chamila.fernando
How to invoke Java class from post.POST.jsp
Sep 25, 2012 5:51 AM
Tags: #java #class #to #from #how #method #the #is #undefined #invoke #post.post.jsp
Hi All,
I am trying to invoke a simple java method from post.POST.jsp
I am getting below exception while doing it.
org.apache.sling.api.scripting.ScriptEvaluationException: org.apache.sling.scripting.jsp.jasper.JasperException: Unable to compile class for JSP:
An error occurred at line: 32 in the jsp file: /apps/mywebsite/components/customFormAction/post.POST.jsp
The method test() is undefined for the type DatasourceUtil
29:
30:           ///
31:          com.day.test.datasource.DatasourceUtil dsUtil = new com.day.test.datasource.DatasourceUtilImpl();
32:          dsUtil.test();
33:           //dsUtil.validateLogin(request.getParameter("username"), request.getParameter("password"));
34:
35:           ////
It appears to resolve the class correctly. I could run the code, if I only comment  dsUtil.test();. As soon as I uncomment, it gives above error.
In the Utill I have a simple void method which will print a simple text. My package structure is as follows.
any help will be great
Tx
    Sep 25, 2012 1:15 PM   in reply to chamila.fernando
    1.  In the interface [1] not the implementation[2] have u defined the method test?
    2.  If it is implemented, Change the bundle version in bnd file and make a new build. Then from felix console verify the latest version reflected in the bundles.
    If 2 works & you are going to make lot of frequent changes then give the version as snapshot till it get stable.
    [1]  com.day.test.datasource.DatasourceUtil
    [2]   com.day.test.datasource.DatasourceUtilImpl
