I have just installed Elements 11 on my Retina Macbook Pro running OSX 10.7.5.
I have a USB SuperDrive connected with a DVD recorded by my DVD recorder, so not a copy protected DVD.
I go to the Video Importer and just get a screen saying "No supported device detected".
I tried using Organizer to import the VOB file, but this just ends up as an audio file, with no video.
So how do I get Premiere Elements 11 to import video from a DVD on my Retina Macbook Pro, or do I just give up and get a refund?
If your DVD is in your Mac's DVD drive, there is no reason why you should not be able to see it using Add Media/From DVD Camcorder or PC DVD Drive's Video Importer. It works fine on my Mac.
But if it's not working and that's a dealbreaker, I suppose you should ask for a refund.
The longer you wait, the harder it is to get a refund.
Do make sure that you're connected to the internet when you try to use Premiere Elements' Add Media/DVD Camcorder or Computer Drive to get your video. There is a component that needs to be downloaded and installed the first time you use the Video Importer.
But try it in Premiere Elements first -- not the Organizer. Until Premiere Elements downloads and activates that component, the programs may not read the VOB files.
Yes, also connected to the internet.
I quit the app and tried again.
I get the no supported device.
If I browse to the VOB file from the Files and folder menu then it tell me to use Video Importer, which doesn't work due to the no supported device.
If I then try the same file (/Volumes/DVD_VIDEO_RECORDER/VIDEO_TS/VTS_01_1.VOB) from Organizer, then it imports into Premiere Elements 11, but as audio not video.
As it happens the DVD only has video, not audio...
Here is the Console log from starting up Premiere and going to the DVD import to be greeted with the "No suitable device..." screen:
13/10/2012 19:51:58.070 Adobe Premiere Elements: CFURLCreateWithString was passed this invalid URL string: '/System/Library/Frameworks/System.framework' (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateWithFileSystemPath or CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
13/10/2012 19:51:58.074 Adobe Premiere Elements: kCGErrorInvalidConnection: CGSGetOnScreenWindowCount: Invalid connection
13/10/2012 19:51:58.074 Adobe Premiere Elements: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
13/10/2012 19:51:58.075 Adobe Premiere Elements: kCGErrorInvalidConnection: CGSGetOnScreenWindowCount: Invalid connection
13/10/2012 19:51:59.348 Firewall: Adobe Premiere E is listening from 127.0.0.1:55851 proto=6
13/10/2012 19:52:00.709 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: <CFURL 0x111935f90 [0x7fff7dfa9fa0]>{type = 15, str
13/10/2012 19:52:00.709 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: ing = file://localhost/Applications/Adobe%20Premiere%20Elements%2011/Suppor t%20Files/Adobe%20Premiere%20Elements.app/Contents/Plug-ins/Common/PSA /Photoshop%20Adapter.plugin/, encoding = 134217984, base = (
13/10/2012 19:52:00.709 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: null)}
13/10/2012 19:52:00.709 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: RL 0x1119359c0 [0x7fff7dfa9fa0]>{type = 15, string = file://localhost/Applications/Ad
13/10/2012 19:52:00.709 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: obe%20Premiere%20Elements%2011/Support%20Files/Adobe%20Premiere%20Ele ments.app/Content
13/10/2012 19:52:00.709 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: s/Plug-ins/Common/PSA/Pixar.plugin/, encoding = 134217984, base = (null
13/10/2012 19:52:00.709 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: )}
13/10/2012 19:52:00.709 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: <CFURL 0x10f91c8d0 [0x7fff7dfa9fa0]>{type = 15, string = file:
13/10/2012 19:52:00.710 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: //localhost/Applications/Adobe%20Premiere%20Elements%2011/Support%20F iles/Adobe%20Premiere%20Elements.app/, encoding = 134217984, base = (null)}
13/10/2012 19:52:00.710 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: <CFURL 0x11ed257a0 [0x7fff7dfa9
13/10/2012 19:52:00.710 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: fa0]>{type = 15, string = file://localhost/Library/Application%20Support/Adobe/Plug-Ins/Element s%2011/File%
13/10/2012 19:52:00.710 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: 20Formats/Camera%20Raw.plugin/, encoding = 134217984, base = (null)}
13/10/2012 19:52:00.713 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: <CFURL 0x111936440 [0x7fff7dfa9fa0]>{type = 15, string
13/10/2012 19:52:00.713 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: = file://localhost/Applications/Adobe%20Premiere%20Elements%2011/Suppor t%20Files/Adobe%20Premiere%20Elements.app/Contents/Plug-ins/Common/PSA /Photoshop%20Adapter.plugin
13/10/2012 19:52:00.713 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: /, encoding = 134217984, base = (null)}
13/10/2012 19:52:00.743 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: <CFURL 0x11ed4a600 [0x7fff7dfa9fa0]>{type = 15, string = file://localhost/Applications/Adobe%20Premiere%20Elem
13/10/2012 19:52:00.743 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: ents%2011/Support%20Files/Adobe%20Premiere%20Elements.app/Contents/Pl ug-ins/Common/PSA/Pixar.plugin/, encoding = 134217984, base = (null)}
13/10/2012 19:52:00.744 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: <CFURL 0x11ed4bb10
13/10/2012 19:52:00.744 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: [0x7fff7dfa9fa0]>{type = 15, string = file://localhost/Library/Application%20Support/Adobe/Plug-Ins/Element s%2011/File%20Formats/Camera%20Raw.p
13/10/2012 19:52:00.744 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: lugin/, encoding = 134217984, base = (null)}
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: spEdgeCallPlugin(): Sweet Pea 2 Adapter Plugin (Reload) 0
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: spEdgeCallPlugin done: Sweet Pea 2 Adapter Plugin (Reload)
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: spEdgeCallPlugin(): Sweet Pea 2 Adapter Plugin (Acquire) 0
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: spEdgeCallPlugin done: Sweet Pea 2 Adapter Plugin (Acquire)
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: spEdgeCallPlugin(): Sweet Pea 2 Adapter Plugin (Release) 0
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: spEdgeCallPlugin done: Sweet Pea 2 Adapter Plugin (Release)
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='ADBE' propertyKey='kind' propertyID=0 propertyLength=4
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='ADBE' propertyKey='adpt' propertyID=0 propertyLength=4
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='ADBE' propertyKey='ivrs' propertyID=0 propertyLength=4
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='ADBE' propertyKey='mach' propertyID=0 propertyLength=9
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='ADBE' propertyKey='mi64' propertyID=0 propertyLength=9
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='ADBE' propertyKey='mi32' propertyID=0 propertyLength=9
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='kind' propertyID=0 propertyLength=4
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='vers' propertyID=0 propertyLength=4
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='name' propertyID=0 propertyLength=6
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='znam' propertyID=0 propertyLength=48
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='nabo' propertyID=0 propertyLength=4
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='mi64' propertyID=0 propertyLength=1
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='mi32' propertyID=0 propertyLength=1
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='mode' propertyID=0 propertyLength=2
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='fmTC' propertyID=0 propertyLength=8
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='RdTy' propertyID=0 propertyLength=8
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='WrTy' propertyID=0 propertyLength=8
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='RdEx' propertyID=0 propertyLength=4
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='WrEx' propertyID=0 propertyLength=4
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='fmtf' propertyID=0 propertyLength=1
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='mxsz' propertyID=0 propertyLength=4
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='mxch' propertyID=0 propertyLength=32
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='ffps' propertyID=0 propertyLength=4
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='prty' propertyID=0 propertyLength=4
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='name' propertyID=0 propertyLength=11
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='znam' propertyID=0 propertyLength=54
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='mi32' propertyID=0 propertyLength=8
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='coco' propertyID=0 propertyLength=4
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='mi64' propertyID=0 propertyLength=8
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='fftE' propertyID=0 propertyLength=108
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='ffbs' propertyID=0 propertyLength=4
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='ffpm' propertyID=0 propertyLength=4
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='ffpt' propertyID=0 propertyLength=4
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='xmpr' propertyID=0 propertyLength=4
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='xmpw' propertyID=0 propertyLength=4
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='qthm' propertyID=0 propertyLength=4
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='ffbo' propertyID=0 propertyLength=4
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='piLU' propertyID=0 propertyLength=4
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='piPF' propertyID=0 propertyLength=4
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='rscp' propertyID=0 propertyLength=4
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='fowa' propertyID=0 propertyLength=4
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='fwio' propertyID=0 propertyLength=4
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='frts' propertyID=0 propertyLength=4
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: SPEFiles.c:EndianSwapPiPL vendorID='8BIM' propertyKey='hstm' propertyID=0 propertyLength=31
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: spEdgeCallPlugin(): internal (Reload)
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: spEdgeCallPlugin done: internal (Reload)
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: spEdgeCallPlugin(): internal (Startup)
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: spEdgeCallPlugin done: internal (Startup)
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: spEdgeCallPlugin(): internal (Register plugins)
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: Suite not found: Photoshop Adapter.plugin asked for Adobe Parser Support Suite version 5
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: spEdgeCallPlugin done: internal (Register plugins)
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: spEdgeCallPlugin(): Sweet Pea 2 Adapter Plugin (Startup) 0
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: spEdgeCallPlugin done: Sweet Pea 2 Adapter Plugin (Startup)
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: spEdgeCallPlugin(): internal (Load plugin)
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: spEdgeCallPlugin done: internal (Load plugin)
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: spEdgeCallPlugin(): internal (Send message)
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: spEdgeCallPlugin done: internal (Send message)
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: Suite not found: Photoshop Adapter.plugin asked for IR Message Info version 1
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: spEdgeCallPlugin(): internal (Start up)
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: spEdgeCallPlugin done: internal (Start up)
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: spEdgeCallPlugin(): Sweet Pea 2 Adapter Plugin (Start up) 0
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: spEdgeCallPlugin done: Sweet Pea 2 Adapter Plugin (Start up)
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: Suite not found: Photoshop Adapter.plugin asked for IR Purge Control version 1
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: Suite not found: Photoshop Adapter.plugin asked for AI Runtime Suite version 6
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: Suite not found: Photoshop Adapter.plugin asked for IR Abort Suite version 2
13/10/2012 19:52:01.792 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: Texture memory: 0
13/10/2012 19:52:01.798 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: Vendor string: NVIDIA Corporation
13/10/2012 19:52:01.798 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: Renderer string: NVIDIA GeForce GT 650M OpenGL Engine
13/10/2012 19:52:01.798 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: Version string: 2.1 NVIDIA-7.32.12
13/10/2012 19:52:01.798 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: OpenGL version as determined by Extensionator...
13/10/2012 19:52:01.798 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: OpenGL Version 2.0
13/10/2012 19:52:01.798 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: Supports shaders!
13/10/2012 19:52:01.807 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: Supports BGRA -> BGRA Shader
13/10/2012 19:52:01.808 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: Supports VUYA Shader -> BGRA
13/10/2012 19:52:01.810 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: Supports UYVY/YUYV ->BGRA Shader
13/10/2012 19:52:01.811 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: Supports YUV 4:2:0 -> BGRA Shader
13/10/2012 19:52:01.811 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: Device was not tested for CUDA support.
13/10/2012 19:52:01.818 [0x0-0x19f19f].com.adobe.Adobe Premiere Elements-11.0: Completed shader test!
13/10/2012 19:52:02.639 Adobe Premiere Elements: CFURLCreateWithBytes was passed these invalid URLBytes: '/Applications/Adobe Premiere Elements 11/Support Files/Adobe Premiere Elements.app/Contents/Frameworks' (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateFromFileSystemRepresentation should be used instead.
13/10/2012 19:52:04.540 Adobe Premiere Elements: invalid drawable
13/10/2012 19:52:16.592 Adobe Premiere Elements: [PremiereCocoaMacApplication handleMenuCommand:1164726136 from <DVAMacMenuItem: 0x1167b5af0 DVD camera or computer drive>]
My guess is that Adobe is getting it wrong for DVD Recorder VOBs, as it loads just the audio, not the video.
No idea why they can't get the Video Importer to work. Probably they have coded so it only works with internal drives... well guess what, no internal drive on any of the Macbooks I own (Air or Retina Pro).
How do I report this to Adobe, as they seem very keen to push you to the Forums only?
Here is my VOB info:
| [00000000] | VTS Identifier | DVDVIDEO-VTS | |
| [0000000c] | Last Sector of VTS | 50631 | [0000c5c7] |
| [0000001c] | Last Sector of VTSI | 7 | [00000007] |
| [00000021] | Specification version number | v1.1 | [11] |
| [00000022] | VTS Category | 0 | [00000000] |
| [00000080] | End byte of VTSI_MAT | 2047 | [000007ff] |
| [000000c0] | Start sector of VTSM_VOBS | 0 | [00000000] |
| [000000c4] | Start sector of VTSTT_VOBS | 992 | [000003e0] |
| [000000c8] | Start offset of VTS_PTT_SRPT | 1 | [00000001] |
| [000000cc] | Start offset of VTS_PGCIT | 2 | [00000002] |
| [000000d0] | Start offset of VTSM_PGCI_UT | 3 | [00000003] |
| [000000d4] | Start offset of VTS_TMAPT | 4 | [00000004] |
| [000000d8] | Start offset of VTSM_C_ADT | 0 | [00000000] |
| [000000dc] | Start offset of VTSM_VOBU_ADMAP | 0 | [00000000] |
| [000000e0] | Start offset of VTS_C_ADT | 5 | [00000005] |
| [000000e4] | Start offset of VTS_VOBU_ADMAP | 7 | [00000007] |
| [00000100] | Video attributes of VTSM_VOBS | 0 | [0000] |
| Video attribute details: | |||
| Video compression | MPEG-1 | ||
| TV system | NTSC 525/60 | ||
| Aspect ratio | 4:3 | ||
| Automatic Display Mode | pan-scan & letterboxed | ||
| CC for Line21-1 (NTSC only) | no data | ||
| CC for Line21-2 (NTSC only) | no data | ||
| Bit Rate | VBR | ||
| Source Resolution | 720x480 (NTSC) | ||
| Letterboxed top&bottom cropped | no | ||
| Mode | Camera | ||
| [00000103] | Number of audio streams in VTSM_VOBS | 0 | [00] |
| [00000104] | Audio_1: VTSM audio attributes | 0 0 0 0 0 0 0 0 | [00 00 00 00 00 00 00 00 ] |
| [0000010c] | Audio_2: VTSM audio attributes | 0 0 0 0 0 0 0 0 | [00 00 00 00 00 00 00 00 ] |
| [00000114] | Audio_3: VTSM audio attributes | 0 0 0 0 0 0 0 0 | [00 00 00 00 00 00 00 00 ] |
| [0000011c] | Audio_4: VTSM audio attributes | 0 0 0 0 0 0 0 0 | [00 00 00 00 00 00 00 00 ] |
| [00000124] | Audio_5: VTSM audio attributes | 0 0 0 0 0 0 0 0 | [00 00 00 00 00 00 00 00 ] |
| [0000012c] | Audio_6: VTSM audio attributes | 0 0 0 0 0 0 0 0 | [00 00 00 00 00 00 00 00 ] |
| [00000134] | Audio_7: VTSM audio attributes | 0 0 0 0 0 0 0 0 | [00 00 00 00 00 00 00 00 ] |
| [0000013c] | Audio_8: VTSM audio attributes | 0 0 0 0 0 0 0 0 | [00 00 00 00 00 00 00 00 ] |
| [00000155] | Number of Sub-picture streams in VTSM | 0 | [00] |
| [00000156] | Sub-pic_1: VTSM Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [00000200] | Video attributes of VTSTT_VOBS | 21248 | [5300] |
| Video compression | MPEG-2 | ||
| TV system | PAL 625/50 | ||
| Automatic Display Mode | not specified | ||
| Bit Rate | VBR | ||
| Source Resolution | 720x576 (PAL) | ||
| Mode | Camera | ||
| [00000203] | Number of audio streams in VTSTT_VOBS | 1 | [01] |
| [00000204] | Aud_1: audio attributes | 2 193 0 0 0 0 0 0 | [02 c1 00 00 00 00 00 00 ] |
| Audio attribute details: | |||
| Application mode | Surround | ||
| Language type | not specified | ||
| Multichannel extension | not present | ||
| Coding mode | AC3 | ||
| Channels | 2 | ||
| Sample Rate | 48Kbps | ||
| Quantization/DRC | DRC (dynamic range control) | ||
| Language | Not Specified | ||
| Language extension | [00] | ||
| Code extension (Audio Type) | unspecified | ||
| suitable for Dolby surround decoding: | no | ||
| [0000020c] | Aud_2: audio attributes | 0 0 0 0 0 0 0 0 | [00 00 00 00 00 00 00 00 ] |
| [00000214] | Aud_3: audio attributes | 0 0 0 0 0 0 0 0 | [00 00 00 00 00 00 00 00 ] |
| [0000021c] | Aud_4: audio attributes | 0 0 0 0 0 0 0 0 | [00 00 00 00 00 00 00 00 ] |
| [00000224] | Aud_5: audio attributes | 0 0 0 0 0 0 0 0 | [00 00 00 00 00 00 00 00 ] |
| [0000022c] | Aud_6: audio attributes | 0 0 0 0 0 0 0 0 | [00 00 00 00 00 00 00 00 ] |
| [00000234] | Aud_7: audio attributes | 0 0 0 0 0 0 0 0 | [00 00 00 00 00 00 00 00 ] |
| [0000023c] | Aud_8: audio attributes | 0 0 0 0 0 0 0 0 | [00 00 00 00 00 00 00 00 ] |
| [00000255] | Number of sub-picture streams in VTSTT_VOBS | 1 | [01] |
| [00000256] | Sub-p_01: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [0000025c] | Sub-p_02: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [00000262] | Sub-p_03: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [00000268] | Sub-p_04: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [0000026e] | Sub-p_05: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [00000274] | Sub-p_06: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [0000027a] | Sub-p_07: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [00000280] | Sub-p_08: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [00000286] | Sub-p_09: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [0000028c] | Sub-p_10: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [00000292] | Sub-p_11: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [00000298] | Sub-p_12: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [0000029e] | Sub-p_13: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [000002a4] | Sub-p_14: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [000002aa] | Sub-p_15: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [000002b0] | Sub-p_16: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [000002b6] | Sub-p_17: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [000002bc] | Sub-p_18: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [000002c2] | Sub-p_19: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [000002c8] | Sub-p_20: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [000002ce] | Sub-p_21: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [000002d4] | Sub-p_22: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [000002da] | Sub-p_23: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [000002e0] | Sub-p_24: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [000002e6] | Sub-p_25: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [000002ec] | Sub-p_26: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [000002f2] | Sub-p_27: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [000002f8] | Sub-p_28: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [000002fe] | Sub-p_29: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [00000304] | Sub-p_30: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [0000030a] | Sub-p_31: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [00000310] | Sub-p_32: Sub-picture stream attributes | 0 0 0 0 0 0 | [00 00 00 00 00 00 ] |
| [00000318] | 01. Multichannel extension | 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 | [00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ] |
| [00000330] | 02. Multichannel extension | 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 | [00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ] |
| [00000348] | 03. Multichannel extension | 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 | [00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ] |
| [00000360] | 04. Multichannel extension | 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 | [00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ] |
| [00000378] | 05. Multichannel extension | 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 | [00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ] |
| [00000390] | 06. Multichannel extension | 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 | [00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ] |
| [000003a8] | 07. Multichannel extension | 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 | [00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ] |
| [000003c0] | 08. Multichannel extension | 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 | [00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ] |
Aha - just looked at a pre-recorded DVD VOB and it has both the VTSM_VOBS and VTSTT_VOBS filled in, so my guess is that Adobe is getting it wrong by just looking at the VTSM info...
So definitely a bug in Premiere Elements.
| [0000000c] | Last Sector of VTS | 1384332 | [00151f8c] |
| [0000001c] | Last Sector of VTSI | 31 | [0000001f] |
| [000000c0] | Start sector of VTSM_VOBS | 32 | [00000020] |
| [000000c4] | Start sector of VTSTT_VOBS | 194 | [000000c2] |
| [000000d8] | Start offset of VTSM_C_ADT | 8 | [00000008] |
| [000000dc] | Start offset of VTSM_VOBU_ADMAP | 9 | [00000009] |
| [000000e0] | Start offset of VTS_C_ADT | 10 | [0000000a] |
| [000000e4] | Start offset of VTS_VOBU_ADMAP | 11 | [0000000b] |
| [00000100] | Video attributes of VTSM_VOBS | 21248 | [5300] |
| Bit Rate | VBR | ||
| Mode | Camera | ||
| [00000155] | Number of Sub-picture streams in VTSM | 1 | [01] |
| Bit Rate | VBR | ||
| Mode | Camera | ||
| [00000204] | Aud_1: audio attributes | 4 193 101 110 0 0 0 0 | [04 c1 65 6e 00 00 00 00 ] |
| Application mode | unspecified | ||
| Language type | present | ||
| Channels | 2 | ||
| Language | English | ||
| [00000255] | Number of sub-picture streams in VTSTT_VOBS | 0 | [00] |
Hi ,
Please check the supported files and formats in Elements 11.
http://help.adobe.com/en_US/premiereelements/using/WSeffff8bffc802084- 1665492e133c9c19956-8000.html
Regards
_techkid123_ *Back*
See Expert view timeline zooms when dragging clips on MacBook with Retina Display to troubleshoot problems importing video into Adobe Premiere Elements 11 or working with clips/dragging clips on the timeline on MacBook with Retina Display.
My first thought on reading this link was "why are you pointing me at a fix for timelines when I clearly state that DVD import doesn't work and VOBs just give audio without video"?
Anyway, in case you know it fixes something else, I tried installing it...
No it doesn't fix either of my problems!
So let me once again state them...
Unless someone from Adobe gives confirmation that this is being fixed, I am demanding a refund, as I can't edit video from my DVD recorder, which is the only reason I brought this software!
Adobe makes it virtually impossible to report bugs, so no wonder the software is so poor!
OK - one last attempt.
I have Parallels, with a Windows 7 installation, so I tried installing the Windows version of Premiere Elements 11.
This is using the USB Superdrive on my Retina Macbook Pro...
Guess what, the Video Importer can see the USB drive as a DVD, so the Video Importer is broken on the Mac - Bug 1) Confirmed!
and low and behold, I put in the DVD from my DVD recorder and tell it to import, and I get audio and no damn video!!!
Bug 2) Confirmed - Premiere Elements 11 is completely useless for editing video recorded in a Panasonic DVD recorder. (yes I have tried more than one attempt, including a finalised DVD with top menu).
How on earth do Adobe get away with shipping such poor software????
External DVD drive is not supported by Video importer on Mac.
Refer to http://help.adobe.com/en_US/premiereelements/using/WS8E086945-8338-478 a-9083-710C2F9B1DA9.html
Yes, I have an external Apple Superdrive I bought when I got the new iMac. Luckily I am also an Adobe Cloud subscriber so have been able to use Premiere Pro to import from the external drive. For simple home projects I prefer Elements, but obviously Elements is not much use if I can't import old home movie DVDs to re-edit.
Given that Premiere Pro works it's obviously not impossible to do. I'd suggest this is something Adobe needs to add back to Elements.
North America
Asia Pacific
