GPS aware?
Sep 19, 2012 7:02 AM
In the new CS6, is it possible to browse the pictures and see them on a map.
All my photos include GPS data and I dont know how to view that!
  • Omke Oudeman
    Nov 27, 2004
    Sep 19, 2012 8:04 AM   in reply to zuzullo
    Not in Bridge sadly enough, many people do want this feature, or even good support for GPS data but it has not been realized jet.
    If you have a Mac use iPhoto for that function, works pretty good, for Windows I don't know but there seem to be good 3th party options available.
    PS Elements Northern America versions seems to have also the ability with Yahoo Maps but due to licensing this is only possible for the Northern America version
    Sep 21, 2012 2:50 PM   in reply to zuzullo
    In Bridge CS6, it's possible to view the GPS data itself, because there's a GPS panel within the Metadata panel for photos that have GPS info.
    But I don't know of a way to open that into a map. (In Lightroom there's a button next to the GPS data that takes you to a map.)
    May 5, 2013 9:56 PM   in reply to zuzullo
    You can edit the exif data in your pictures using Exif Pilot. Add the GPS data from an independent GPS (e.g.Windows 8 phone, hand held GPS). the GPS readings then appear in Bridge. Otherwise it is impossible to put them directly into Bridge if there is no GPS built into your camera. The numbers can then be used to find a location in Google maps, but you will have to copy and paste them - there is no direct method that I am aware of.
    May 6, 2013 7:11 AM   in reply to Omke Oudeman
    I thought iPhoto and Adobe don't mix as iPhoto puts the images in a hidden packet.
  • Omke Oudeman
    Nov 27, 2004
    May 6, 2013 3:10 PM   in reply to Curt Y
    I had to look back because it is an old thread but what I meant was that if you want to see GPS as it should meant to be you have to view the files in iPhoto itself. iPhoto uses a map  (Google Earth?) showing the locations of images having GPS info in the metadata.
    I don't know if you can add GPS info in iPhoto but in general, adding longitude and attitude data is not easy, especially when you want to be correct in location and have to look it up
