Use keywords in Adobe Bridge
Oct 5, 2012 2:00 PM
    Oct 5, 2012 2:00 PM   in reply to Community Help
    For a nice step by step guide to Importing keywords, see this blog post by Jennifer Brown:
    http://jenniferbrowndesigns.blogspot.com/2011/06/importing-library-in- bridge.html
    Nov 28, 2012 6:02 AM   in reply to Community Help
    I am using Adobe Bridge CS 5.0.1.on a MacBook Air, and I am wondering why adding keywords does reduce the size of image files? Is there a reduction of quality happening?
    Thanks for any help!
    Gudrun
  • Omke Oudeman
    Nov 27, 2004
    Nov 28, 2012 6:55 AM   in reply to wieverdammt
    Can you provide an example of the figures, what file type are you using and how much reduction in size are you experiencing?
    Normally adding keywords to a file saves it in the metadata of this file (or in case of Raw in the separate XMP file) however the difference for keywords should be more in bits or a very view KB, not more and especially not reducing the amount of pixels.
    Dec 4, 2012 4:36 AM   in reply to Omke Oudeman
    Hi Omke,
    thanks for your fast answer. I am adding  keywords to jpeg files and my husband told me, that the files with keywords are smaller in size than his old backups. But I can't reproduce the reduction now. When I add three keywords, the file is 5 kb bigger, I think, thats normal, isn't? I just want to be sure, that adding the keywords does not reduce the quality of our pictures.
    Greetings
    Gudrun
  • Omke Oudeman
    Nov 27, 2004
    Dec 4, 2012 6:01 AM   in reply to wieverdammt
    Hi Gudrun,
    This sounds indeed normal, if this are also the figures (a few kb) that your husband suspects as less instead of more for his old back up this might be caused by writing from one disk to an other disk, that also can cause a bit difference in size.
    But if the files are really different he should compare the pixel amount of both files and make also sure the files are not resaved or resized during time between the old back up and the newer files. Resaving in lower quality and reducing size is something Bridge can only achieve using the tools menu for PhotoShop (batch or image processor) or the export module. Keywords panel only can add or delete metadata (keywords, info etc) in the fields that have a pencil so you can alter it.
