ORIGINAL POST: SEPT 19, 2012 http://forums.adobe.com/message/4784335#4784335
Upgraded to cs6. All programs work perfect for me exceopt Dreamweaver.
I have never expierenced this challenge however no matter what file(s) I upload dreamwever is chanign the file permissions.
For instance if I upload an image to the sever the image won't appear. I check permissions and they are set to 0. Same with files.
I have to now go in to each item I upload and change permissions to 644 or 755 depending if its a file or directory.
This is a Dreamweaver exclusive problem as it does not happen when I use Filezilla and Im working on 6 different servers.
ONLY when I upload files with Dreamweaver CS6 do the file permissions change on upload. Cs5.5 no problem.
Any ideas?
Aloha!
STILL NOT WORKING UPDATE:
I was even on with India Adobe support doing a screen share and they watched in real time as I uploaded a file and Dreamweaver and it changed the permissions to 000. You can 'Get' a file with 775 permissions then 'Put' that same file and it will chanve to 000 permissions.
Support failed to address this problem after 30 days and never called back.
STILL NOT WORKING UPDATE: Changing ro SFTP seems to be a workaround.
See Full Discussion here as I posted in the wrong area. http://forums.adobe.com/message/4784335#4784335
I'm using DW6 version 12.2, and this problem is still happening.
The permissions are defaulting to 0664, where I need them to be 0644. Every time I create a new file, it defaults to 0664, and I'm unable (not permitted) to view that file online until I go in, using another FTP program, and change the permissions to 0644... or manually go in the slow-poke way using DW6 Remote View -> [file name] -> Set Permissions.
Too bad there's no way to configure this in the Preferences area of DW6.
North America
Asia Pacific
