Air QR code generator/reader
Oct 14, 2012 4:03 PM
Anyone have any current recommendations for Air QR code generator and reader (ANE, lib)?
I need a solution that will:
1) Generate a text/string QR code in Air desktop
2) Generate a text/string QR code in Air cross-platform mobile app (android or iOS).  Same code base as #1.
3) Scan the QR code on cross-platform mobile device (android, iOS) from within my Air app.
I see a lot of search results for various ways, but so far nothing cross-platform.
Thanks!
Don
    Oct 23, 2012 7:05 AM   in reply to Don Kerr
    Which search results did you try/test?
    The following page seems to describe (at least partly) what you're looking for:
    http://cookbooks.adobe.com/post_How_do_I_add_a_QR_code_reader_to_my_Fl ex_mobile_ap-19074.html
    Jan 10, 2013 6:08 PM   in reply to Don Kerr
    I encode text, string, URL in QR Code using the QR Code barcode generator. It works for the ios 6 and can be scanned easily.
    Feb 13, 2013 10:13 PM   in reply to Don Kerr
    I have written ANE version for ZBar that works on Android and iOS over same ActionScript API. It works similar to CameraUI i.e. I open Native Activity/ViewController that scans and sends the data to AIR app as an async event.
    I have developed this for one of my projects. If anyone is interested revert back on this thread itself.
    Regards,
    sbhave
    Feb 28, 2013 11:42 AM   in reply to sbhave
    I am looking for an ANE for barcode reading. Does your implementation have any limitations to what kind of barcode can be read?
    I do not know the internals of zbar but can it be compared to the xzing library?
    Feb 28, 2013 6:57 PM   in reply to NosliAir
    It supports somewhere around 13 barcode formats. Which you can configure from ane. For supported formats you can google for zbar supported formats.
    Feb 28, 2013 7:31 PM   in reply to sbhave
    See http://code.google.com/p/adobe-air-qr-barcode-zbar-ane for Downloads and sample usage. If you find any issues you can open one on google project.
    Mar 2, 2013 1:35 AM   in reply to sbhave
    Thanks for your reply!
    I am working with your ANE and its a really great! Its super fast at decoding and handles everything perfect.
    I was just wondering if there is a way to customize the screenlayout of the scanner, or is that just the way ANE are set up?
    Regards
    Nordin
    Mar 2, 2013 5:16 AM   in reply to NosliAir
    For android you can.
    You can modify the campreview.xml file in NativeExtension/Assets/res/layout
    Re: Air QR code generator/reader by opening it in Android UI editor for
    eclipse. (Android Dev. plugin for eclipse). Make sure you are not changing
    existing hierarchy or ids of control. You can change or add anything else.
    After this you can run command.txt from within NativeExtension/Assets
    directory. to re-create the new ane package which will have new UI.
    For iOS as of now all UI is generated via code.
    Saumitra Bhave
    Jul 21, 2013 12:34 PM   in reply to sbhave
    Hi sbhave
    I have used your code and its INCREDIBLE and highly recommended. Thanks.
    Do you know what to add to your code so that if it reads a QR code vcard it gives the option to save contact info to the devices contacts list.?
    Paul
    Jul 21, 2013 12:50 PM   in reply to PaulHinrich
    You mean something like this ?
    Jul 21, 2013 11:13 PM   in reply to sbhave
    Hi Sbhave.
    Thanks for your response.
    I still need to read the post but it certainly looks interesting.
    I think it explains how I can make a QR Code having contact details.
    I got your AS3 Qr Code reader to work and it reads a QR Code BEAUTIFULLY, even a VCard. Now your code simply reads the QR Code and outputs the read to a window. Your code doesnt tell the mobile device what to do with the output. Now it is easy enough to add some code which, if the data is a web address, will go to that webaddress. However if I have used your QR Reader (in AS3) to read a vcard how do I code the Reader so that it knows that it must add the contact info to my mobile devices contacts list  and can actually do this ? I have some commercial QR Code readers which use the Zing Library and recognise that its a Vcard and give the choice to save to the contacts list.
    Paul
    Jul 21, 2013 11:58 PM   in reply to sbhave
    I can imagine to do this on either Android or i-Phone would require access to an ANE to access contacts list on the device.
    Paul
    Jul 27, 2013 4:15 AM   in reply to PaulHinrich
    The Zxing Library has a class named VcardResultParser at the address
    actionscrit/core/src/com/google/zxing/client/result
    So I am guessing I would need to add code to first recognise that its a Vcard and then to link the data to that Class ?
    Or am I wrong ?
    Paul
