CFHTTP "Connection Failure"
Sep 20, 2012 11:49 AM
Hello,
We're attempting to connect to an xml feed using some CFHTTP code that has been working for some time. We moved to a new CF10 server and have started running into issue, now persistenly, where we receive a "connection failure" response.
I took a look at several related postings and added a number of cfhttpparam's as follows:
<cfhttpparam type="header" name="Accept-Encoding" value="*" />
<cfhttpparam type="Header" name="TE" value="deflate;q=0">
<cfhttpparam type="header" name="accept-encoding" value="no-compression" />
<cfhttpparam type="header" name="accept-encoding" value="deflate;q=0?">
<cfhttpparam type="header" name="te" value="deflate;q=0?">
No combination of the above has worked. i tried a CFdump and got this result:
struct
Charset[empty string]
ErrorDetailI/O Exception: Permission denied: connect
FilecontentConnection Failure
Header[empty string]
MimetypeUnable to determine MIME type of file.
Responseheader
struct [empty]
StatuscodeConnection Failure. Status code unavailable.
TextYES
Does anyone have some suggestions?
    Sep 20, 2012 1:06 PM   in reply to ggantzer2
    It's an HTTPS URL you're hitting, right?
    It is likely a certificate issue.
    The certificate chain for that site was probably already loaded into the certificate store for your previous install, then when you installed CF10 you got a new JVM with a new cert store. You' ll probably need to import the cert chain again.
    Instructions: http://helpx.adobe.com/coldfusion/kb/import-certificates-certificate-s tores-coldfusion.html
    You'll need to figure out where your cacerts file is, and your keytool executable. But after you do that, the instructions should be the same.
    Jason
    Sep 20, 2012 1:34 PM   in reply to ggantzer2
    If it is not SSL then my only thoughts are firewall or DNS issues.  Did you hit it from a browser on the same machine as the CF server that is having trouble?
    Jason
    Sep 20, 2012 2:42 PM   in reply to ggantzer2
    Can you ping the site in question?  Even if the site does not respond to ping, the question I am wondering if can you resolve the IP of the site on a ping?
    jason
