There have been longstanding bugs in the PSE Organizer regarding the writing of Tags and other metadata to files.
Specifically, the two bugs that I am aware of are:
I call on Adobe to state clearly that they have fixed these bugs, or not.
I ask users of PSE11, if you have an opportunity to observe PSE11's performance on these issues, to report what you experience.
Thank you.
I'm not familiar with issue number one, but I'll more into it.
As for issue number two, I am aware of this one (having reported it to the engineers myself...). It has not been fixed in PSE11.
This is considered as a feature request rather than a bug, as this prevents data loss from accidentally removing keywords. To get this feature added into PSE, we need to advocate for change. This issue has already been brought up on the Feedback site (where feature requests and bugs are reported), but only one person is asking for this change. I'll check to see if others are looking for the same. But it is important that you add your name to the list:
http://feedback.photoshop.com/photoshop_family/topics/unwanted_keyword _tags_in_metadata
As far as #1, If you can't replicate the probelm, then it must be working properly. That's really all we need to know.
As far as #2, if you make a change in PSE, and then expect that change to be written to the file, and it is not, then it is a bug. It can't be a feature to have different metadata in the Organizer's database and in the photo file, if you have asked PSE to write the metadata to the file.
I was quite expecting such an answer from Adobe. I must admit that writing the metadata to the file is not necessarily equivalent to update (replace) the metadata in the file from that in the catalog. For instance, you could imagine two different catalogs where you don't want to share all tags... yes, that's a bit far-fetched and I think that most users would prefer the way John R Ellis has implemented that feature in his psedbtool (for versions 6,7 and 8 only).
My prefered solution would be to set the user choice in the preferences. Either updating by 'add' or 'replace'.
In my opinion, the Adobe answer is baloney. If you ask PSE to write the tags to the photo file or sidecar, and it writes a DIFFERENT set of tags to the file than exists in the Organizer database, this is a BUG.
Adobe, if you are still listening, I will be letting people know in these forums and others that I am still skeptical of the ability of PSE to properly write tags to files, and I will specifically point to this thread where you say, essentially, that when PSE writes a DIFFERENT set of tags to the photo file than exists in the database, that this is a FEATURE. In fact, I have already said this in a different thread. It is a BUG that needs to be fixed.
I tend to agree with dj_paige...
isn't saying that it's a desired feature that it's not possible to remove a tag so that there is no accidental data loss the same as suggesting that when you try to delete a file in windows it shouldn't let you do that, in order to prevent data loss??
definitely a bug.
As I mentioned, I reported this behavior as a BUG to the engineers. The response from engineering was that this was not a bug, it was done on purpose. Remember, a bug is when an application is not behaving as intended (which is not the same as "behaving as expected"). In this case, because this is the way the application was designed, we have to view this in terms of a feature request: we want the application to behave in a different way. In order to have change, we have to prove to the engineers that we want this change to happen. In order to do that, we have to upvote the Feedback page I linked to above.
PSE 11 has implemented a functionality where IPTC keywords can be appended/overwritten from the metadata pane directly. Here is how you can achieve this.
1. Select the desired files in the grid for which metadata has to be edited.
2. From the Tags/Info pane on the right, click the Information pane.
3. Click "Add IPTC Information"
4. This would open up the Edit IPTC dialog, where you can edit/add/overwrite the IPTC information including the keywords.
And once this information is saved, this would be saved in the file.
Glad to know that !
Thanks to Paige for asking and Sourabh Gupta for pointing to a useful feature I would have totally missed otherwise!
EDIT:
That worked once, and now I am unable to see the "Add IPTC Information' ?
EDIT 2:
The 'Add IPTC Information' button only appears when SEVERAL items are selected. I did not find anything about this useful feature in the help file.
Hi MichelBParis,
This functioanlity is also available when a single file is selected. Here are the steps -
1. Select the desired file.
3. In the Metadata section, click the "Complete" button to view the detailed metadata (if detailed metadata is not shown already)
4. Click the three dots shown along the IPTC.
This would open up the Edit IPTC dialog.
Regards,
Sourabh
Here is the tutorial for the same : http://photoshopelementstips.blogspot.in/2012/11/how-to-edit-iptc-meta data-of-multiple.htmlhttp://photoshopelementstips.blogspot.in/2012/11/how-to-edit-iptc-meta data-of-multiple.html.
Hope that helps!
North America
Asia Pacific
