labrey
Posterize time / TIF Sequence
Sep 18, 2012 2:46 PM
Tags: #after_effects #export #output #render
Is it possible to export a TIF sequence from posterize time? I need to export one frame per minute, and not have to do it manually 60 times for an hour of footage.
Thanks!
    Sep 18, 2012 3:33 PM   in reply to labrey
    For a job like this, you may be better off using an editing application.  Most will let you defing the duration of stills, then you simply add them to the timeline and you're done.
    But you'll end up with an hour-long video file.  It seems like a lot of file space for 60 stills.  Do you have another way to play them back in order?
    Sep 18, 2012 11:10 PM   in reply to labrey
    Agree with Dave. It would be better to simply export them manually. 60 images really isn't that much. I've done exports this way with hundreds of images at times to patch up botched 3D renderings. It's merely a matter of patience and finding something to distract yourself while you hit Ctrl+Alt+Save repeatedly...
    Mylenium
