Hi there,
I'm trying to export a web pdf with RGB color settings but it doesn't work. Everything looks good in the Indesign document and I've switched to RGB transparency blend space. When I export to a interactive pdf it comes out as a CMYK pdf and when I try a print pdf i just get the error: "1 problem (1 failure) was found with a background task: mydocument.pdf"
What could be wrong??
The RGB Colour Setting is only for how Transparency interacts - it's not a RGB setting for the entire document.
To make the PDF into RGB you need to go to the File>Export and choose PDF (INteractive) and that should make it RGB, but this has Spreads turned on by default in CS5.5 and prior, I think this was fixed in CS6.
If you are exporting from CS5.5 or below then choose PDF (Print) and choose the smallest file size option, and that is automatically set to convert to RGB - you can check that out in the Output area of the PDF Export Dialog Box.
I can see it on the colors. Our company logo is green, black and white and the green color tone in the logo is wrong on the exported pdf. I've done pdf documents in Photoshop and Microsoft Publisher with the logo and then the green tone is correct. I can also compare the pdf with the indesign document an see a clear difference in color tones.
The logo has a green gradient so I guess that means it's not a spot color logo?
A gradient can be made with a spot color. Spot colors have a spot color icon in the Swatches panel. You should be able to double-click the swatch and change it to process:
I want this pdf to be suited for the web so then I should use the INteractive export, right?
Are there interactive elements like buttons? If not PDF/X-4 should keep color unchanged.
Since you mention RGB, PDF and InDesign CS6, just thought I should mention that if you ever need to convert PDF to InDesign CS6, Markzware PDF2DTP can do that.
Is it impossible to export with RGB colors???
No. It sounds like you might have an RGB profile conflict—it could be something like a conversion from AdobeRGB to sRGB that shifts the color. Can you post a screen capture that shows the differences?
In Acrobat Pro you can check the color space of page items via Output Preview>Show. If you select CMYK does the logo show?
To export compliant RGB PDF documents, you need to "Print..." to the Adobe PDF printer profile. The Export... will not get compliant documents, but going via the print driver will. I am on Windows, and noticed the color shifts in Reader as well, did some exploring and by using the Print to PDF I get RGB PDF files that do not shift color.
Compliant to what—a PDF/X standard? Exported PDF/X-4 documents pass compliance preflight in AcrobatPro without a problem.
Maybe this a Windows thing, but on OSX I don't have any problem exporting RGB colors and getting them to preview the same in the latest versions of Acrobat, Reader, and Preview. Here's an out-of-gamut green exported as PDF/X-4:
In AcrobatPro the default simulation profile for a PDF/X-4 is the Output Intent profile which has to be a print profile—usually CMYK—so the green can preview as CMYK or RGB depending on the chosen simulation profile.
I think in earlier versions of Reader the display of PDF/X-4 was also through the Output Intent, so it might be the Reader version.
I've been having the same issue. If I print to PDF the issue does not occur, but I needed to Export as a PDF because the interactive doc format maintains hyperlinks. After much frustration I've found that the issue is linked to having any semi-transparent element on a page.
Each of the images are different pages from the same document. As you can see if there is a PNG with transparency, or a JPEG with a transparency applied in InDesign, the colors appear as CMYK "For Print" rather than the expected RGB.
Note that this document was setup for web (Document Setup > Intent > Web).
Unless there are some settings that I'm missing this sure seems like a bug Adobe should fix.
Where are you viewing the exported PDF? If it's AcrobatPro you might have a CMYK simulation profile set.
I tried exporting an interactive PDF with your colors and transparency, and it previewed correctly in AcrobatPro (sRGB simulation), Reader, and Preview. Here's AcrobatPro with different simulations:
SWOP:
Reader 9.5, Preview 5.03, Safari:
Thank you both for the quick reply.
Rob: I'm using Acrobat X to view. It seems that if CMYK simulation profile was set then all of the pages would render the same . The only variable on these images was the transparency but they render differently in the same document. Your test appears to be using a solid block of color with the transparency set to ~50%. I just check and yes, that form of transparency works fine. Please try again using a PNG 24 with transparency or by using the Gradient Feather Tool on an imported image. BTW, the transparency blend space is set to Document RGB.
Peter: If there are settings that are affecting this outcome that I'm not aware of then I can't really tell you what those settings are. Please let me know which settings I should report back on.
We need to know waht the transparency blend space is set for in ID and what PDF preset yiou are using (or if not using a preset, what acrobat compatibility is being used, and what settings you are using for color in the Output screen of the export dialog (for a print PDF) or give a screen capture of the interactive export dialog.
The color here is a placed JPEG—set your simulation profile to sRGB
The Transparency Blend Space in Acrobat could be different check the flattener preview:
What does your PDF look like in Acrobat Reader?
Rob, thank you, this was very helpful. The document appeared correctly in Acrobat Reader so the issue seemed to be with Acrobat Pro. The first suggestion didn't seem to help. Switching the simulation profile momentarily changes the look of the document, but upon closing the Output Preview dialog the colors switch back.
However, the second suggestion worked. Changing the Transparency Blend Space, applying it to the entire document, and then saving it appears to permanently change the doc - even when closing and re-opening in Acrobat Pro. It solves the problem, but only for that particular document. As a test, I exported another version of the same file from InDesign and I ran into the same issue. Even though the problem appears in Acrobat Pro it still seems like this is a problem with the ouput from InDesign.
Will I need to change the Transparency Blend Space for every document I output from InDesign inside Acrobat Pro or is there some setting in InDesign that will solve this issue?
I'm not sure why you are getting a CMYK blend space with an interactive PDF—I always get an sRGB blend space with ID interactive PDFs.
Are you actually making edits in AcrobatX? Why not just preview in Reader or a browser?
Have you tried a new document where you choose Web as the Intent from the New Document dialog?
I have been trying to export RGB green 255 from InDesign to PDF without much success.
After reading through this thread, I've decided the work-around of exporting to Interactive PDF,
then converting the 'Output intent' within Acrobat to Adobe 1998 (or sRGB, take your pick) does the trick for me.
Also, I've converted the RGB green 255 to process, not spot. Not sure if this makes a difference to my work-around.
This has been frustrating me all day! Working on a client document in InDesign RGB and Acrobat keeps rendering incorrect colour space.
Is there any way to remove this as a default once you export as Interactive PDF? It seems rather painful to have to change the Transparency Blend Space manually for each document.
North America
Asia Pacific
