I am trying to load data from a database using cfc and jquery but can not sort it out due to some issue on client side.
here is what I have so far:
.cfc
<cfcomponent output="false">
<cffunction name="getData" access="remote" returntype="any" output="false">
<cfquery name="test1" datasource="database">
SELECT ID,NAME
FROM table
</cfquery>
<cfset data = serializeJSON(test1)>
<cfreturn data/>
</cffunction>
</cfcomponent>
.cfm
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Untitled Document</title>
<script src="jscript/jquery-1.8.2.min.js"></script>
<script>
$(document).ready(function() {
$("#loadLink").click(loadQuery)
function loadQuery() {
$.ajax({
url: "loaddata.cfc?method=getData",
success:function(data){
alert('data that function gets from the server:' + '\n' + '\n' + data + '\n' + '\n' +
"everything is listed here");
var columnMap = {}
for (var i = 0; i < data.COLUMNS.length; i++) {
columnMap[data.COLUMNS] = i
var str = '<h1>People</h1>'
for (var i = 0; i < data.DATA.length; i++) {
str += '<b>'+data.DATA[columnMap.NAME]+'</b>'
str += ' has a cool score of '+data.DATA[columnMap.ID]+'<br/>'
$("#content").html(str)
return false
</script>
</head>
<body>
<p>
<a href="" id="loadLink">Load Query</a>
</p>
<div id="content">
</div>
</body>
</html>
as you can see this is a simple script (I found it on the web and slightly changed it for testing purposes), the final one should be a bit complex.
here is an error firebug throws every time
TypeError: data.COLUMNS is undefined
I know this is a javascript question but I would really appreciate your help on this one.
now I have two working examples, the first works great and the second one is even better
Is your alert firing? If so, what does it show you? Can you post the output here?
From this line:
yup every time and as I can see everything is normal on the server side
here is the output
<wddxPacket version='1.0'><header/><data><string>{"COLUMNS":["ID","NAME"],"DATA":[["1","John"],["2","Peter"],["3","Susan"]]}</string></data></wddxPacket>
Well there you go. That's not valid JSON format. It is valid between the <string> tags but not with the wddx stuff.
Try adding the returnformat on your cfc method and instead of returning "any" set it to return "string"
<cffunction name="getData" access="remote" returnformat="json" returntype="string" output="false">
Let us know what that returns.
Also, you may no longer need to use the SerializeJson() function as I think the returnformat will do that for you. Test to verify.
I've already tried that and everything else I could think off within the cfc and still cant sort it out.
I added &returnformat=json within url on the client side
url: "authenticationService.cfc?method=getData&returnformat=json",
and now it returns {"COLUMNS":["ID","NAME"],"DATA":[["1","John"],["2","Peter"],["3","Susan"]]}
regardless whats on the server side (returntype (string or any or query), and with or without serializeJSON), though for some reason I'm still getting the same error msg.
I think it should return [object Object] but have no idea how to make it work.
Now that's better. You now have your JSON response exactly as documented here " converts a ColdFusion query into a row-oriented JSON Object with the following elements ...COLUMNS DATA..." : http://help.adobe.com/en_US/ColdFusion/9.0/CFMLRef/WSc3ff6d0ea77859461172e0811cbec22c24-79fa.html
Now at this point you need to parse the JSON and iterate over the data. You can Google something like "javascript parsejson array" for various ways to do this like here: http://stackoverflow.com/questions/9991805/javascript-how-to-parse-json-array
If you Google something like "javascript reference coldfusion json query object" you will get lots of varying examples on how to do that as well.
Hope that helps.
thanks for your comments and for forcing me to learn, really appreciate that
i was able to sort it out and do some other things successfully
Now I would like to output data say
on first click records from 1 to 10
on second click records from 11-20
.etc
though I am not sure how to do it (again the problem is javascript).
in coldfusion component I should obviously use cfloop but not sure how to dynamically change startrow using javascript.
Great! I'm glad you got it working and I purposely wanted to lead you and not just give you an answer. What fun would that be?
I might be oversimplifying things but it seems like you could just pass a value (javascript variable) containing the starting record to your cfc. When you get the data back just increment that variable based on the length (count of records) that was returned. Your cfc can handle the number of records to return each time or you could also pass that to your cfc from javascript. Is that what you are after?
Perhaps you are unaware but there is a "data" setting for the jQuery.ajax call that allows you to pass data to the server. And lucky for you, the data is in JSON format.
http://api.jquery.com/jQuery.ajax/
So you could do something like:
$.ajax({
data: { start: "1", records: "10" }
var columnMap = {}
yup, that's exactly what i want to do but not sure how to handle it from client side
i already have dataType: 'json', within script which converts data back to a JavaScript object so I do not have to parse JSON manually.
Yep, dataType is for formatting the result from the server but data is for passing data to the server. Check out the examples in the docs http://api.jquery.com/jQuery.ajax/
This should get you going with passing data from javascript to your cfc. Let me know how it goes.
dataType - data duh, my bad
it passes data to the server correctly, though I've a different problem now on the server side.
my "simple" plan to cfloop over query, populate array and return json data has failed. whatever I try i can not return JSON format for some reason. definitely need a break, will try to sort it out later!
You may not need to build an array and since the cfc can handle formatting a query object into JSON for you try to use that. There is a "maxrows" attribute to the cfquery tag. Maybe leverage that to get your 10 record chunks. You just need to be sure that your query parameter increments the records for you (first 10, then 11-20, then 21-30, etc). If your datasource does not support that maxrows attribute you could also write your query so that it only returns n records at a time.
See maxrows attribute of cfquery here: http://help.adobe.com/en_US/ColdFusion/9.0/CFMLRef/WSc3ff6d0ea77859461172e0811cbec22c24-7fae.html
"query object into JSON" yup I'm currently using that
also i know about maxrows attribute, as I have been using it all over my websites as well as LIMIT within MySQL statement, of course, where it's possible to set it.
anyway I am missing the basic logic here, if maxrows is set (within <cfquery not <cfoutput query...) the query will actually return the first 10 rectords each time and given that cfquery tag does not support startrow I don't see how to make it work without cfloop.
Yes you are correct. Okay, so here is what I was trying to say with this statement "You just need to be sure that your query parameter increments the records for you (first 10, then 11-20, then 21-30, etc)"
Again, this is probably over simplifying but hopefully you'll get the gist. I see that you have ID and NAME in your query example above. So on your first call to the cfc it will return the first 10 records:
<cfquery name="test1" datasource="database" maxrows="10">
SELECT ID,NAME
FROM table
ORDER BY ID
</cfquery>
1 Smith
2 Smith
3 Smith
4 Smith
5 Smith
6 Smith
7 Smith
8 Smith
9 Smith
10 Smith
When the user clicks for more you pass it the last record that you displayed and have the cfc return the next 10 records.
SELECT ID,NAME
FROM table
WHERE ID > 10
ORDER BY ID
</cfquery>
11 Smith
12 Smith
13 Smith
14 Smith
15 Smith
16 Smith
17 Smith
18 Smith
19 Smith
20 Smith
and so on. I'm not sure if that will work with your data or not but that is what I was thinking. Notice I added an order by clause and where clause to the query. You'll need to do something with these in order to make your 10 record chunks.
Hopefully that clarifies my thinking. Anyway it sounds like you are making good progress.
we obviously have the same thinking (looking for the easiest possible solution), I thought of that first,
however this is never going to work because cfquery will be a bit more complex say
SELECT ID,NAME
FROM table
WHERE cat="cat1" and subcat="subcat2"
ORDER BY DATE
</cfquery>
this is still much simpler than what I'll use on production server.
so I can have IDs like this
5 Smith
210 Smith
355 Smith
800 Smith
etc
in this regard ID > of something is out of question
I thing looping over a cfquery is is the only solution, after which I need to do something
I\ve already tried to put data to array of struct and than serializeJSON but failed to sort it out
Great! Glad you got it working.
