senthil.t
Adding event listener to check-in menuitem in illustrator
Oct 21, 2012 9:44 PM
Tags: #illustrator #libraries #client #drive #check-in
Adobe Drive client libraries provide check-in option in the illustrator.
Inside illustrator can we add an event listener to the check-in option?
Or is it possible to trigger a check-in using a custom illustrator plug-in?
I do not find any documentaion about the Adobe drive client libraries.
Senthil.
    Oct 22, 2012 1:07 AM   in reply to senthil.t
    From my knowledge, inside Illustrator, you can't add an event listener to the the check-in option, but I am not sure about that, you can ask help from Illustrator forum.
    Regarding how to trigger a check-in using a custom Illustrator plug-in, currently, you can't do it, one option is asking Illustrator to add this functionality in Illustrator SDK. another option is, Adobe Drive adds a helper library, in the custom Illustrator plug-in, you can invoke check-in operation from this library, however, there is a drawback of this option, this will break the check-in logic of Illustrator, how to notify Illustrator and refresh document status is a problem.
