the server control script (<cf_server_home>/bin/coldfusion) shipped with ColdFusion 10 is partially broken.
On Linux, if sudo is configured with the env_reset option, the coldfusion status command fails immediately without giving any output.
Start and stop work fine, though.
To get status as well, I applied this patch to the script: http://pastebin.com/sJUN5Rj4
This fix works for me on RHEL6 64-bit.
Br,
Jan
Hi Jan, thanks for passing that news along for others who may trip over the problem.
Just one suggestion: you should also file a bug report (https://bugbase.adobe.com/), as there’s no guarantee that an Adobe rep will read this message, let alone respond to it, or fix the problem based on it.
Now don’t get me wrong, they may well respond here to a message observing a problem. There’s just no promise. If you file a bug report, those are read and responded to.
All that said, many do often file that report and then point out the problems here (even with the details, like you have below), for the benefit of those who might never notice it in the bug report. But then they also add a link to the bug report, so that others affected might add their vote in support.
Just something to consider.
/charlie
Thanks Charlie, that's a good suggestion. I didn't even know Adobe had a public bugtracker available.
Bug ID is 3339175.
