x95219000 - 0x95295ff3  libType1Scaler.dylib (??? - ???)  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
    0x95297000 - 0x9529aff7  libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <69357047-7BE0-3360-A36D-000F55E39336> /usr/lib/system/libmathCommon.A.dylib
    0x9529b000 - 0x952b5fff  com.apple.Kerberos (1.0 - 1)  /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x952b6000 - 0x952bcffb  com.apple.print.framework.Print (7.4 - 247.3)  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x952bd000 - 0x952c0ffb  com.apple.help (1.3.2 - 42)  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x95323000 - 0x954d7ff3  libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <4AFF6FC3-6283-3934-8EFC-CA227CA11164> /usr/lib/libicucore.A.dylib
    0x954d8000 - 0x95501fff  com.apple.shortcut (2.1 - 2.1) <60000F49-6309-34B1-88A1-588DC566C8DF> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
    0x95502000 - 0x9552cff0  libpcre.0.dylib (1.1.0 - compatibility 1.0.0) <5CAA1478-97E0-31EA-8F50-BF09D665DD84> /usr/lib/libpcre.0.dylib
    0x9552d000 - 0x9552efff  libDiagnosticMessagesClient.dylib (??? - ???)  /usr/lib/libDiagnosticMessagesClient.dylib
    0x9552f000 - 0x95544fff  com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <92AADDB0-BADF-3B00-8941-B8390EDC931B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x95749000 - 0x9574cffd  libCoreVMClient.dylib (??? - ???)  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x9574d000 - 0x961e2ff6  com.apple.AppKit (6.7.5 - 1138.51)  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x961e3000 - 0x96205ffe  com.apple.framework.familycontrols (3.0 - 300) <6735D7ED-7053-3AB8-B144-E7F70A124CCD> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
    0x96206000 - 0x9635cfff  com.apple.audio.toolbox.AudioToolbox (1.7.3 - 1.7.3)  /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x9635d000 - 0x967d2ff7  FaceCoreLight (1.4.7 - compatibility 1.0.0) <3E2BF587-5168-3FC5-9D8D-183A9C7C1DED> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
    0x967d4000 - 0x967d8ff7  com.apple.OpenDirectory (10.7 - 146) <4986A382-8FEF-3392-8CE9-CF6A5EE4E365> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x967d9000 - 0x967edfff  com.apple.CFOpenDirectory (10.7 - 146) <9149C1FE-865E-3A8D-B9D9-547384F553C8> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x967ee000 - 0x967efffd  libCVMSPluginSupport.dylib (??? - ???) <4B0476F9-950D-3EB7-BD83-F65AF0B05F0E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x96842000 - 0x96846ff3  libsystem_network.dylib (??? - ???) <62EBADDA-FC72-3275-AAB3-5EDD949FEFAF> /usr/lib/system/libsystem_network.dylib
    0x96847000 - 0x968a0fff  com.apple.HIServices (1.21 - ???) <91EC636D-AC27-3332-BA1C-FD7301917429> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x968a1000 - 0x968a1fff  libOpenScriptingUtil.dylib (??? - ???)  /usr/lib/libOpenScriptingUtil.dylib
    0x96bd2000 - 0x96c59fff  com.apple.print.framework.PrintCore (7.1 - 366.3)  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x96c5a000 - 0x96c89ff7  libsystem_info.dylib (??? - ???) <37640811-445B-3BB7-9934-A7C99848250D> /usr/lib/system/libsystem_info.dylib
    0x96c8a000 - 0x96c8effa  libcache.dylib (47.0.0 - compatibility 1.0.0) <56256537-6538-3522-BCB6-2C79DA6AC8CD> /usr/lib/system/libcache.dylib
    0x96c8f000 - 0x96c8ffff  libdnsinfo.dylib (395.11.0 - compatibility 1.0.0) <7EFAD88C-AFBC-3D48-BE14-60B8EACC68D7> /usr/lib/system/libdnsinfo.dylib
    0x96c94000 - 0x96f96fff  com.apple.CoreServices.CarbonCore (960.25 - 960.25)  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x96f97000 - 0x96f9cff7  libmacho.dylib (800.0.0 - compatibility 1.0.0) <943213F3-CC9B-328E-8A6F-16D85C4274C7> /usr/lib/system/libmacho.dylib
    0x96f9d000 - 0x96f9dffe  libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <7F0E8EE2-9E8F-366F-9988-E2F119DB9A82> /usr/lib/system/libkeymgr.dylib
    0x96f9e000 - 0x96fd4ff7  com.apple.AE (527.7 - 527.7) <7BAFBF18-3997-3656-9823-FD3B455056A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x96fd5000 - 0x96fd5fff  com.apple.quartzframework (1.5 - 1.5) <49B5CA00-083A-3D4A-9A68-4759A5CC35A6> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x96fd6000 - 0x9700aff8  libssl.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <567E922C-E64F-321B-9A47-6B18BF481625> /usr/lib/libssl.0.9.8.dylib
    0x97058000 - 0x97098ff7  com.apple.NavigationServices (3.7 - 193) <16A8BCC8-7343-3A90-88B3-AAA334DF615F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
    0x97102000 - 0x97102fff  com.apple.Cocoa (6.6 - ???) <5FAFE73E-6AF5-3D09-9191-0BDC8C6875CB> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x97103000 - 0x97106ffc  libpam.2.dylib (3.0.0 - compatibility 3.0.0) <6FFDBD60-5EC6-3EFA-996B-EE030443C16C> /usr/lib/libpam.2.dylib
    0x97107000 - 0x9737bff3  com.apple.CoreImage (7.99.1 - 1.0.1)  /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x97382000 - 0x973adfff  com.apple.GSS (2.2 - 2.0) <2C468B23-FA87-30B5-B9A6-8C5D1373AA30> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x973ae000 - 0x973b5ff8  libCGXCoreImage.A.dylib (600.0.0 - compatibility 64.0.0) <4F9DD9D1-F251-3661-A3C6-B1F550B084B0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
    0x973b6000 - 0x97431ffb  com.apple.ApplicationServices.ATS (317.12.0 - ???) <4D124B65-3D43-32E9-B296-3671347BB888> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x9748f000 - 0x9749affe  libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0)  /usr/lib/libbz2.1.0.dylib
    0x9749b000 - 0x9750ffff  com.apple.CoreSymbolication (2.2 - 73.2)  /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x97510000 - 0x975e6aab  libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <2E272DCA-38A0-3530-BBF4-47AE678D20D4> /usr/lib/libobjc.A.dylib
    0x975e7000 - 0x975eafff  com.apple.AppleSystemInfo (1.0 - 1) <0E02BA66-4EA6-3EA1-8D81-3D0DE36F1CE8> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
    0x9761c000 - 0x97664ff7  com.apple.SystemConfiguration (1.11.3 - 1.11) <68B92FEA-F754-3E7E-B5E6-D512E26144E7> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x97665000 - 0x97a59feb  com.apple.VideoToolbox (1.0 - 705.94) <8FCC2C08-2D4C-3A96-B57A-CAA56911120F> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x97a5a000 - 0x97cdffe3  com.apple.QuickTime (7.7.1 - 2339)  /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
    0x97ce0000 - 0x97d44fff  com.apple.framework.IOKit (2.0 - ???) <94827954-5906-36C4-819B-24CDAFD85C72> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x97d45000 - 0x97e3dff7  libFontParser.dylib (??? - ???) <71B33EB1-27F8-3C68-B940-FC61A3CFE275> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x97e3e000 - 0x97e4bfff  libGL.dylib (??? - ???)  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x97e4c000 - 0x97e8eff7  com.apple.CoreMedia (1.0 - 705.94) <10D5D25F-9BCB-3406-B737-23D9FDF2CC71> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x97e8f000 - 0x97e91ffb  libRadiance.dylib (??? - ???) <4721057E-5A1F-3083-911B-200ED1CE7678> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x97e92000 - 0x97ea9ff8  com.apple.CoreMediaAuthoring (2.0 - 891) <69D569FD-670C-3BD0-94BF-7A8954AA2953> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
    0x97eaa000 - 0x97f8bff7  com.apple.DiscRecording (6.0.4 - 6040.4.1) <08BADDAD-FA79-3872-9387-EEE2A9FAA2F0> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
    0x97f8c000 - 0x97fc9ff7  libcups.2.dylib (2.9.0 - compatibility 2.0.0) <007A1877-E981-3007-A8FA-9B179F4ED6D1> /usr/lib/libcups.2.dylib
    0x97fca000 - 0x98001fef  com.apple.DebugSymbols (2.1 - 87)  /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x98002000 - 0x98049ff5  com.apple.opencl (2.0.19 - 2.0.19) <7689E7B9-EE5A-3F74-8699-4CDED9162260> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x9804a000 - 0x980e6fff  com.apple.ink.framework (10.7.5 - 113) <05CAFB64-D3B8-3973-87EA-CB8BBE580F6B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x980f2000 - 0x98130fff  libRIP.A.dylib (600.0.0 - compatibility 64.0.0)  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x98131000 - 0x9813cffb  com.apple.speech.recognition.framework (4.0.21 - 4.0.21)  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x9813d000 - 0x981d3ff7  com.apple.LaunchServices (480.40 - 480.40)  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x981d4000 - 0x981f5fff  com.apple.framework.internetaccounts (1.2 - 3)  /System/Library/PrivateFrameworks/InternetAccounts.framework/Versions/A/InternetAccounts
    0x9822d000 - 0x98232ffb  com.apple.phonenumbers (1.0 - 47) <1830301D-5409-3949-9614-C43C62B39DDA> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
    0x98233000 - 0x9827cff7  libGLU.dylib (??? - ???) <9AF7AD51-16E3-3674-B60E-30EE499D7B46> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x9827d000 - 0x9827eff0  libunc.dylib (24.0.0 - compatibility 1.0.0) <2F4B35B2-706C-3383-AA86-DABA409FAE45> /usr/lib/system/libunc.dylib
    0x98558000 - 0x98684ff9  com.apple.CFNetwork (520.5.1 - 520.5.1)  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x98685000 - 0x98795fe7  libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <34E1E3CC-7B6A-3B37-8D07-1258D11E16CB> /usr/lib/libsqlite3.dylib
    0x987a3000 - 0x987c8ff9  libJPEG.dylib (??? - ???) <743578F6-8C0C-39CC-9F15-3A01E1616EAE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x987cc000 - 0x9881effb  com.apple.CoreMediaIO (216.0 - 3199.8)  /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
    0x98822000 - 0x9882ffff  com.apple.KerberosHelper (3.0 - 1.0) <0E16B080-3931-3D3E-A786-419C24B44B02> /System/Library/PrivateFrameworks/KerberosHelper.framework/Versions/A/KerberosHelper
    0x98886000 - 0x98896ff7  libCRFSuite.dylib (??? - ???) <94E040D2-2769-359A-A21B-DB85FCB73BDC> /usr/lib/libCRFSuite.dylib
    0x98897000 - 0x988a2fff  libkxld.dylib (??? - ???) <14E79D7A-B6C2-35C5-B56D-D343BEC2A106> /usr/lib/system/libkxld.dylib
    0x988a3000 - 0x98985fff  com.apple.backup.framework (1.3.5 - 1.3.5) <1FAE91F2-BCEF-387D-B5C4-412C464DA1BE> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x9899f000 - 0x989a8ffc  com.apple.DisplayServicesFW (2.5.4 - 323.3) <820C4B45-814A-3101-A1FA-044CA6D2FBC8> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
    0x989a9000 - 0x989a9fff  com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <22997C20-BEB7-301D-86C5-5BFB3B06D212> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x98ab3000 - 0x98b22fff  com.apple.Heimdal (2.2 - 2.0) <2E1B8779-36D4-3C62-A67E-0034D77D7707> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x98b23000 - 0x98bfaff3  com.apple.avfoundation (2.0 - 180.50) <7B7FDF30-AC40-3715-A409-B5A27F7B5585> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
    0x98bfb000 - 0x98c31ff4  com.apple.LDAPFramework (3.2 - 120.2)  /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x98c32000 - 0x98c55fff  com.apple.CoreVideo (1.7 - 70.3) <4234C11C-E8E9-309A-9465-27D6D7458895> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x98c56000 - 0x98c57fff  com.apple.TrustEvaluationAgent (2.0 - 1) <4BB39578-2F5E-3A50-AD59-9C0AB99472EB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x98c58000 - 0x98c63ffe  com.apple.NetAuth (3.2 - 3.2) <4377FB18-A550-35C6-BCD2-71C42134EEA6> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x98c64000 - 0x98c72fff  libz.1.dylib (1.2.5 - compatibility 1.0.0)  /usr/lib/libz.1.dylib
    0x98c73000 - 0x98c99ffb  com.apple.quartzfilters (1.7.0 - 1.7.0) <64AB163E-7E91-3028-8730-BE11BC1F5237> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
    0x98c9a000 - 0x98d27ff7  com.apple.CoreText (220.22.0 - ???)  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
    0x98d28000 - 0x98d28ff2  com.apple.CoreServices (53 - 53) <7CB7AA95-D5A7-366A-BB8A-035AA9E582F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x98d29000 - 0x98d4bff8  com.apple.PerformanceAnalysis (1.11 - 11) <453463FF-7C42-3526-8C96-A9971EE07154> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x98d4c000 - 0x98db4ff3  com.apple.ISSupport (1.9.8 - 56) <59225A65-41C1-35CA-9F29-229AC427B728> /System/Library/PrivateFrameworks/ISSupport.framework/Versions/A/ISSupport
    0x98df3000 - 0x98df6ff9  libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <16DCE20A-9790-369A-94C1-B7954B418C77> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
    0x98e34000 - 0x98e42fff  com.apple.opengl (1.8.1 - 1.8.1) <766AFB12-A2CB-3A55-B662-FC9FFCAE0008> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x98eea000 - 0x98eeefff  com.apple.CommonPanels (1.2.5 - 94)  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x98f5e000 - 0x98f67ff3  com.apple.CommonAuth (2.2 - 2.0)  /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x98f68000 - 0x98f6cffd  IOSurface (??? - ???)  /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x990b5000 - 0x990b6ff7  libquarantine.dylib (36.7.0 - compatibility 1.0.0) <46980EC2-149D-3CF7-B29A-401FB89C275D> /usr/lib/system/libquarantine.dylib
    0x990b7000 - 0x9914eff3  com.apple.securityfoundation (5.0 - 55116)  /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x9914f000 - 0x9916cff3  com.apple.openscripting (1.3.3 - ???) <0579A4CB-FD6F-3D7F-A17B-AC0F2CF11FC7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x9916d000 - 0x9941afff  com.apple.JavaScriptCore (7534.57 - 7534.57.3) <5AE5C3B8-D807-356B-80D9-4D0A706A10D1> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x9941b000 - 0x9941cfff  liblangid.dylib (??? - ???)  /usr/lib/liblangid.dylib
    0x994a7000 - 0x994aeffd  com.apple.NetFS (4.0 - 4.0)  /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x994af000 - 0x9959fff1  libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <9E5F86A3-8405-3774-9E0C-3A074273C96D> /usr/lib/libiconv.2.dylib
    0x9965e000 - 0x9969bfef  libGLImage.dylib (??? - ???)  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x9969c000 - 0x996feffb  com.apple.datadetectorscore (3.0 - 179.4) <3A418498-C189-37A1-9B86-F0ECB33AD91C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x9974a000 - 0x99a90fff  com.apple.MediaToolbox (1.0 - 705.94) <89D37021-C389-3CC5-A158-620ADCBD99EF> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x99a91000 - 0x99af9fff  libc++.1.dylib (28.4.0 - compatibility 1.0.0)  /usr/lib/libc++.1.dylib
    0x99afa000 - 0x99b21ff3  com.apple.framework.Apple80211 (7.4.1 - 741.1) <7F29673A-B030-34AF-B8CA-AB30DD63FFAB> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x99bd9000 - 0x99dd1ff7  com.apple.CoreData (104.1 - 358.14)  /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x99dd2000 - 0x99e16ff3  com.apple.framework.CoreWLAN (2.1.3 - 213.1) <8A99ADB8-4A3E-3B8E-A0E4-A39398C288EC> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x99e23000 - 0x99ee3ffb  com.apple.ColorSync (4.7.4 - 4.7.4) <0A68AF35-15DF-3A0A-9B17-70CE2A106A6C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x99ee4000 - 0x99eeeff2  com.apple.audio.SoundManager (3.9.4.1 - 3.9.4.1) <2A089CE8-9760-3F0F-B77D-29A78940EA17> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
    0x99eef000 - 0x99f0cfff  libresolv.9.dylib (46.1.0 - compatibility 1.0.0) <2870320A-28DA-3B44-9D82-D56E0036F6BB> /usr/lib/libresolv.9.dylib
    0x99f0d000 - 0x99ff0ff7  libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8)  /usr/lib/libcrypto.0.9.8.dylib
    0x99ff1000 - 0x9ad42fff  com.apple.QuickTimeComponents.component (7.7.1 - 2339) <0001FA3A-E33F-3699-8382-3110AC51244F> /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
    0x9ad43000 - 0x9ad53fff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <6D6F0C9D-2EEA-3578-AF3D-E2A09BCECAF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x9ad54000 - 0x9aeb6ffb  com.apple.QuartzCore (1.7 - 270.5) <6D0EC7FC-11E5-35FB-A08A-3B438E89FBDB> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x9af37000 - 0x9b1e9ff7  com.apple.AddressBook.framework (6.1.3 - 1091)  /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
    0x9bbc4000 - 0x9bc1fff3  com.apple.Symbolication (1.3 - 91) <4D12D2EC-5010-3958-A205-9A67E972C76A> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x9bc28000 - 0x9bc9efff  com.apple.Metadata (10.7.0 - 627.37)  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x9bc9f000 - 0x9bca6ff9  libsystem_dnssd.dylib (??? - ???)  /usr/lib/system/libsystem_dnssd.dylib
    0x9bca7000 - 0x9bcebfff  com.apple.MediaKit (12 - 602) <6E429DD7-8829-37DE-94AF-940FB70F2FB9> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x9bcec000 - 0x9bd0cff7  com.apple.RemoteViewServices (1.5 - 44.2) <11C87337-FF29-3976-A230-6387D96563C5> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x9bd1d000 - 0x9bda7ffb  com.apple.SearchKit (1.4.0 - 1.4.0)  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x9bda9000 - 0x9be81ff6  com.apple.QuickLookUIFramework (3.2 - 500.18)  /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
    0x9be82000 - 0x9be83fff  libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0)  /usr/lib/system/libsystem_blocks.dylib
    0x9c1f9000 - 0x9c3d0fe7  com.apple.CoreFoundation (6.7.2 - 635.21) <4D1D2BAF-1332-32DF-A81B-7E79D4F0A6CB> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x9c3ff000 - 0x9c4feffb  com.apple.DiskImagesFramework (10.7.4 - 331.7) <31A74A7E-E2AE-313D-A7C4-6DFCF0F22C9A> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
    0x9c4ff000 - 0x9c505ffd  com.apple.CommerceCore (1.0 - 17)  /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
    0x9c506000 - 0x9c507ff4  libremovefile.dylib (21.1.0 - compatibility 1.0.0) <6DE3FDC7-0BE0-3791-B6F5-C15422A8AFB8> /usr/lib/system/libremovefile.dylib
    0x9c50d000 - 0x9c520ff8  com.apple.MultitouchSupport.framework (231.4 - 231.4) <083F7787-4C3B-31DA-B5BB-1993D9A9723D> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x9c521000 - 0x9c561ff7  libauto.dylib (??? - ???) <984C81BE-FA1C-3228-8F7E-2965E7E5EB85> /usr/lib/libauto.dylib
    0x9c562000 - 0x9c5a5ffd  libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <6B35F203-5D72-335A-A4BC-CC89FEC0E14F> /usr/lib/system/libcommonCrypto.dylib
    0x9c5b7000 - 0x9c644fe7  libvMisc.dylib (325.4.0 - compatibility 1.0.0)  /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x9c6e8000 - 0x9c716fe7  libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <30189C33-6ADD-3142-83F3-6114B1FC152E> /usr/lib/libSystem.B.dylib
    0x9c723000 - 0x9c7a0fff  com.apple.PDFKit (2.6.4 - 2.6.4)  /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
    0x9c7a1000 - 0x9c7f4ff3  com.apple.ImageCaptureCore (3.1.0 - 3.1.0)  /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
    0x9c7f9000 - 0x9c856ffb  com.apple.htmlrendering (76 - 1.1.4) <409EF0CB-2997-369A-9326-BE12436B9EE1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
    0x9c857000 - 0x9cee3ff5  com.apple.CoreAUC (6.16.12 - 6.16.12) <9D51400F-B827-3BA7-87F5-954A1CDDAEA9> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0xb0000000 - 0xb001afe3 +com.adobe.ahclientframework (1.7.0.56 - 1.7.0.56) <928D8FAD-DEE7-F1D0-FE17-FA7F4E4C1E48> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
    0xba900000 - 0xba91bffd  libJapaneseConverter.dylib (54.0.0 - compatibility 1.0.0) <473499F3-8CB8-3372-98B0-8E3BCC1A3D80> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
    0xbab00000 - 0xbab21ff6  libKoreanConverter.dylib (54.0.0 - compatibility 1.0.0)  /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
    0xbb100000 - 0xbb103fff  libLatinSuppConverter.dylib (54.0.0 - compatibility 1.0.0) <39A543C1-2604-3AB8-8148-0D76D02CE501> /System/Library/CoreServices/Encodings/libLatinSuppConverter.dylib
    External Modification Summary:
      Calls made by other processes targeting this process:
        task_for_pid: 177
        thread_create: 0
        thread_set_state: 0
      Calls made by this process:
        task_for_pid: 0
        thread_create: 0
        thread_set_state: 0
      Calls made by all processes on this machine:
        task_for_pid: 10875
        thread_create: 0
        thread_set_state: 0
    VM Region Summary:
    ReadOnly portion of Libraries: Total=439.8M resident=171.6M(39%) swapped_out_or_unallocated=268.3M(61%)
    Writable regions: Total=1.3G written=564.3M(43%) resident=677.8M(51%) swapped_out=0K(0%) unallocated=642.6M(49%)
    REGION TYPE                      VIRTUAL
    ATS (font support)                 33.1M
    CG backing stores                 110.8M
    CG image                             84K
    CG raster data                      668K
    CG shared images                   3472K
    CoreGraphics                          8K
    CoreImage                             4K
    CoreServices                       4968K
    Java                              225.2M
    Java (reserved)                    9908K        reserved VM address space (unallocated)
    MALLOC                            856.6M
    MALLOC guard page                    80K
    Mach message                          8K
    Memory tag=240                     3776K
    Memory tag=242                       12K
    Memory tag=243                        4K
    Memory tag=249                      264K
    OpenCL                               40K
    Stack                             113.0M
    VM_ALLOCATE                        27.4M
    __CI_BITMAP                          80K
    __DATA                             19.3M
    __DATA/__OBJC                       200K
    __IMAGE                             528K
    __IMPORT                             72K
    __LINKEDIT                        101.9M
    __OBJC                             3364K
    __OBJC/__DATA                        40K
    __PAGEZERO                            4K
    __TEXT                            338.0M
    __UNICODE                           544K
    mapped file                       219.2M
    shared memory                      11.3M
    shared pmap                        4916K
    TOTAL                               2.0G
    TOTAL, minus reserved VM space      2.0G
    Mar 18, 2013 1:36 PM   in reply to jvon42
    After I posted the previous crash report, I attempted an experiment and found that I am able to duplicate the problem easily. Create a new AS2.0 file, draw a vector shape, then edit the control points with the subselection tool. I can move around the control point a few times, but it's not long before the application freezes and crashes.
    Mar 27, 2013 9:09 AM   in reply to jvon42
    I've been having a related issue where opening a large fla (about 100m) crashes flash constantly on a brand new out the box imac that has plenty of juice to run the program and all the appropriate updates.  after two days i ran across this gem.  not sure how old it is but regardless:
    http://helpx.adobe.com/flash/kb/mountain-lion-support-flash-profession al.html
    Mac OS X 10.8 (Mountain Lion) is not supported with Flash Professional CS6. The platform has not been tested with Flash. Therefore, Adobe recommends that you do not install Flash Professional CS6 on it. You could encounter any of the following issues if you run Flash CS6 on Mac OS X 10.8:
    • The color picker displays incorrect colors.
    • Flash Professional CS6 crashes when you use the keyboard shortcut (Command + Option + S) for Scale and Rotate.
    • You cannot open large FLA files.
    • The Stage and Timeline are slow.
    not sure what could be going on if you're not running mountain lion, but it might save you some time.
    I'm not even sure why they offer flash cs6 for os x without putting this warning right up front. it would seem like something a consumer would want to know before purchasing a product that is not recommended to be run on your system.
    hopefully they find a fix for this soon.
    not sure what's causing the subselection tool control point crash, but I would imagine it's related to the fact that apparently flash cs6 isn't supposed to be run on mountain lion at all.
    dunno if this is useful to everyone on this thread, but I lost a few days of work trying to get cs6 up and running on mountain lion before I came across this and now, unfortunately, i've just had to go back to my old hardware until adobe decides to find a fix for mountain lion (or apple finds a fix for flash cs6, who knows what the issue is).
    Mar 27, 2013 9:23 AM   in reply to AMLlys002
    I previously posted above and were having the same issues. However, I recently got a new iMac and am on Mountain Lion and am no longer having these issues (I'm on the most up-to-date version of CS6 as well). Perhaps it has something to do with RAM. I previously was running a 2009 17" MBP w/ 8GBs of RAM. Now, I'm running the latest BTO (2012/2013?) 27" iMac with 32 GBs of RAM. Think I've had Flash crash only once within the past month and a half or so since I've been using the new system but it wasn't from the Scale and Rotate shortcut (I believe I was just saving the file and accidentally hitting a few keys at the same time as cmd + S). Scale and Rotate works perfectly fine now as does everything else.
    Jun 18, 2013 2:43 AM   in reply to Line
    Here too, CS6 Crash on numeric scaling, I've sent countless bug reports after CS6 has crashed but to no avail. It's clearly an error, RAM problems or not... a good program should warn memory issues instead of crashing. Building in an autosave option in CS6 is not the solution Adobe!!
    Jun 18, 2013 7:09 AM   in reply to gritty_d
    FlashPro crash log (43).mdmp
    Enough said. Are you listening Adobe? To any of us? Do you care? I can zip them all up and send them to you if it will help you fix it...
  • kglad
    Jul 21, 2002
    Jun 18, 2013 7:40 AM   in reply to mhunter1964
    this is a user-to-user forum, not an official or unofficial adobe communication channel.
    Jun 28, 2013 1:29 AM   in reply to mhunter1964
    So... since the memory suggestion I've upgraded my MBP to 16GB but the 3rd time after transforming a 160x600px image CS6 crashes on me again.
    I'm glad with the 16GB but safe to say this didn't appear to be the solution for this specific problem...
    Jun 28, 2013 7:44 AM   in reply to gritty_d
    try taking out the old ram. really curious if that is the issue. Out of 5 artists here, only two of us have it really bad...
    Dec 4, 2013 3:58 AM   in reply to mhunter1964
    The bug is still there... *surprise*
    Dec 4, 2013 5:52 AM   in reply to boudewijndanser
    Hi boudewijndanser
    This Crash has been fixed in Flash CC. Please let me know if you still face this in any other scenario in Flash CC.
    Nipun
    Feb 18, 2014 6:43 AM   in reply to Nipun Asthana
    That's very nice. But there are still tons of people using CS5.5 and CS6.
    It's a bug that has been around for way too long, I'd expect it to be fixed in current versions too, not to be suggested to upgrade to a new version just to fix that bug...
    Feb 18, 2014 10:33 AM   in reply to boudewijndanser
    Problem is also that CS6 is the last version of Adobe's tools which does not require a monthly fee.
    I don't know about you but for me switching to a CC subscription feels like giving in to some sort of life-long drug-sustained-addiction. And surely... The former versions of Flash did not really make me feel like 'Chasing the Dragon'...
    At first I was quite sad that Flash was bit the dust in favour of the (at that time) much less powerful HTML5, but now the CC-subscription and the alternative tools/frameworks you can BUY for a single (or few) months CC subscription fee makes me switch even faster.
    It's catching up Adobe, give it a few years and you don't have to worry about bugfixes anymore...
    Mar 18, 2014 5:50 AM   in reply to Nipun Asthana
    Any news on fixing that in CS6?
    Mar 18, 2014 5:55 AM   in reply to boudewijndanser
    No news here. I'm working on legacy projects with AS 2, so I can't start using Flash CC to find out if the problem persists there.
    This is by no means a definite fix, but I think I've found that if I click and hold for a second before resizing a shape or moving a vector vertex point, I don't crash as much. Maybe I normally move to fast for Flash CS6 to handle, or maybe it's all just coincidence.
    Also, I've noticed that all my crash logs are related to Java. So, that might help someone narrow down the problem and find a fix - someone more technically minded than me!
