Hello,
I use C5.5
In a slide, I have 3 buttons. Each is attached to a variable.
When I click to the button 1, an highlight and a text caption with audio included appears.
I did the same actions on the other buttons.
I'd like after the 3 clicks to show a new button with a text caption with audio. But I don't find a solution. I try to used conditional actions based on some example of Lilybiri (template menu) but it's not doing the good think, because any button jump on a slide and return to this slide. The button appear at the beginning or not depending on the situation in the timeline.
Could you help me please for this ?
Florence
Hi Florence,
What is the event that triggers the conditional advanced action 'Organisation'? In my template example this is triggered on entering the slide, but that has no sense here. You will have to check the condition by the same event that triggers the standard action, when clicking on each of the buttons. I have explained that also somewhere, and multiple times in threads here, but cannot remember the links. To combine the standard with the conditional action you will need a conditional action for each button. That action will have two decisions, where the first is a simulated standard action, something like this for the first button:
Decision 1 'Always'
IF 1 is equal to 1
Assign v_item7_1 with 1
Show H7_1
Show Ex7_1
Decision 2 'Check'
IF v_item7_1 is equal to 1 AND
v_item7_2 is equal to 1 AND
v_item7_3 is equal to 1
Show BtNext
Show A7End
So the condition is checked every time a button is clicked, but the second decision will only result in TRUE when all buttons have been clicked.
Lilybiri
I try to find other examples of you but there are a lot
It's always vague for me so if I understand.
For this kind of slide, "on enter" field will be "continue
For each button (name Bt1, Bt2, Bt4, BtEnd), I create a conditionnal action with the actions:
Tab1 (decision "always")
Show H7_1
Show Ex7_1
and the tab 2 is the tab for the decision "check"
Show BtNext
Show A7End
But I can't save the advanced action with this.
So I suppose that I have to create a tab for each button for only one conditional actions. Then, I put this advanced actions for each button but when i click on a button, all the 3 functions.
It's very frustrating because I know the answer is closely to my nose
No! Read my mail correctly: the first decision (you call it tab) Always has to be executed every time, so the condition must be:
IF 1 is equal to 1
Only the 3 buttons that have to be clicked need a similar action with the 2 decisions Always and Checked. Both decisions will have to be edited for each button, of course. Here is an article about combination of standard with conditional action:
http://kb2.adobe.com/community/publishing/862/cpsid_86254.html
Lilybiri
Hi Lilybiri,
Thanks for your last example, it's more clear with the explanation on the link.
I test this and it's working.
Best regards
Florence
