LR 4.2 update downloads and dialog .pkg opens. Click and Install Icon briefly appears in Dock and dissappears. No "continue" dialog opens. Adobe tech took over desktop X2 without sucess. Apple says cannot help. Tried uninstalling LR 4.1, Tried in Safe Mode, many work arounds did not help. MacBook with 10.8.2 installed update promply. LR 4.1 runs just fine, but why can I not install the update?
Do you have a case number which I can review from your previous interactions with our support team?
Case # 0183688847 Three chats, one lost but two took over my computer and could not fix. Apple says it is Adobe problem, they had little to offer. I like to keep updating LR but do not require this update to operate. My MacPro is 2007 and cannot update OS to Mountain Lion. My Macbook Pro (Mountain Lion) updated LR 4.2 just fine. David
If you select the Adobe Photoshop Lightroom 4.pkg file and go to File>Get Info. What does it have listed under Open With?
"Installer.app (Default)
App Store
Other"
The Installer app is the proper setting. Have you tried opening any other pkg files to see if they are able to open successfully?
yes recently installed Photomatix Merge to 32 bit with no trouble. We uninstalled that during efforts to fix. Now new problems appear. Photoshop CS6 could not update ACR today leaving error message: U44m1p7. At same time I find my Canon Raw files since Oct 2 have no EXIF data and Photoshop "cannot open, does not recognized file type" prior to that date files look and act normally in PS. I cannot append metadata presets on files saved since that date. I reset preferences to default with no effect. I don't know if the LR 4.2 download did this or these faults in PS CS6 are preventing LR updates. I have uninstalled and reinstalled LR 4.1. Maybe I need to uninstall and reinstall PS?
Addendum: These October Canon RAW files open in Aperture and DXO without problem and have EXIF data there. Somehow Photoshop has become corrulted?
Before we jump to a different issue please try deleting your install files and try download a new copy of Photoshop Lightroom from http://www.adobe.com/support/downloads/detail.jsp?ftpID=5487
It is difficult to say what caused your failure of the Camera RAW update. You can review the install logs determine the cause of the failure by following the directions listed at Troubleshoot with install logs | CS5, CS5.5, CS6 - http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5-cs5.html.
I moved all install downloads LR 4.2 found in "Downloads" file to Trash. I downloaded new LR4.2 from site you provided. Double click on download, icon appears on desktop (grey square with blue disc and letters LR. Tag below icon "Lightroom 4.2 432.7 MB". Double click icon and dialog opens with package. Double click on package an same behavior "install" icon briefly appears in dock and disappears. No further action occurs. I repeated above with LR4.1 in Trash but to no avail.
Then it would appear the download is not at fault but instead for some reason your Installer.app is not functioning properly. You can try going to the Console app in your Application/Utilities folder. This will allow you to access the logs from the time period of trying to invoke the installer.app.
I find understanding this beyond my knowledge. Original effort was 10:05:00 but repeated at 10:43.
Activated .dng and click on .pkg 10:43AM
The first line on opening .dng reports "job appears to have crashed Bus error: 10"
Diagnostic Report/hasplmd_2012-10-28-100150_localhost.crash
From Kernal Log:
Oct 28 10:00:20 Mac-Pro-4 kernel[0]: CODE SIGNING: cs_invalid_page(0x1000): p=237[ksadmin] clearing CS_VALID
From System Report, top part only:
Process: hasplmd [1038]
Path: /usr/libexec/hasplmd
Identifier: hasplmd
Version: ??? (???)
Code Type: X86 (Native)
Parent Process: launchd [1]
Date/Time: 2012-10-28 10:43:04.455 -0700
OS Version: Mac OS X 10.7.5 (11G63)
Report Version: 9
Crashed Thread: 0
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
VM Regions Near 0:
--> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] ---/--- SM=NUL /usr/libexec/hasplmd
__TEXT 0000000000001000-00000000001d2000 [ 1860K] r-x/rwx SM=COW /usr/libexec/hasplmd
Thread 0 Crashed:
0 ??? 0000000000 0 + 0
1 libsystem_kernel.dylib 0x00fa9ef3 mig_get_reply_port + 12
2 libsystem_kernel.dylib 0x00f9c06d mach_port_allocate + 90
3 ??? 0x0048f6ac 0 + 4781740
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x0048f63c ecx: 0xbffffd9c edx: 0x00fa9c0a
edi: 0x00000907 esi: 0x00fb31bc ebp: 0xbffffd38 esp: 0xbffffd2c
ss: 0x0000001f efl: 0x00010286 eip: 0x00000000 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x00000000
Will we have replaced the install files. You may want to consult with Apple to see if there is some what to repair the Installer.app.
Not clear. I just updated ADC that came in to Software Update this morning. I have asked Apple to help and they state that the install files are generated by Adobe update.
I will take the computer to Apple Store Genius Bar and see if they can help. David
addendum, typo: software update today was Adobe Camera Raw. In this MacPro Desktop: Photoshop/Bridge/ACR is 7.0.0.308 after update. MacBook Pro Mountain Lion: Photoshop/Bridge/ACR is 7.2.0.46. Is this significant difference or does is imply that the MacPro Desktopis not updating even ACR. I did not get evidence of failed installation when I downloaded and installed update in Desktop where I cannot update LR 4.2.
