My export presets for PDF(print) are missing.
Oct 4, 2012 5:02 PM
Tags: #missing #pdf #export #indesign #presets #cs6
I have InDesign CS6. I went to export a file and I only have [custom] and standard (1). The normal settings such as "smallest file size", "high quality print" and "Press quality print" are all gone. Does anyone know how to fix this? And why this problem happened in the first place?
It seems it's just another problem to add to a long list which haults my work and wastes so much of my time. Is it too much to expect that an expensive program which my company paid for should just work?
If it makes any difference I am using Windows 7.
Any assistance is much appreciated.
    Oct 5, 2012 1:28 AM   in reply to Aussie_leah
    Have you tried replacing your preferences?
    http://forums.adobe.com/thread/526990
    Oct 5, 2012 4:04 AM   in reply to Aussie_leah
    I don't think Prefs is going to do it...
    I uploaded a zip file of standard presets to my YouSendIt account a few mainths ago for someone else. It's still there: https://www.yousendit.com/download/TEhVN3RhbEpOQnljZDhUQw
    Oct 7, 2012 2:38 PM   in reply to Aussie_leah
    They'll work.
    Try putting them in C:\Users\All Users\Adobe\Adobe PDF\Settings
    If that doesn't work, you can load them into your user from File > Adobe PDF Presets > Define...
    Oct 22, 2012 11:54 AM   in reply to Aussie_leah
    Help! Same thing just happened to me and I'm on deadline. I get an error when I try to access the above link with the settings. I would sure appreciate it if someone could direct me to a link I can download quickly. Thanks!
    Oct 22, 2012 12:08 PM   in reply to APCreativeFla
    This should work :-
    http://dl.dropbox.com/u/16243351/joboptions.rar
    Oct 22, 2012 5:55 PM   in reply to APCreativeFla
    That link is still working for me....
    Oct 22, 2012 9:43 PM   in reply to Peter Spier
    I think it was Yousendit server issue as I also tried it last night but didn't work.
    Oct 23, 2012 1:57 AM   in reply to Manish-Sharma
    Maybe it needs a cookie....
    Dec 3, 2012 10:19 AM   in reply to Aussie_leah
    I'm having the same issue... all my presets have just magically vanished and now I am in a real bind. This is just one of many problems I've had since upgrading to CS6... wish I never had! Adobe is really going downhill.
    Dec 3, 2012 12:02 PM   in reply to mga_user
    The link is still good...
    Obviously there are a number of you who have this problem, but I wouldn't necessarily lay it at Adobe's feet as there are many more users who don't experience any difficulty with the presets at all. That usually means there's something on your own system that caused this.
    Dec 3, 2012 12:09 PM   in reply to Peter Spier
    Finally figured out a fix...
    1. Close all Adobe products
    2. Delete this folder: C:\Users\username\AppData\Roaming\Adobe\InDesign\Version 8.0
    3. Restart
    Dec 3, 2012 12:13 PM   in reply to mga_user
    That's interesting. It means the presets aren't really missing at all, but your prefs are corrupt. That surprises me quite a bit since the default presets are not stored in the user profile.
    Dec 7, 2012 8:41 AM   in reply to Peter Spier
    I've just had a similar problem. I didn't lose the presets I've previously created/installed myself, but all the default presets were suddenly missing from the File > Adobe PDF Presets menu.
    I tried pasting a known good copy of the default .joboptions files into C:\ProgramData\Adobe\Adobe PDF\Settings - didn't work
    I tried deleting C:\Users\Steve Balcombe\AppData\Roaming\Adobe\InDesign\Version 8.0 - didn't work
    I copied the known good .joboptions files into C:\Users\Steve Balcombe\AppData\Roaming\Adobe\Adobe PDF\Settings - this gave me back my default presets but of course it's a workaround - the original problem (InDesign fails to read the presets in C:\ProgramData\Adobe\Adobe PDF\Settings) is still there.
    Dec 12, 2012 12:48 PM   in reply to Aussie_leah
    I'm on a Mac, 10.7.5, and had just uninstalled some old software and came up with this exact problem in InDesign. On a Mac, reinstalling Acrobat Pro (or installing the newest version) did the trick for me and restored the presets.
    Feb 13, 2013 4:49 PM   in reply to Gwendolyn Rice
    Thank you Gwendolyn.
    I'm on Mac too and had also just uninstalled some older Adobe versions prior to upgrading to Mountain Lion, and ran into this problem. Your solution worked perfectly!
    Mar 6, 2013 10:54 AM   in reply to Aussie_leah
    I have exactly same problem.
    installed cs6 fine. then updated mountain lion 10.8.2.
    i removed some of my old cs3, cs4, and trial cs5 by using adobe installer
    now my presets in illustrator is gone?!
    i stil have my acrobat 9 pro intact and it exports fine and has the various presets.
    i think it's only my illustrator presets gone....i am not sure about indesign (if anyone has a snapshot of what it should look like in the export PDF panel, pls show me)
    i downloaded the link from the above....but i dont know where to place this?
    Mar 6, 2013 11:07 AM   in reply to hic66
    You should probably reinstall CS6. Uninstalling earlier versions after you install a new one can have a lot of bad effects (things go missing becasue the get delted by the uninstaller from common folders), but it's hard to know waht all the damage is until you hit a problem.
    Mar 6, 2013 11:15 AM   in reply to Peter Spier
    Thanks Peter for replying.
    But is there any workaround without having to do full install? all my other apps work fine so far. I mean worst case i could open it up in acrobat 9 pro which i do have, then export the file.
    i dont see any preset folders for acrobat in illustrator CS6 at all. it must be getting it from somewhere?
    Mar 6, 2013 11:40 AM   in reply to hic66
    You can probaly just reinstall them where they belong, but I can't tell you where that is on a Mac. You can try a search for *.jobptions files and include hidden files and folders (I'm pretty sure it's a hidden folder). You might see a folder that has others in it. Or you can save the ones you downloaded in a folder on the desktop, then from ID go to File > Adobe PDF Presets > Define... and click the Load button. Doing it that way will load them only for the current user.
    Mar 6, 2013 11:57 AM   in reply to Peter Spier
    Hi Peter,
    Weirdest thing, i rebooted my mac in frustration, I was giving up....and voila! It worked?!!! I really have no clue what went on there....glitchy. All my presets showned properly again in Illustrator.
    But in reply to your previous suggestion, my problem actually occured in Illustrator CS6 and so far I was not able to find any joboptions or acrobat pdf presets folders, etc. It must be hidden in a script ?
    In case this pops up again, can you suggest where I look to manually install these acrobat presets in Adobe Illustrator CS6?
    A million thanks for your responses and expertise.
    Mar 6, 2013 12:08 PM   in reply to hic66
    As I said, I have no idea where they are stored on your Mac (nor do I know if there are multiple copies for Illy to have its own). On the PC the default presets for everyone are stored in the "all users" profile under Adobe\Adobe PDF\Settings
