I was getting the generic 'failed to install' message but now I'm getting the 'error code: A12E1' one that I came across when searching through the forums. The solutions I came across did not fix the problem for me and I'm finding several discussion where the problem is never solved or at least the solution isn't posted.
Any other solutions floating around???
I see these two forum posts http://forums.adobe.com/message/4396482#4396482 and http://forums.adobe.com/message/4602195#4602195 that have solutions that solved the 'error code: A12E1' error for some customers. Combining the steps this should work:
Things are not labelled in an obvious and intuitive way in the Adobe Cleaner Tool.
You need to select 'Creative Cloud' from the drop-down in the top right, then highlight 'Creative Cloud Installer' (which is what the Adobe Application Manger aka AAM is called here), and then click the button 'Cleanup selected'.
I spent over an hour today with tech help trying to fix this problem. I had received info that Creative Cloud had new features. Then I got a message to open Application Manager to download new features. AM wanted to update itself. I crashed -- multiple times.
I finally followed the above instructions.
I used the Support Advisor with no errors showing.
I downloaded and used the Adobe Cleaner. it opened in DOS, not in a graphics interface as shown above. I cleaned and got error messages that I ignored.
Finally I renamed OOBE as directed above. I reinstalled AM (version 6.2_all). Magic. it worked -- on both my computers (desktop, laptop, same error, same time--go figure).
Hint: do not move AM as a quick start icon to the desktop. Leave it in the usual START menu. Don't know why but that seems to be a problem (I got that from the Tech who was more baffled by the problem than I was).
I bet many others are about to hit this wall, with a never ending circle of wrong Adobe instructions.
Adobe MUST get their act together with thisa cloud thing. The current set-up is a total disaster.
Hoodedfang
The experience with the Adobe Cleaner Tool on Windows is different. Here are the steps:
Here are screen shots:
Yes, that’s EXACTLY what I got – not the graphic screens as shown the thread (under your name) dated Sept 20, 2012.
The real point is the tech guy I spoke with (for about an hour) was not aware of the ‘fix’.
This is the second time (third if you count the second compute) that I’ve had to remove or rename the OOBE file. Nobody seems to know why or why Adobe’s installer programs are not making the fix. The tech guy sent me a link to a patch file which was just another copy of AAM (that’s not good policy).
As a software reviewer for a Canadian magazine I cannot recommend the Suite to anyone who is not super aware of how to delve into hidden files etc.
This is simply not good enough and someone at Adobe needs to fix the problem
Peter Walpole
Hoodedfang
I ran the cleanup tool for windows, as described above, and reinstalled AAM. But I am still unable to install any app from the cloud. In the case of Acrobat XI, I had to get the trial and it then recognized my cloud membership. Using AAM, it seems to go through the download and extract process, but then always dispplays the error message "AAM is corrupted and needs to be reinstalled." Without AAM working I cannot get Edge, which does not have a trial download. Something is very wrong here.
I finally solved my issue by removing every Adobe app that I had, deleting every Adobe folder on my OS drive, running CCleaner and AdobeCreativeSuiteCleanerTool in sequence several times with a restart in between each time.
Now AAM has installed successfully, and I am installing Adobe apps from the cloud one at a time.
I still don't know what caused the problem in the first place, but I'm pretty sure it is related to some dysfunction between some Adobe products. I had perpetual versions of both CS5.5 and CS6 at the same time that I started using the cloud. I then installed Creative Cloud Connection, which as I remember it was when the issue first started. For the time being I am staying away from CCC, but will install some perpetual apps at some point to see if that issue comes back.
Hey Ken, Have ran this tool around 60+ times, others have also done the same thing and a new thread has been opened at http://forums.adobe.com/message/4969128#4969128
This is becoming a more common problem and it hasent been fixed, I even reinstalled the operating system and still the error shows.
@OliverBryant1 - Not being able to install the Adobe Application Manager (AAM) and a paid subscription saying it is a trial are two different issues. Photoshop after the most recent update saying it is a trial is an issue a lot of customers have run into and we are working on a fix. The workaround is to choose License This Software and sign in again, or uninstall Photoshop and reinstall it without the most recent update until there is a fix.
Are you not able to install AAM or are you running into Photoshop saying it is a trial? Which OS are you using?
North America
Asia Pacific
