Liquid-Metal
Export DXF files not workable
Oct 2, 2012 6:36 AM
Tags: #export #dwg #ai #dxf #anchor_points
Good Afternoon all
Im really hoping someone can help me with this as I have spent many hours googling, youtube and many other methods trying to solve a constant problem im having.
Im trying to turn some vector images into a dxf file for laser cutting and im constantly banging my head against a wall with it as the files just wont work once converted over to dxf or dwg files.
I have a vector image in CS6 and have also tried in older CS5 or CS4, the image is already a .ai file and all the anchors and outline look fine so I make any small changes like spacing etc, I then try to save as a dwg or dxf in all different save preferences but normally as R13 dwg.
When I take this or any of my saved files into the cad software the laser machine software does not generally recognise there are even lines there so I started taking it into draftsite and saving as a R12 DXF which works but the dwg or dxf exported out of illustrator have sometimes hundreds of anchor points which where not there when it was a vector or the anchor points are not actually on the lines anymore they are way off outside the drawing.
How can I export out of illustrator without getting all these problems, I must be doing something stupid wrong out of pure lack of experience with it so appologise if this sounds stupid but would really love some advice and help with this as I have many files I need to get turned into workable dxf files.
Would appreciate any help and thanks for taking the time to read my post hopefully its not too confusing
Leon
    Oct 2, 2012 7:55 AM   in reply to Liquid-Metal
    Yes, you are using DXF/ DWG. Pardon the sarcasm, but you are simply exporting to a format that works completely differently from AI and to complicate matters, AI simply only supports a handful of these entities natively and will almost always convert stuff to polylines. It's simply AI's inability to better retain that info. Anyway, most CAD programs will happily import AI 88 files (which supports proper spline curves), so simply use that. And in the long run, simply forget about AI if this is crtitical stuff for CAD/ CAM/ CIM and do it right away in your CAD programs...
    Mylenium
    Oct 2, 2012 9:14 AM   in reply to Liquid-Metal
    For the extra points it might mean you will have to clear the guides before exporting. As Mylenium says try the AI88 level of saving. Should be in the second dialog on save.
    Oct 2, 2012 11:42 AM   in reply to Liquid-Metal
    As Larry said, I can only once more advise to try importing AI 88 files into CAD. Anything in AI that is not a straight line, an isolated simple path or a circle loses its Bezier magic in DXF/ DWG - AI will convert any shape to a bunch of straight lines if it uses the simplest Pathfinder operations. If you need a continuous path, your only option is to clean up that stuff in CAD. On the other hand, many exporters for milling/ cutting have tools to resample and rebuild curves as do the CAD programs themselves based on selecting the area and some reference points in the geometry, so it may not at all be that difficult - for the little gimmicks, anyway.
    Mylenium
    Oct 2, 2012 10:03 PM   in reply to Liquid-Metal
    Hi Liquidmetal, we use CS5 and use a plug-in called EXDXF-PRO, google EXFDXF-PRO and you will see the site, BABY UNIVERSE. Beware though, circles DO NOT come through completely circular, can't figure why since we've tried every setting there is to choose from. Apart from that, it works straight from Illustrator to our laser software.
    good luck,
    rushbudgie
    Oct 3, 2012 12:09 PM   in reply to Mylenium
    Illustrator 88 is not available in save dialog.  Is this an added feature from the "extras" folder on install disk or the Adobe site?
    Oct 3, 2012 12:15 PM   in reply to jeffhdesign
    Ai88 files can be saved out of old Illy which is version 7.0 or FreeHand.
    Nov 22, 2012 8:58 AM   in reply to Liquid-Metal
    hello,
    I've been having the same problem for many years. until I found a solution just recently.
    I'm running illustrator CS3 on mac and need to serve dxf files to a PC with solidworks on it.
    the trick goes as follows:
    -ungroup your artwork in illustrator, color only the outlines, no fillings.
    -go to object > path > simplify > straight lines
    from there on the dxf will export in a way that my solid works will nicely import it!
    try if it works for your needs. cheers stefan
    Nov 22, 2012 10:07 AM   in reply to blackeyer
    Sorry I forgot:
    before creating straight lines you may "add anchor points" (object > path > add anchor points) until your result is satisfactory...
    cheers, stefan
    Jan 28, 2013 6:00 AM   in reply to blackeyer
    Thanks mate, you just made my day :-)
    Jürgen
    Jan 28, 2013 6:04 AM   in reply to Juergen Schrader
    Oh, while we are at it:
    The operator said the units appear in inches while I used mm.
    I know that it's a simple calculation but is there a way to do it right from the beginning?
    Apr 14, 2013 11:01 AM   in reply to blackeyer
    This is also the method for getting line art imported into SketchUp Pro.
    Apr 14, 2013 11:02 AM   in reply to Juergen Schrader
    If you are looking for another method to preserve curve information, Adobe DXF/DWG will import into Solid Edge 2D (free) which can then be saved out to another DXF/DWG file, with correct units, too.  Solid Edge 2D is parametric, with a learning curve.  I've had similar issues getting Illustrator art to waterjet cutting services, as the Adobe DXF/DWG has "extra" information in the file header which prevents clean import on the waterjet software.
    May 4, 2013 10:14 AM   in reply to Liquid-Metal
    I convert Illustrator CS5 to DXF for a plasma cutter with success on a regular basis without additional plugins.  Not always, mind you, there is no doubt how finicky this process is.  I'm not CAD trained yet and come from Photoshop so I understand the want to work in Illustrator and the frustration of outputting.  I have spent a great deal of time studying this topic so will share my notes.
    The image below is what the DXF looks like when opened back up in Illustrator after outputting.   You can solve a lot of problems looking at it this way before burning time in other software or on a cutting machine of any sort.  This panel is part of a three section fire ring, the holes on each side are for bolting to other panels. all curved to make 180 degrees.  On the cutting software each file always has a random extra line but I don't think Illustrator is at fault with that.
    To have ANY success at all as a cutting file all elements need to have no fill (white box with red line through it, noobs) and with some stroke (0.0313 in the image below) so it comes through for the machine specific software to read.  A narrower line won't be read as easily and ends up with problems.  All guides must be deleted and all hidden elements must also be deleted as well or it will show up in a DXF.  This is annoying but just save off copies with that stuff intact...unless you have a better idea which I would love to hear about. Were this Photoshop I'd draw up all 21 required panels with the art on each layer and the frame as its own element and output them individually.  Can't though.
    As well, you need to make outlines of text and other elements (stroke border and deer/tree art in this case) and subsequently merge them all into one group otherwise you'll have cut marks separating elements and making the work fall apart if you actually cut it.   Bolt holes were placed on the frame then one by one sitting above the border object/path/divide objects below to make them actual holes.  They cannot be white fill dots on the black border.
    For the record this design may or may not work in steel. It is intended for 14 gauge material.  It is connected at the antlers, the question is if the tree will stand on its own OK or if it should be partially merged with the edge or top of the frame.
