• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
AIR 3.5 still doesnt have 96x96px xhdpi icon support on android.
New Here ,
Oct 25, 2012 Oct 25, 2012
Nexus7's use the larger icons.
TOPICS
Development
Views
7.8K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee , May 30, 2013 May 30, 2013
This is a known issue and is planned to fixed in next release of Flash Professional. For the time being, could you please package your application through command line using adt (http://help.adobe.com/en_US/air/build/WS901d38e593cd1bac1e63e3d128cdca935b-8000.html). Please let us know how it goes.
-Nimit
Votes
Translate
Translate
Engaged ,
Oct 29, 2012 Oct 29, 2012
At least its not Apple where this could cause the whole app to get rejected. Have you tried manually adding it?
Votes
Translate
Translate
Report
Report
Contributor ,
May 10, 2013 May 10, 2013
This is now the case on Google Play. My APK just got rejected for not having 96x96, and I can't even add that at the command line!
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Please try out the latest build available at http://labs.adobe.com/downloads/air.html, this should solve your problem, please let us knwo how it goes.
Regards,
Nimit
Votes
Translate
Translate
Report
Report
Contributor ,
May 12, 2013 May 12, 2013
It turns out it was a native extension I included in the manifest that was causing Google Play to imply that an "icon" was missing. Very strange...
Votes
Translate
Translate
Report
Report
Engaged ,
May 13, 2013 May 13, 2013
What extension was it and what did you do to resolve it?
Votes
Translate
Translate
Report
Report
Explorer ,
May 29, 2013 May 29, 2013
Just downloaded the Air 3.8 beta. Still cannot add a 96x96 icon for xhdpi devices. If I unpack the apk, I can see that he 72x72 is in the xhdpi folder. I have tried to add the icon myself by editing the app-xml file, but it does not work. I am going to try to manually add the proper icon in the proper folder, but that is a total kludge of a solution,
This is a totally standard part of Android development. Please provide a fix or at least a work-around.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Have you added 96x96 icon name in <image96x96>icons/96x96icon.png</image96x96> under <icon> tag in app-xml?
-Nimit
Votes
Translate
Translate
Report
Report
Explorer ,
If I add the 96x96 line to the app-xml file and do a Publish from Flash, that line is deleted from the app-xml file and the 72x72 icon is placed in the XHDPI folder in the apk.
app-xml pre-build:
<icon>
        <image48x48>AppIconsForPublish/icon_square_48.png</image48x48>
        <image72x72>AppIconsForPublish/icon_square_72.png</image72x72>
        <image36x36>AppIconsForPublish/icon_square_36.png</image36x36>
         <image96x96>AppIconsForPublish/icon_square_96.png</image96x96>
    </icon>
app-xml post build:
<icon>
    </icon>
I suppose I can go back to manually packaging the app - but would it be that big a deal to add the icon as it is supposed to be added in the same way the others are handled?
Votes
Translate
Translate
Report
Report
Adobe Employee ,
-Nimit
Votes
Translate
Translate
Report
Report
Contributor ,
Jun 27, 2013 Jun 27, 2013
I installed Flash CC and no fix for this.  Actually it is now worse.  Previously in AIR 3.6, icon images seemed to get scaled up on higher resolution devices (not sure if that is Android behaviour vs AIR/Flash) so although not as crisp as I would have liked, the icon was at least a good size.  In AIR 3.7, a bug was fixed to support icon size > 72 and now when I build it, I get a mini icon through out the app.  In sumary:
Use Flash CC + AIR 3.6 = upscaled icon images
Use Flash CC + AIR 3.7 = mini icons
Only solution it seems is to use command line but that isn't really acceptable given I just bought Flash CC and icon sizes on Android haven't really changed in a long time.  I actually posted about Nexus 10 icons in January.  I really hope that the release or update cycle for Flash CC isn't yearly.
http://forums.adobe.com/message/5024692#5024692
Votes
Translate
Translate
Report
Report
Contributor ,
Aug 26, 2013 Aug 26, 2013
Just updated flash update 1.  Besides it now not starting up (error 1, uninstall and reinstall), I don't see support for any new icons.
Votes
Translate
Translate
Report
Report
Explorer ,
Sep 07, 2013 Sep 07, 2013
@nimitja
I have been packaging from command line, but there is no way to add the extra icons from command line. If I try to include the icons from command line, it sticks them all in the /assets/ folder for Android. How do I make it put it in the app root where it needs to be for Android to see it rather than "/assets/"?
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Have you added the icons in the application.xml under icon tag?
-Nimit
Votes
Translate
Translate
Report
Report
Explorer ,
I had it there before but the Flash editor ate it when i built/tested. I just tried inserting the XML right before building with command line. That seems to have updated the xhdpi icon to 96x96. So apparently AIR supports this, other than the faxt that the editor strips out the XML when building/testing.
Also I have heard talk of a 144x144 icon, I added this in the XML as well, but it seems to only have been used as an 'ouya_icon.png' under drawable-xhdpi in the final APK. What is the deal with 144x144? Is it a standard or Google Play size, or just something ouya-specific?
Votes
Translate
Translate
Report
Report
Contributor ,
144 is for xxhdpi where 96 is xhdpi.  xxhdpi came out a year ago with the Nexus 10.
Votes
Translate
Translate
Report
Report
Explorer ,
Is there any way to get drawable-xxhdpi/icon.png into my APK?
From what I understand drawable-*dpi is about what how dense the pixels are on the screen, not the tablet size iteself, so theoretically even a small device could have xxhdpi?
Is this correct?
What other tablets of notable install base besides Nexus 10 have xxhdpi?
Votes
Translate
Translate
Report
Report
Contributor ,
Not sure all the scenarios but just noticed that in the beta 3.9 of the AIR SDK, it supports the xxhdpi icon.  Still waiting for any way to have Flash Pro be able to do this.  From release notes of beta 3.9:
XXHDPI (144x144) Icon Support – Android - With this feature we have added support for beautiful, high resolution icons on devices
such as the Nexus 10.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Could you please share the command line and AIR SDK you are using. You can try with the below command in your terminal to package the apk:
Path/archive_air_3.9_with_asc2_drm_sdk/bin/adt -package -target apk -storetype pkcs12 -keystore Yourcertificate.p12 -storepass CertificatePassword APKName.apk Example-app.xml Example.swf /assets
Also, ouya specific size is 732x412. If you want to use 144x144(xxhdpi) then you can use latest AIR SDK beta available at http://labs.adobe.com/downloads/air.html
-Nimit
Votes
Translate
Translate
Report
Report
Contributor ,
Oct 15, 2013 Oct 15, 2013
Hi nimitja,
I installed the latest AIR SDK to Flash CC on my Mac but the icons96x96 and 144x144 are still not supported. Is there a date when this is going to be fixed?
Is there any adobe tutorail/instruction on how to add these icons via command line?
Best
Jan
Votes
Translate
Translate
Report
Report
New Here ,
Tried using the Flash CS6 IDE and tried to add it manually to the app.xml file and then build the air file using adt.  adt throws an error about the size being invalid.
I'm not even going to attempt to make an air app for ios lol.... can't imagine it being accepted ever.
david,
Votes
Translate
Translate
Report
Report
Engaged ,
Oct 30, 2012 Oct 30, 2012
You should give iOS a try, apple is a PITA but they are unquestionably the industry leader.
Votes
Translate
Translate
Report
Report
Engaged ,
Another thought. Maybe you do not need the 96px icon. Such is the case with the Kindle fire it uses a much higher resolution image on the home screen than the 72px max size that Air supports but it pulls it off the server, when you submit to amazon you include a 512px image and I believe that image is then used to create the home screen icon.
Votes
Translate
Translate
Report
Report
New Here ,
Yup, there is a 512px image... thats a separate issue...   about halfway down the page it lists the icon sizes for android : http://developer.android.com/guide/practices/ui_guidelines/icon_design_launcher.html  ...
Votes
Translate
Translate
Report
Report
Explorer ,
Oct 29, 2013 Oct 29, 2013
You can add 144 and 96 micon entries manually in the app descriptor, then you can either use adt, or mark the app descriptor as read-only, and flash will not strip lines off whil compiling!
Votes
Translate
Translate
Report
Report
