This discussion is archived
Where is the Camera Raw 7.2 download?
Oct 3, 2012 5:57 AM
Tags: #missing #update #camera_raw_7.2
Adobe's web page "New Downloads" refers to a new download by "Adobe Camera Raw and DNG Converter"—but when downloading the self-extracting archive then it will contain DNG Converter 7.2 only (plus a bazillion of camera and lens profiles) but no Camera Raw 7.2. What gives?
    Oct 3, 2012 7:07 AM   in reply to 01af
    For the ACR plugin download, it’s available via CS6 or Elements 11. Launch one of the Adobe product, and go to “help-update” to get ACR 7.2 update. Thanks.
    Oct 3, 2012 7:13 AM   in reply to 01af
    Could you please explain a bit more re: “Using the Adobe products' update feature is not an option here?”
    Oct 3, 2012 7:33 AM   in reply to 01af
    Thank you for your quick response!
    “Updating is done manually, via a machine that has Internet connection but no Adobe products installed”
    You can’t use the adobe.com patcher installer, which was what we have been posting on adobe.com for the past few years either, on the machine you have no Adobe products installed.
    On the machine you have CS6/E11 and however you updated to ACR 7.1, use Adobe Updater method to update to ACR7.2, you can get 7.2 from the plugin location and move it to the other machine.
    Feel free to shoot me an email at mqi@adobe.com<mailto:mqi@adobe.com>
    Michelle
    Oct 3, 2012 7:42 AM   in reply to Michelle Qi
    Moving the plug-in from one machine to the other will not update the camera and lens profiles, which would be important for new camera support.
    Is it now Adobe’s policy to not supply a manually-installable update for Camera Raw except via personal e-mails to Adobe personnel?
  • Noel Carboni
    Dec 23, 2006
    Oct 3, 2012 8:38 AM   in reply to 01af
    01af wrote:
    This sentence doesn't make any sense, grammatically and logically. So once again: Where can I download the manual update file for Camera Raw 7.2, please?
    It makes sense to people who understand computers and files.  Here it is stated another way:
    The Camera Raw plug-in is embodied in one or two files only (depending on whether you have a Mac or a Windows x64 system).
    On a Mac it's Camera Raw.plugin.  On a PC the plug-in is named Camera Raw.8bi.  The file(s) are several tens of megabytes in size.
    In either case, if you copy those file(s) from the place(s) they are installed after a successful update to the place(s) they should be installed on your non-internet connected machines, you will have successfully applied the update manually.
    -Noel
    Oct 3, 2012 9:12 AM   in reply to 01af
    Looks like Adobe wants you to plug one of your PCs into the router to do the update; then locate and copy the two Camera Raw.8bi files (32-bit and 64-bit) to a memory stick, then locate and copy them to each of your other workstations. You might have to write a batch file to make this easier in future. That's progress!
    Oh well, at least it will probably do less damage than the built-in updater
    Oct 3, 2012 9:34 AM   in reply to 01af
    Oct 3, 2012 10:02 AM   in reply to 01af
    01af wrote:
    Thank you very much, deejjjaaaa! This is exactly what I was looking for. My problem is solved now.
    Until the next time.
    Oct 3, 2012 10:30 AM   in reply to Yammer
    I'd assume next time somebody will inspect the network traffic again to find out the URL of the installer...
    Oct 3, 2012 1:35 PM   in reply to deejjjaaaa
    Oct 3, 2012 2:20 PM   in reply to Michelle Qi
    Michelle,
    Whenever I go to Help > Update, I get the following error message:  "The update server is not responding.  The server might be offline temporarily, or the Internet or firewall settings may be incorrect."  Thus the Adobe Application Manager is unable to update CS6 or ACR.  I don't have any firewall problems with any other software, so what would you suggest?
    David
    Oct 3, 2012 2:23 PM   in reply to davidl11
    May be you could try this solution? http://www.youtube.com/watch?v=2tRewtGT83M
    Oct 3, 2012 2:26 PM   in reply to davidl11
    simply:
    1. Open Network and Sharing Center
    2. Click  Change adapter settings
    3. Right-click  the Microsoft Virtual WiFi Miniport  Adapter, and click Disable.
    4. Open  Adobe Reader and Help > Check for Updates
    I'm a Mac but I have found this solution and hope it can help! Good luck!
    Oct 3, 2012 2:46 PM   in reply to avrbox
    avrbox,
    Thanks.  Your instructions worked like a charm, and Adobe Application Manager is 'happily' updating my Adobe software.
    Best,
    David
    Oct 3, 2012 5:32 PM   in reply to 01af
    Camera Profiles are, yes, but are Lens Profiles?  Does creating a Linear DNG actually apply vignetting and geometry corrections from a lens-profile?  I don’t use the DNGC in enough circumstances to know.
    Oct 3, 2012 11:02 PM   in reply to davidl11
    You're welcome David!
    Oct 4, 2012 5:52 AM   in reply to deejjjaaaa
    deejjjaaaa, thank you! it helped
    Oct 4, 2012 5:59 AM   in reply to Nick Sun
    I find a download for "Adobe DNG Converter 7.2", but no Camera RAW 7.2 download.  I never use the DNG converter, so don't download that.  Does this download contain Camera RAW 7.2?
    What's the problem Adobe?
    Oct 4, 2012 6:02 AM   in reply to b2martin_a
    b2martin_a, here is a direct link for Mac for ACR 7.2.0.46 is http://swupdl.adobe.com/updates/oobe/aam20/mac/PhotoshopCameraRaw7-7.0 /7.2.82/Setup.dmg
    It contains Camera RAW 7.2 so you can easily download and install it if you're Mac!
    Oct 4, 2012 6:03 AM   in reply to b2martin_a
    No, despite what it says:
    File Information
    ProductAdobe Camera Raw and DNG Converter
    Oct 4, 2012 10:13 AM   in reply to Michelle Qi
    I tried to update CS6 through the update button but it says my files are up to date.  I have a Nikon D600 and I still can't read the raw files.
    Oct 4, 2012 10:21 AM   in reply to fheimann
    Dear fheimann, you can use both mac and windows link above this post to download working update files without waiting it through Update manager.
    Just to make you know there are a lot of people having the same problems.
    So don't wait anything and just download these update files depending on system you use!
    Good luck!
    Oct 11, 2012 5:38 AM   in reply to avrbox
    what is  the reason for adobe annoying it´s customers and NOT puting this update on the camera raw update page?
    they have done it in the past.. so what the hell is going on?
    Oct 12, 2012 9:08 AM   in reply to fheimann
    Same problem here.
    I ran Update from within Photohop CS6, and it downloaded and installed 4 updates.
    I couldn't open D600 NEFs - checked the Camera Raw plug-in and it still said 7.1.
    I ran the Update again and it said "Your applications are all up to date".
    Finally resigned to downloading ACR 7.2 via the link on this thread, and updated manually.
    Plug-in now showed as 7.2.0.46, and I can now open D600 nefs in ACR.
    So, does this mean the updater is whacked and I won't get future updates, or is this something on Adobe's end?
  • Noel Carboni
    Dec 23, 2006
    Oct 12, 2012 9:44 AM   in reply to Qbarrie
    For what it's worth, I got the Camera Raw 7.2 update without problem on my PC through the Help - Updates... facility.
    -Noel
    Oct 12, 2012 9:56 AM   in reply to Noel Carboni
    Just tried it on my XP partition and it worked okay - downloaded and installed 4 updates including 7.2.
    I don't get why it downloaded and installed the updates on my W7 partition, but it didn't do 7.2.
    (It's checked on the list in the AAM preferences)
    The only thing I can think of is that I recently trialed Lightroom 4.1 on my W7 partition, and maybe it didn't uninstall clean or something....
