joshgilson
ERROR on version 1.1.0906 using CreateJS on Flash CS6
Sep 25, 2012 2:35 PM
Tags: #error #flash #html5 #cs6 #createjs
I've installed the new version of CreateJS with Adobe Flash Pro CS6 and when I export I get this error:
"An unexpected error occurred during export. [JSX]
The following JavaScript error(s) occurred:"
Please help!
Thanks.
-Josh
    Sep 25, 2012 6:39 PM   in reply to joshgilson
    Is it with any particular file? If so, are you able to share that file, or isolate it down to the piece of content that is causing this issue?
    Sep 27, 2012 5:04 AM   in reply to joshgilson
    I'm getting the same error, did you find a solution?
    Oct 26, 2012 10:21 AM   in reply to joshgilson
    hi Josh - with the file you provided I am not getting the same error. Instead I am getting a series of DUPSYM errors. I did some testing, and this is related to special characters < and > in some symbol names. We will absolutely be fixing this in the next version.
    If you (or anyone) has an FLA that generates the other error:
    Please send me the FLA or attach it to this thread. It is usually caused by abnormalities in the FLA, and we are hoping to isolate these to avoid this error in future versions.
    Thanks!
    Nov 13, 2012 4:52 PM   in reply to Grant_Skinner
    Have the same error, not sure if I can attach the FLA to this post, don't see where I can.
    Nov 26, 2012 2:07 PM   in reply to joshgilson
    Thank you Google!
    Getting this with all of my .FLAs, even the simple 441kB preloader FLA I made for all my Flash Projects. Says this in addition to the error:
    Unable to save the document as "C:\Users\<Username Removed>\AppData\Local\Adobe\Flash CS6\en_US\Configuration\CreateJS\.TMP.fla".
    Thought it might be an issue because I didn't install the Adobe Cloud stuff on the C drive (it's an SSD, I don't need to wear it out). So ran it 'As Admin' and still getting the error
    The preloader was done in CS5 (yes I even tried it after CS6 converted it).
    Nov 26, 2012 2:42 PM   in reply to illutian
    illutian - That sounds like somehow your Flash configuration directory has been made read-only.
    Nov 26, 2012 6:20 PM   in reply to Grant_Skinner
    Odd that Adobe would set it up as read-only.
    But meh, stuff doesn't work:
    WARNINGS:
    Feature not supported: Embedded fonts.
    Text support is limited. It is generally recommended to include text as HTML elements (see DOMElement). (3)
    Shadow and glow filters are very expensive effects. (5)
    Input and static text fields are published as dynamic text fields. (3)
    Frame numbers in EaselJS start at 0 instead of 1. For example, this affects gotoAndStop and gotoAndPlay calls.
    Feature not supported: Compiled clips. (2)
    Oh well, guess I'll have to learn the HTML5
    Unless, I want to make sites that give seizers
    Dec 10, 2012 9:37 AM   in reply to joshgilson
    I'm getting the "JSX" error as well. Simple SWF that loads another using the Loader class. Anyone know if this is supported?
    I tried Swiffy (v4.9.0) also, it says AS3 is not supported.
    Dec 11, 2012 12:07 AM   in reply to RobRusher
    It appears this CreateJS needs to be done with CS6's method of making a FLA. I made most of my stuff in CS5's Flash, and when you save it CS6 will say it needs to convert to the new format, and that files will no longer be readable in earlier versions.
    After that (save, exit, re-open), CreateJS seems to work.
    -Can't say how it'll do with non-Adobe Flash Makers.
    Jan 8, 2013 9:50 PM   in reply to Grant_Skinner
    I get error with Flash Pro CS6 trial & CreateJS 1.0.2
    Please check...
    You can download my FLA file
    Jan 13, 2013 6:35 AM   in reply to Grant_Skinner
    Not a very useful message in my case because there are no details included.
    I too have this error.  I'm not sure how to attach my flash file?
    Jan 13, 2013 6:58 AM   in reply to zzz111222
    - Saved my file as Flash CS6 uncompressed file (*.xlf) using Save As.. command from the menu.  Then ran CreateJS again and at least got error messages this time - they are listed below.  This one is causing substantial grief - Frame numbers in EaselJS start at 0 instead of 1. For example, this affects gotoAndStop and gotoAndPlay calls. (12)
    Tried Save As back to Flash format but still get the same errors.
    WARNINGS:
    Text support is limited. It is generally recommended to include text as HTML elements (see DOMElement). (13)
    Bitmap fills will not be transformed in the output, and may render differently. (9)
    Feature not supported: Color effects. (30)
    Shadow and glow filters are very expensive effects. (2)
    Input and static text fields are published as dynamic text fields. (11)
    Feature not supported: Blend modes except normal and add.
    Feature not supported: Filters other than shadow and glow. (2)
    Feb 7, 2013 3:51 PM   in reply to zzz111222
    Hi!
    I have created about 30 flash pieces over the past 7 years.  They have all been built using AS2 and are all very similar in function. Most of them have been saved as Flash Version CS4 because that's what I've been using over the years.  I now need to convert them to run on mobile devices.  I downloaded the trial version of Flash CS6 and CreateJS to see if I would have any luck with getting them to publish and work on an iPad.  I have saved the  file as a CS6 Flash file and have run the publish function from the CreateJS panel. I continually get this:
    Any help would be much appreciated! I don't see a way to post the actual file to this forum, so please let me know how I can get it to you if you need to take a look at it.
    Thanks!
