hanbrac
Is it possible to resave a pdf file and convert the text, in it to curves?
Sep 20, 2012 5:36 AM
    Sep 20, 2012 7:10 AM   in reply to hanbrac
    Hi hanbrac
    I'm not quite sure I know what your asking, but I'm guessing that you want to re-open a PDF file and change the text to outlines. If that's the case, you can try to open the PDF in Adobe Illustrator, select the text, convert to outlines and resave as PDF. Be careful in this though and make sure text and images have not changed appearance or position when opened in Illustrator. This also won't work if security has been applied to the PDF.
    [ signature removed by forum host ]
    Sep 20, 2012 7:53 AM   in reply to hanbrac
    Illustrator won't let you do this unless you own the font. Adobe in general insist you own fonts before doing much with them.
    Acrobat won't do it at all.
    Acrobat can optimize files back to older versions, perhaps your old workflow would work.
    Sep 20, 2012 2:57 PM   in reply to hanbrac
    I am assuming you can see the text, but it is being replaced with another font. You might try printing it to a new PDF with the replacement fonts or select the text and see if you can replace it with a font that you have (like the substitute font).
    Oct 31, 2012 8:31 AM   in reply to hanbrac
    The solution might be in the transparency flattener. If your pdf has transparent objects on it, you might use the transparency flattener to convert transparency to regular objects. While flattening Acrobat offers you a choice to convert fonts to outlines.
    The downside of this is that flattening breaks your design into smaller pieces overlapping each other. And when your PDF doesn't have any transparency yet, you would have to add a small transparent object (hardly or not visible because it contains 1%yellow) on each page.
    The other solution would be to make use of Enfocus Pitstop Professional. This plugin for acrobat had capabilities to do what you are asking for (provided that you have the actual fonts installed on your computer).
    Oct 31, 2012 9:03 AM   in reply to peter_maas
    You would also need the funds to Purchase enfocus.
