Hello,
InDesign CS4 has a "Corner adjustment for dashed stroke" feature which allows corners of a dashed stroke to have the dash part instead of a gap or a small part of a dash. Interestingly, I cannot find this feature in Illustrator CS4. I believe it is included in Illustrator CS5.
Is this feature indeed absent from Illustrator CS4? If so, is there a workaround?
Thanks.
- pattern brushes
- this script: http://park12.wakwak.com/~shp/lc/et/en_aics_script.html#dash_offset
Thanks Monika and W_J_T. I just tried pattern brushes, but I have trouble making corner connections that flow well as the size of my rectangle changes (I am applying the brush to a rectangle and have defined the side tile and outer corner tile). Perhaps you could point me to a tutorial on this subject as I might not be creating my pattern brush properly.
You could try this: http://help.adobe.com/en_US/illustrator/cs/using/WS714a382cdf7d304e7e0 7d0100196cbc5f-64d6a.html#WS714a382cdf7d304e7e07d0100196cbc5f-64d1a
In case you understand German:
North America
Asia Pacific
