Hello there, I've tried doing some searches regarding this and found nothing. We have around 6 scheduled tasks on a fresh install of CF10 on our server, fully up to date. I just found out
from one of my programmers that they cannot edit or delete any of the tasks that they created (This occured before updating CF10). However, if I create a new scheduled task, I am able
to modify and delete it.
On the old ones, I recieve an "XML Site Map Error".
Any thoughts?
ColdFusion10\cfusion\lib\neo-cron.xml I guess you could manually edit neo-cron.xml and delete offending lines. Take care make a copy of or backup first (case I give you bad direction). You may need to stop CF10 application service to apply edit changes. Add tasks again thru CFadmin once CF10 application service is started.
HTH, Carl.
