Hi everybody,
Well I have a big problem here, with my software Adobe Premiere Pro CS6. There is a project very important to me, on which I have been working for two monthes now... I can't open it.
Everything worked fine untill this evening. Now, when I want open it, it loads and there is a message on which is written : "This project contained a sequence that could not be opened. No sequence preview preset file or codec could be associated with this sequence type.".
I have tried the solutions proposed on http://helpx.adobe.com/premiere-pro/kb/missing-sequence-presets.html : I disactivated and reactivated my Premiere Pro CS6, and I "re-created the Adobe Premiere Pro preferences and plug-in cache" (at the least, I pressed alt + shift during the loading screen of Premiere.. I had no sign that anything was done or changed because the software started as usually, but I suppose it's normal).
So, since it seems that there's no further solutions or ideas to resolve the problem, I want, at the least, find a way to recover the huge cutting work on which I
thoroughly strived during the whole last weeks.
According the error message, there is ONE sequence that doesn't work. It means that the great majority of my sequences are clean. How can I recover them in a way I can edit them again on Premiere ?
Thanks.
PS : sorry if there are mistakes in my words, my maternal language is french.
What version of Premiere are you using? 6.0 or 6.0.1 or 6.0.2 or 6.0.3?
Also sometimes this problem occurs when you used a customized sequence in the project but this sequence/codec is no longer installed is this possibly the case? For example did you have any capture cards installed that aren't installed anymore? Did you recently re-install your OS or remove codecs or make any system changes?
Also from what I have read another quick work-around for this issue is to open the Premiere Pro Project up inside Notepad ++ and change all instances of the current preview codec from I-Frame Only MPEG to Microsoft AVI. Because some other people have said this solution works in some cases. However I'd only do this as a last resort. This solution will only work though if the problem was being casued by the I frame only mpeg preview codec option though which isn't always the case. So this might not work anyways. I'd honestly recommend just re-installing though if you've already tried to deactivate and you personally already know that you weren't using I frame only mpeg as a preview choice and you also know for a fact you haven't uninstalled any capture cards recently or any codecs. If you do uninstall though, use the adobe cleaner tool when doing so.
Well yes and no, we know what the problem was now so, in that since it's solved. Sadly though like you very correctly stated it's not a perm fix at all. Which is why I recommended a clean install for the perm solution. So the problem has been solved, a solution hasn't fully been provided yet. Only a suggestion on how to get there.
Hi again ! ![]()
Is that what we could call an Adobe Philosophy ?
Well now I have another problem xD Each time I open my project, I get the error message... so each time I have to edit it with Notepad ++ and each time I lose every renders.
Is there a solution to definitely tell Premiere to make the renders on "Microsoft Avi" instead of "I-Frame" ?
Thanks ![]()
Like I mentioned earlier you're going to need to uninstall the suite, then run the cleaner utility. Then reinstall, unless someone else knows how to fix the issue that caused the corruption in the first place. Which I have no clue how it managed to get corrupted, I just know that somehow it did. That's why that problem is solved (meaning knowing what exactly the problem was), since we know it's corrupted, sadly though I still have 0 clue why. I'd really just recommend the uninstall option. It's by far the fastest solution IMO because you could end up spending hours/days trying to work around a issue that can be fixed by a fresh re-install (most of the time). I've fallen in this trap myself before.
Just make sure to follow the steps listed from the link I posted in my earlier post.
If you really want avoid a fresh install though. (Which I'd strongly recommend doing instead of doing what I'm about to say)
You can technically create a customized sequence that is using a different codec for preview, then paste your old sequence into the new sequence then delete your old sequence which was using the I-frame only mpeg for previews, then click save as and name the project w/e you want then use the project which only contains the good sequence which is using a different/ your newly selected preview codec.
Hi all,
I've recently run into this issue as well. My client gave me a 2TB external with a mess of PProCS6 projects, and I cannot get a single one of them to work.
System: Win7/64 Ultimate
i7-2760QM
32gigs Ram
3gig NVidia 560m
First attempt to fix was the notepad workaround. Unfortunately each project file ranges from 300mb to 600mb (rounded, obviously). Not only did the rename process take upwards of 15 minutes to complete on the seemingly massive text docs, but I still received the error.
Next attempt was to completely wipe CS6 off my system, and follow up with Adobe Cleaner. Ran Cleaner 5 times back-to-back, reinstalled Master and still have the issue.
What gives?
Okay so obviously you've attempted to reinstall and it didn't work. Very strange scenario going on here, usually that fixes the problem. However when you start Premiere Pro up now does it say anything about using a trial version? Because it it sounds like your not activated still. Try disabling your firewall, and see if it activates. Your "deactivate" should stop appearing as greyed out if it works.
Check out this FAQ: http://forums.adobe.com/message/4626663#4626663
Also if the firewall option didn't work try the following solutions as well.
Although it sounds like you already have done at least one of the suggetions from this link so please ignore if you have.
I had the same problem. After some trial and error I figured out that it was some .psd files that I had imported as a sequence.
I created a new premiere project and imported the sequences from the old project that wouldn't open.
Then I used Photoshop to save the graphic as tiff files and reimported them into the project.
I replaced the .psd/sequences with the Tiff files and deleted the .psd/sequences from my project.
This totally solved the problem.
I know it's just a workaround but until this .psd import issue is fixed, it's a perfectly good one.
I hope this helps.
I deactivated, killed everything with Adobe's name on it and restarted Premiere (which promptly failed to ask me to or provide any options for reactivation - Encore subsequently told me I was not activated - relaunching Premiere showed the 30day message - relaunching the Adobe Application Manager let me activaite.
That allowed me to open ALL the prproj's I was DENIED access to by Adobe's licensinig division..... Slap on the back of the hand for your new flangled licensing devs - I bet you tested the part that collects the money and blocks use of the program right? Serious killjoy project manager...
And Priemere dev's - you should know better than to trust them when they say you won't need to update anythign for the new licensing - update the damn eror rmesage: "Oh yea...sorry...I'm gonna go ahead and ask you to reactivate everything"
Reinstall? What is this ATI?
Hello everyone and sorry for my bad english.
Ok, this was my problem :
I created my project in Prelude CS6 then worked out in Premier Pro CS6 and then send it to SpeedGrade CS6. After closing everything for a reboot, my main project Premiere couldn't be opened, error message : " This project contained a sequence that could not be opened. No sequence preview preset file or codec could be associated with this sequence type. "
So, after looking on all those forums I decided to reinstall all my CS6 programs with Adobe Creative Suite Cleaner. Somehow, the cleaner doesn't clean everything, 5 of my CS6 programs were still there. And when I tried to reopen my project with the fresh Premier CS6, the same error message shown his face.
This is my solution :
Open a new Premier project and import your "work" project in the new one. When Premier ask you how to import, choose Import selected sequences. This worked for me.
( Any of my CS6 were updated ).
Also, my " old " project had dynamic link with After Effect CS6, maybe all this cocktail made this error.
I just encountered this same problem after copying all of my projects to a different external drive. I verified btye counts on every folder when I copied. I just read the FAQ that adobe pointed too. Maybe the error message should be a little more verbose as this is a very unsettling error to see on something you have worked really hard on.
Update. I'm on Creative Cloud and deactivating and reactivating RESOLVED this issue for me
North America
Asia Pacific
