I have 8 primary selection tabs in my Spry menu. Those pages live in the root folder. All other pages live in a sub-folder called "pages". This setup worked perfectly for months. At some point, and I know not why or exactly when, when I click on a "pages" sub-folder tab and then try to go back to the primary row of tabs, the selection pop-up tells me that the path for any of those on top has changed to http://mywebsite/_pages/Home and of course an error occurs. I am using CS6 and I have modified the template several times as well as the index.html file. I have even swapped out all the newly modified pages. But the paths appear to stay exactly as they were when I first noticed them. What else can be causing this problem?
Thanks in advance.
John Oster
There is not a link I can show you. That is the center of the mystery for me. I can't find the origin of the link that pops up.
When I hover over the "Home" tab, I can see that the path will be incorrect. It should be saying http://www.mysite/index.html Instead, it is saying http://www.mysite/_pages/index.html I already know it's not going to find the 'Home' page in the "pages" folder. So why is it trying to tell me that's where it is?
I had the thought that the "broken links" checker in Dreamweaver did more damage than I had previously imagined. I just checked the navigation on one of the pages in the "pages" subfolder and found this at the top of the Spry navigation:
<li><a class="MenuBarItemSubmenu" href="../index.html">Home</a> This indicates a correct path from a sub-folder page TO the "Home" tab in the Spry menu, I assume. But I have no idea how this got there other than from a "broken links" check. (It was a page created from a template.)
I'm self educated. And I know that's an oxymoron, but shouldn't all the pages in my site come from the same template? So the same navigation appears on each page? I really don't know some of these basic things. Should my links be document relative or site root relative? I only have 29 pages and this is my first published site. I think I should start all over again. What would your thoughts be on that? At this point I'm wondering if that is the path of least resistance.
John O.
Because you are not giving us much to work on, I am assuming that index.html resides in the root directory and the other pages reside in the pages subdirectory. I am also assuming that you have created a template that includes the menu items with relevant links.
If the above is true, you are best off using absolute links, ie in lieu of
use
<a class="MenuBarItemSubmenu" href="http://www.mysite/index.html">Home</a>
I apologize for lack of content. I thought I was making it clear. But of course my eyes are beginning to cross at this point.
Yes, your assumptions are correct. At the top of this page I described it as best I could. The 8 visible menu tabs link to pages nested in the root. All other pages lived in a sub-folder titled "pages".
The index.html file lives in the root as well.
The drop-downs link to pages in a sub-folder.
I can skip across the menu bar and each page appears as it should. But when I click on a drop-down link to a page in a sub-folder, I am not able to go back to the top menu.
When I hover over the 'Home' tab, the command indicates http://www.mysite/_pages/Home
I just finished moving all the sub-folder pages to a new sub-folder and created a completely new template with new navigation links.
The same problem occurs, but with the new navigation links.
When I click on a sub-folder page and then hover over the 'Home' tab, the command indicates: http://www.mysite/newsubfolder/home
So I will try your suggestion. Thank you for your time. I will let you know how it goes. If this doesn't work, I'm going to scratch this and begin again.
I've just tried your suggestion and I am unable to create a workable page from the template to use as an index page. It's time to scrub this project and begin anew. Just as well. I have learned a lot from this experience. I know quite a bit more than I did before I started this.
I can fetch a backup copy and modify that so I have a working site while I build a new one.
Thanks again for your time and suggestions.
John O.
Please do not start again, you are very close to the solution.
Have a look at the following scenarios:
1. If the template shows
<a class="MenuBarItemSubmenu" href="about.html">About Us</a>
<a class="MenuBarItemSubmenu" href="contact.html">Contact</a>
and the template is applied to index.html which resides in the root folder, none of the links will work. However, if the template is applied to about.html which resides in a subfolder (_pages), then all of the links will work.
2. If the template shows
<a class="MenuBarItemSubmenu" href="http://mywebsite/index.html">Home</a>
<a class="MenuBarItemSubmenu" href="http://mywebsite/_pages/about.html">About Us</a>
<a class="MenuBarItemSubmenu" href="http://mywebsite/_pages/contact.html">Contact</a>
then it does not matter where the template is applied, the links will always work, assuming that about.html and contact.html are both located in the _pages subdirectory.
North America
Asia Pacific
